Old 05-14-2003, 07:19 AM   #1
Un-even tire wear
I have 2001, 27ft Safari and the front tire on one side is wearing unevenly. Can the axels be realigned. I check the tire pressure ofen when travelling so I don't think that has a bearing on my problem. I would appreciate any thoughts that you would have on my problem.
RM
Deputych is offline   Reply With Quote
Old 05-14-2003, 08:42 AM   #2
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
Are they the same size and brand (not all tires are exactly the same size as listed) on all four wheels?
Measure from a common center point at the front to a common point on all axles and make sure the distance is the same. On my little single axle trailer I noticed it dog leging on me and I found that one of the springs was put on backwards. The centering pin was about 1/2 inch off center. Flipped the spring around and it tracked properly.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 05-14-2003, 11:49 AM   #3
LLB21's Avatar
Check with the Airstream factory. There are service centers that are able to align your axels. I'm sure you will find one in your general area.
Louie
LLB21 is offline   Reply With Quote
Old 05-14-2003, 06:02 PM   #4
Out of alignment and/or lack of proper tire wheel hub and drum balance, can cause the problem.
inlandrv.com
Old 05-14-2003, 08:13 PM   #5
JPAIRSTREAM's Avatar
1972 31' Sovereign
, Ohio
Images: 47
Here is a link to Airstreams FAQ page with a pdf of there Alignment shops ------>PDF FORM
JP
JPAIRSTREAM is offline   Reply With Quote
Old 05-15-2003, 12:23 PM   #6
I HAVE RAN INTO THE SAME PROBLEMS WITH TIRES, THE SOLUTION IS TO TAKE IT TO THE AIRSTREAM FACTORY AND HAVE IT ALIGNED, THAT IS THE ONLY AIRSTREAM ALIGNMENT PLACE I KNOW OF THAT HAS THE EQUIPTMENT TO CORRECTLY ACCOMPLISHED THE TASK, PLUS THE FACTORY MECHANICS KNOW WHAT THEY ARE DOING
jimwatkins is offline   Reply With Quote
anyone: 10-ply "E" 7-15 Del-Net tire??? jmeredith Tires 13 07-09-2009 06:31 PM
Uneven tire wear..Yikes!! daydreamer36535 Tires 18 07-09-2007 10:17 AM
Wheel mounting stud ruined, Where to find replacement? Land Yacht Deb Wheels, Hubs & Bearings 3 09-06-2003 02:25 PM
Flat tire... Craig Tires 10 07-11-2003 12:49 PM
Z71 or Z85? River Rat Tow Vehicles 7 05-09-2003 04:40 PM
