Old 09-21-2011, 09:49 AM   #1
2004 25' Classic
Newmarket , Ontario
Unusual Tire Wear
Have a 2004 25' Safari. Purchased new in 04 and after two years had to replace the "Marathons" because of bulges in sidewalls. Now have 40k on the replacements. No issues with the sidewalls BUT have a problem with the curbside tire leading axel. Noticed today that the tire has worn on both edges for a distance of about 10". No tread. Face of the tire is fine. Jacked the trailer up and checked visually for an alignment problem. Tire spins true. Would normally replace the tires (all others are normal ware) after five years but do not want to replace the "bad" one and then have the same ware issue. Could this be just normal ware or do I have some type of aligement issue. Spoke to a Goodyear dealer who suggested that I probably had a brake lock-up. I don't think so.
Thnx
Jake
Jake is offline   Reply With Quote
Old 09-21-2011, 09:52 AM   #2
dznf0g's Avatar
Oswego , Illinois
Could you post some pictures of the tire wear?
I suspect you have some alignment and/or balance issues
Old 09-21-2011, 10:25 AM   #3
Thnx
Jake
Jake.
How well do you have the running gear balanced?
Old 09-21-2011, 11:31 AM   #4
SteveH's Avatar
Common Sense , Texas
I would wager that tire has seperated. That's what the Goodyear Marathons do best.
Regards,
Steve
Old 09-21-2011, 12:44 PM   #5
2010 27' FB Classic
N/A , Texas
That's what it sounds like to me too.
Old 09-21-2011, 06:14 PM   #6
2004 25' Classic
Newmarket , Ontario
Had all tires balanced when I initially installed them even though the GoodYear dealer said that it wasn't necessary. Tire in question still has the wheel weights. Given the fact that we hit a couple of rather large pot holes on I-81 on our trip down to SC I am inclined to believe that I have a separation as suggested by a couple of other Forum Members. What do you think?
Old 09-21-2011, 06:17 PM   #7
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
My 25' Airstream wears Michlen light truck tires. 4 years, 40000 miles or so, no wear, no problems. That is what I think of GYM's.
Old 09-21-2011, 07:36 PM   #8
2004 25' Classic
Newmarket , Ontario
Bill
Were you able to get the same tire size 225/75R15 in the Michelin LT tire ?
Old 09-21-2011, 07:44 PM   #9
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Jake,
Both edges, inside and outside worn in the same place on the tire? No sidewall damage?
Is the tech who told you the balance was unnecessary the one who balanced the tires?
Could be he necessarily did a rotten job.
I would suspect balance.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 09-21-2011, 08:42 PM   #10
Martinez , California
If the inside and outside edges of a tire are worn evenly but the center of the tread is not it's almost always from running the tire under-inflated. If the center is worn but the edges aren't, the tire was over-inflated. If one edge is worn but the other isn't it's an alignment problem. If the tire has odd scuff marks, as if it had been dragged sideways, it's an alignment issue. If the rubber on one edge or the other has odd "cups" it's usually a balance issue, if I remember right. This is all coming from Auto Shop classes of almost 50 years ago, but I don't think much has changed.
Mr.Bill is offline   Reply With Quote
Old 09-21-2011, 09:39 PM   #11
Was the entire running gear balanced as an assembly, namely the tire, whell and hub and drum.
If not, then the running gear was not properly balanced.
Old 09-21-2011, 11:22 PM   #12
Scott J-24's Avatar
2009 27' FB International
Los Angeles , California
Andy,
When I replace my tires where can I get the entire running gear balanced as an assembly? Can any tire store do this, or do we need to go to a specialty shop (or come to you)?
Scott, Becky & Heidi (our standard poodle and travel companion)
WBCCI #1215
Air #54601
Remember... No matter where you go, there you are...
2009 27FB International Ocean Breeze
2010 Toyota Tundra CrewMax, 5.7L V8, 4x4
Scott J-24 is offline   Reply With Quote
Old 09-22-2011, 02:11 AM   #13
2005 19' Safari
GLENDALE , AZ
Andy is probably trying to avoid being called out for pushing commercial products and services, but he's hinting at Centramatic Dynamic Balancers. Many of us have purchased these over the years to reduce tire problems, and Inland is a supplier. This is not a plug, just a statement of fact.
Personally, I searched these out after discussing Airstream tire problems with a neighbor who is an independent long-haul trucker. They have had these on their tractor for millions of miles, and swear by them; because they add 100,000+ miles to tire life, which saves them money. He says they eliminate pounding and cupping, which is a common problem on big rigs. The tires run much cooler, smoother and wear more evenly. This is probably less apparent on Airstreams; because we don't ride in the back, and we don't put near as many miles on our tow vehicles. However, to me its a good investment, if it reduces the chance of blowouts. We put these on when we switched to 16-inch wheels and all-steel, Michelin XPS Ribs.
Link to video demonstration and more information:
http://centramatic.com/Page.aspx?page=Demo
If you think this will help your problem, there are a couple of similar products available. But the easiest way to purchase these is just to call Andy for details. His pricing and shipping costs are competitive, and you won't have to do a whole lot more research. By the way, I am in no way connected to Andy or Inland RV, other than being a satisfied customer. (I don't work for Michelin, either.)
Old 09-22-2011, 04:52 AM   #14
Yes, but not necessarily true if the worn area only spans 10in.
PFC
"Tahawus"
RLC
John Prine
Airstream Tire Failure Poll Phoenix Tires 150 05-14-2018 07:34 PM
WD hitch and tire wear... flmgrip Hitches, Couplers & Balls 46 09-14-2011 07:34 AM
Need One Tire.. 1Rookie Tires 8 06-13-2011 06:09 PM
Wheel and tire Combo Mr & Mrs S Wheels, Hubs & Bearings 2 05-09-2011 10:10 PM
Correct Tire Pressure on Tow Vehicle Jim Pona Tow Vehicles 4 02-01-2011 10:37 AM
