Old 09-05-2006, 09:59 AM   #1
lewster's Avatar
Naples, FL , Hood River, OR
Originally Posted by Foiled Again
Many people have had a flat on a tandem rig, and not known it until a passing motorist flagged them down or until they stopped for gas, etc. Lose on tire on a single axle Airstream, and even with a w/d hitch, you're risking a rollover. You're also going to sustain major damage on your 'Stream if you don't get stopped almost immediately. Really small units like a 16 and a 19 weigh less and just can't accommodate a dual axle, but anything longer, you're playing with fire.
Paula Ford
This type of problem is easily solved now. Look into a Pressure Pro tire monitor system. It will let you know if any tire on your rig loses a significant amount of air while under way giving you plenty of time to pull over to determine the cause of the air loss.
I won't travel without one.......especially on the single axel 19CCD It's the cheapest insurance against a blow-out due to air loss.
Old 09-05-2006, 11:00 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Lew, do you have a comparable system on your Sprinter? You have duals on it, don't you?
tire pressure wb13798 General Motorhome Topics 16 01-27-2007 12:31 PM
dual wheel tire pressure jpurdy Tires 2 10-14-2006 11:03 PM
Tire Pressure TBYRNE Tires 11 08-09-2002 09:04 PM
Low pressure / High pressure appliances Rick LP Gas, Piping, Tanks & Regulators 1 06-15-2002 06:29 PM
Tire Pressure thenewkid64 Tires 1 03-31-2002 01:44 PM
