Old 07-26-2003, 04:26 PM   #1
Send a message via Yahoo to daydreamer36535
Unhappy Uneven tire wear..Yikes!!
Hi all,
in preparation for a trip I was checking the tires out and have found
a problem i'm confused/concerned about.
see pic at http://www.gulftel.com/3strong/tire1.jpg
http://www.gulftel.com/3strong/tire.jpg
This is on a 1974 ambassador, 29'.
So, dual axle and the problem is on one side only.
I see no loose bolts ect.
also it seems this problem occured within the last 1000 miles as I just checked the tire pressure before coming home on the last trip.
As you look at the tire, there is deep wear for 2-3" then all is well
for about 6" - 16" then another deep wear pattern, all around the
tire. This occured on both tires. Its almost like the tire is trying to become square in spots.
What could be the cause?
thanks
Joe
Joe
daydreamer36535 is offline   Reply With Quote
Old 07-26-2003, 04:28 PM   #2
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Uuuhhh, are they...
...balanced?
Old 07-26-2003, 04:36 PM   #3
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Joe!
When I had abnomal wear similar to yours, it was caused by problems with the brakes on the streetside of my Overlander. The drums had worn to the point where the shoes were catching on ridges within the drum causing the brakes to lockup in a "chatter-like" maner both when stopping and starting. There was so much road construction where I was traveling that I attributed the braking shudder to the construction so wasn't terribly alarmed - - it was only after returning home that I discovered the damage to the nearly new Good Year Marathons. The solution on my coach was to replace all of the brakes with new fully loaded backing plates along with full machining of the brake drums and machining the shoes to match the drums. According to my mechanic, the trailer tires would drag from 3' to 5' each time I started or stopped which resulted in the spotty wear along with the fact that the pulsing action created as the shoes caught on the drums also caused periodic locking of the wheels when using the brakes to slow as well. On my coach, the damage occurred during the last 500 miles of a much longer Caravan.
Good luck in locating your tire wear gremlin!
Kevin
Kevin D. Allen
AIR #827
Old 07-26-2003, 05:16 PM   #4
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I'd guess inflation/balance or the rig sitting for too long in one spot underinflated.
Old 07-26-2003, 07:51 PM   #5
1987 29' Sovereign
Sparta , Tennessee
Send a message via Yahoo to wingfoot321
Have never had this on a trailer. Have had it on front tires on cars and trucks. Usually indicates a problem with tow-in or alignment.
Any chance that you hit something hard enough (pothole or curb) to knock one side out of alignment.
wingfoot321 is offline   Reply With Quote
Old 08-03-2003, 12:13 PM   #6
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
A tire subject
The last time I saw tire wear like this, was on the back of a front wheel drive car.
It turned out the rear shocks were worn out, and were letting the tire bounce a little as it went down the road. After a few thousand miles, the tires wore to the point where they were hopping up and down, and, of course, making the wear that much worse.
The "bounce test" that we do with automoblies, will not work on these trailers. As far as I know, the only way to check the shocks, are to remove them, and see how easy it is to extend and compress them. Also check for oil leaking out of the innards of the offending shock(s). Anybody with an easier way to check these, please, jump in and say something.
Something else to check is if you wheel bearings are too loose, that will cause a wierd wear pattern, also, although usually on the inside edge of the tire, not all the way across.
(in Florida)
Old 08-03-2003, 03:05 PM   #7
Unhappy uneven tire wear update
Well,
It turned out to be worn out axles.
warped front to back.
Gonna repalace the whole thing x 2.. bearings hubs brakes ect.
also 4 new shockes while the things are down.
Thanks to all,
Joe
Joe
Old 08-03-2003, 09:54 PM   #8
1987 29' Sovereign
Sparta , Tennessee
Did you get anymore detail explanation? What causes this to happen? Do you know if it is a fairly common occurence? How do you check for warped axles ? It seems like some event should precipitate the warping of both axles.
Old 08-04-2003, 04:21 AM   #9
Scalloping, as it is called, usually happens from a number of things.
Lack of or improper running gear balance (tire, wheel, hub and drum as an assembly).
Bad shocks.
Improper alignment.
The rubber rods in the axle have become defective.
Improper inflation.
The more of these things that are wrong, bad, or incorrect, the worse the scalloping.
It can happen on one tire, or all of them.
Old 08-07-2003, 03:18 PM   #10
DPeakMD's Avatar
1975 23' Safari
1978 31' Excella 500
Franklin , Indiana
Send a message via Yahoo to DPeakMD
Those pictures make it look like it's definitely an axle problem. I would suspect improper toe-in or toe-out. If the wear is on the outside of your tire it's toe-in.
The correction for this is to measure the amount of toe misalignment and then basically 'bend' the axle back into alignment. There is a list of places which will provide this service accessible from the Airstream website as a download. Of course, you could also be ready for new axles for other reasons and this would correct it, too, since that's set at the factory.
Make sure you and everybody who works on the trailer is aware not to use the axles as a jacking point. This is a serious 'no-no'. You're probably already aware of this, but there are many who are not, and this may have been done by a prior owner.
I'd make sure your replacement shocks are for the Airstream. They're made by Monroe, but are a specialty item because of the horizontal mounting and a special way they have to be sealed.
Good luck!
Dallas Peak, MD 'That 70's Guy!'
VAC 1VP President
WBCCI/VAC #8481
AIR #9
W9CDC
DPeakMD is offline   Reply With Quote
Old 08-08-2003, 09:34 AM   #11
Shocks
The "horizontal shock" as used by Airstream is made by Gabriel, which is stamped into the shock body.
Old 06-15-2004, 08:06 PM   #12
gklott's Avatar
2004 30' Classic
Johnson City , Texas
Images: 53
Having to replace front curb tire with almost exact condition. Goodyear Marathon less than 1 year old. Apepars to be brake lockup damage. Working now to fix brake.
Cost $161 with mounting, balance,...
Sure caused lots of bad vibrations - noticed when lower door hinge pin always climbed out while traveling.
73/gus
Gus - KR4K : Mary - K5MCL
2004 30ft. Classic
2003 GMC Sierra 2500HD CrewCab/Shortbed diesel
Hensley/Prodigy
gklott is offline   Reply With Quote
Old 07-08-2007, 08:07 PM   #13
Razorback
razorback's Avatar
2005 30' Classic
Springdale , Arkansas
This same thing happened to me today! I checked the tire pressure and lug nut torque on our 2005 Classic this morning before leaving. After traveling 426 miles, after I parked, I noticed one part of the tread on the Marathon worn all the way slick. After checking the lug torque (which all were fine) and the tire pressure (same as when I left this morning) I replaced the tire with the spare. After inspecting the tire it has severe wear for about 8", then normal tread until the opposite side where again there is the same 8" wear pattern. It is on both the inside and outside tread, leaving a faint tread pattern between the slick spots. The wear spots are exactly opposite on the tire. The tire affected is the front curbside tire. Could this be brake or axle problems? While driving I didn't noticed any braking shudder or anything that would indicate a problem. I thought I would replace the tire tomorrow and have them check the wheel to see if it is bent. If the wheel isn't the problem, I guess I'm looking a trip to the Jackson Center.
Razorback
Sid and Becky
2005 Classic 30 "Twinkie II"
Hensley Arrow
2008 Bighorn 4X4 Dodge 2500 Cummins
WBCCI Member At Large #2786
Life is not a dress rehearsal, live your dreams!
razorback is offline   Reply With Quote
Old 07-08-2007, 10:27 PM   #14
Balance, balance, balance.
The reason your tires are wearing uneven, is lack of proper running gear balance. That wear can happen very quickly.
Not just the tire and wheel, but the complete assembly that rotates, must be balanced.
Wheel mounting stud ruined, Where to find replacement? Land Yacht Deb Wheels, Hubs & Bearings 3 09-06-2003 02:25 PM
Spare Tire Carrier Pahaska Our Community 8 08-27-2003 09:00 AM
Flat tire... Craig Tires 10 07-11-2003 12:49 PM
Un-even tire wear Deputych Tires 5 05-15-2003 12:23 PM
Z71 or Z85? River Rat Tow Vehicles 7 05-09-2003 04:40 PM
