View Poll Results: Do you have radial tires or bias ply tires on your stream?
Radials. 47 74.60%
Bias Ply. 16 25.40%
Voters: 63. You may not vote on this poll
Old 05-07-2006, 08:51 AM   #15
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Originally Posted by lebolewis
How do you figure out the mfg date on tires? What are the codes?
If you look on the tire, near the bead where the wheel meets the tire, you will see a series of letters and numbers that will end in a three or foour digit number in a separate square. If you have three digits in the square, you should probably replace the tires, since they were made in 1999 or before, and are close to the end of their useful life.
The four digit code is for the week and year the tire was manufactured.
A tire made the first week of 2001 would have a code of "0101".
A tire made earlier this year would have, say, "1206". Fresher is better.
Old 05-07-2006, 01:57 PM   #16
Pop Rivet's Avatar
1990 25' Airstream 250
Altoona , Georgia
I had a 34' avion and I used light truck radials with reaql good results - watch to make sure you get the correct load rating for your unit
Pop Rivet is offline   Reply With Quote
Old 06-07-2006, 05:06 PM   #17
crowbar68's Avatar
1975 27' Overlander
fort wayne , Indiana
tires
replaced my hercules 7.00x15 bias plys w/ goodyear marathon st 225 75r15's. i like the looks of the bias ply tires better and they are taller. haven't driven enough miles to like one or the other better. it is all a matter of opinion. buy what you like.
crowbar68 is offline   Reply With Quote
Old 06-07-2006, 05:45 PM   #18
1976 25' Caravanner
Campton , New Hampshire
Originally Posted by scottanlily
Hello scf31,
Now youve done it ! opened the floodgates of airstream tires ,and choices,whos right ,whos wrong ,who?You will get alot of input here,then be confused and not sure.Anyway we all want to help you with your question.I will tell you what I use on my 1960 tradewind single axle. I use 700-15 bias ply tires with that rugged look .Thats what I want ,the look that Im after.I run hercules tires with 4 sidewall plys and 5 tread plys ,thats the construction and they are not "ply rated" as many are ,meaning that they have less plys such as 2 sidewall and3 tread plys but are RATED as a 8 ply in strength.I have used greenball towmasters with no problems ,looked rugged also,Their D range tire was less rugged looking ,so I got the hercules D range.
These tires are listed as LT ,as all the bias ply 700-15s will be .Im very happy with them . have not had any trouble with them .I only offer my experience with these tires and hope that this helps.
good tire luck!
scott of scottanlily
Scott , which hercules tire model are you using that is not ply rated
ticki2 is offline   Reply With Quote
Average speed you tow at? John Community Polls 294 10-24-2015 02:45 PM
Make of your tow vehicle John Community Polls 97 11-24-2011 02:24 PM
What Airstream Clubs do you belong to? airstreamcaravel Community Polls 44 09-13-2007 10:09 AM
Did we influence you? A New Poll. jcanavera Our Community 5 07-11-2003 01:35 PM
1980's Airstreams davidz71 Our Community 19 11-06-2002 11:17 AM
