Old 09-23-2011, 04:15 PM   #29
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
I had a very hard time balancing my Bridgestone Dueler A/T's and finally got the N. Salt Lake Firestone dealer to give me 2 new front tires. Even then, they had a very hard time getting them to balance. I did get them to do pretty well at the Boise Ford dealer, but my set of Michelin's have always been smoother. When my Firestones get bald enough, it's another set of Michelin's for me. I did the Firestone's when they had a buy 3 get one free deal, but the PITA is more than I can stand.
Pap
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 09-24-2011, 04:14 AM   #30
2005 28' Safari
saline , Michigan
Originally Posted by Jake
Thnx to all. A wealth of info here. Am now in search of replacement tires again. Have given up on the GYM 's. Looking at the Michelin LTX 235/75R 15. Anyone had any experience with these or other Michelin products?
I only have a few thousand miles on mine but they ride about the same as my old GYMs. I haven't had to put air in them since I installed them. Also, I have Centramatics and I recommend them. You won't have to worry about balancing when you have them. Cost about $180 for a set to fit the 15" wheel.
Kosm1o is offline   Reply With Quote
Old 09-24-2011, 05:32 AM   #31
2005 19' Safari
GLENDALE , AZ
Michelins; you get what you pay for -- More expensive and worth it. We have run Michelins on all our vehicles, since the old Michelin X radials in the late 60s. The few times we used other brands (mainly, OEM tires on new vehicles), we had tire failures or very poor treadlife.
Right now we have Michelin XPS Ribs on our 19-foot Bambi, and we don't worry about blowouts or tread separation. The tires could safely handle 75-80 mph sustained speeds, but we still drive 55-65 depending on the type of roads; because we feel safer towing at the lower speeds and get significantly better fuel economy.
We have Centramatics, although Michelins typically require very little weight to balance; they are just insurance against out-of-balance problems with the other spinning parts in the running gear. I have ridden in our Airstream at 55-65 mph for a short distance, and the ride is very similar to our 2008 Tundra. My wife leaves a napkin holder with salt and pepper grinders on the table (with a non-skid mat underneath, mainly to prevent scratching the table top), and it has never fallen over or off the table while traveling on highways.
The conversion to 16-inch wheels and XPS Ribs was relatively expensive, but it has been worth the added peace of mind, versus the constant worry about blowouts with Goodyear Marathons and (later) Maxxis tires.
Old 09-24-2011, 07:00 AM   #32
richinny's Avatar
2011 34' Classic
say jake, there is one more test to try besides spinning that tire on a balancer. let that air out and see it the shape deforms. if the belts have shifted it can become more apparent without air in the tire.
Ricky
Old 09-24-2011, 07:01 AM   #33
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Centramatic System
We also advise the use of the Centramatic system!!
Just wish they had an application for the Burb.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Airstream Tire Failure Poll Phoenix Tires 150 05-14-2018 07:34 PM
WD hitch and tire wear... flmgrip Hitches, Couplers & Balls 46 09-14-2011 07:34 AM
Need One Tire.. 1Rookie Tires 8 06-13-2011 06:09 PM
Wheel and tire Combo Mr & Mrs S Wheels, Hubs & Bearings 2 05-09-2011 10:10 PM
Correct Tire Pressure on Tow Vehicle Jim Pona Tow Vehicles 4 02-01-2011 10:37 AM
