Old 01-08-2015, 09:07 AM   #41
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
that would work but, I've found...
there's always piers holding sign or speakers
and
they're always on a raised platform and a tilted trailer will throw off the readings
A family of eight, blogging all things camping from our Airstream
https://boondockdad.com/
boondockdad is offline   Reply With Quote
Old 01-08-2015, 09:11 AM   #42
dznf0g's Avatar
Oswego , Illinois
and
Hmmm, I've only weighed once side to side, but the CAT scale I went to had plenty of clearance. IIRC, there was about 2.5 - 3' of shoulder outside the the scale pads and plenty of clearance to the piers. You just need the AS tires barely off the pad. All of the truck tires were on the pad. Check for other sites. I suppose (in your pic, you might have to back up and crank the wheel to drive off, but I didn't.
-Rich-
Old 01-08-2015, 09:17 AM   #43
Dearborn , Michigan
Images: 21
I'd like to get some independent street/curb side weights, particularly because of our S/O configuration
I saw a frame that was configured for a 30' Slide once at J/C
and the bracing up front didn't look symmetrical to me.
At any rate, tires all around appear to wear evenly (I don't rotate them), it tows true, and brakes in straight line, so I don't worry too much about it
Old 01-08-2015, 09:47 AM   #44
dznf0g's Avatar
Oswego , Illinois
Name:	30 frame 2.jpg
That's true. Plus the weight of the slide itself. You would assume they would hav offset that with other appointments on the other side, but......?
-Rich-
Old 01-08-2015, 09:52 AM   #45
Dearborn , Michigan
Images: 21
Nice.
Look how beefy that is.
Thanks for posting
Old 01-08-2015, 10:25 AM   #46
Vintage Kin
Fort Worth , Texas
Cat Scales differ. Similar but not identical. Ground level and raised, etc. One has to work with what is available. Or go on to the next one.
Old 01-08-2015, 10:37 AM   #47
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
and
Or upgrade the tow vehicle for this type of scale.
>>>>>>>>>>>>Action
Name:	My next TV.jpg
Uneven tire wear Lumatic Tires 7 07-19-2012 09:08 AM
WD bars uneven load - equalizer hitch flmgrip Hitches, Couplers & Balls 16 05-25-2010 08:06 AM
Uneven (rutted) road surface dkottum Hitches, Couplers & Balls 6 11-11-2009 08:18 PM
uneven tire wear 64globetrot Axles 4 09-13-2009 02:01 PM
Uneven tire wear..Yikes!! daydreamer36535 Tires 18 07-09-2007 10:17 AM
