Old 07-09-2005, 12:25 PM   #1
1970 25' Caravanner
Pasco , Washington
Type of Tires for Trailer
We have a 25 foot 1970 airstream trailer. Looking to put new tires on it. We have gotten different advice from people as to what type to put on. Some say 8 ply and the others say 6 ply due to the rims might split with the 8 ply. The rims that are on the trailer right now are not split rims. Can anyone help clear this mess up my trailer needs new tires!
Liz
Pasco WA
bubba99301 is offline   Reply With Quote
Old 07-09-2005, 12:52 PM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Liz!
Welcome to the Forums!
Liz
Pasco WA
There are several issues to be considered when choosing tires for your coach. One of the often stated caveats is to avoid changing from a Load Range C to a Load Range D tire unless the rims are also replaced -- the caution has been that change to the higher Load Range tires can cause issues with the existing rim(s). I know that the first time I replaced the tires on my Overlander, I asked my GoodYear dealer to order new trailer rated rims with 2,600 pound capacity as a means of insuring that I had the correct rims as well as providing a good time to switch to Load Range D tires. Basically, I went into my GoodYear dealer and asked that he measure the clearances on the coach as well as the wheels and order the correct tires and wheels; this procedure meant that if either posed a problem with fit when they arrived his personnel made the mistake in measuring and not me. The following are probably the most critical considerations when purchasing new tires for your coach:
  • Be certain that the intended tire carries an ST rating (Special Trailer).
  • Be certain that the tires selected have the capacity to handle the loaded Gross Weight of your coach.
  • If you are upgrading from a Load Range C to a Load Range D tire, new rims would insure against potential problems with the old rims.
  • Be sure that your dealer includes steel valve stems with your new tires -- rubber stems are marginal at best for the typical inflation pressures required for ST tires.
  • If your dealer must special order either tires or wheels, allow his/her personnel to do the measuring so the proper fitting of the tires/wheels becomes their responsibility.
  • If you have any reason to be suspicious of your dealer, you may want to check the manufacture date of the tires -- there are threads on the Forums with directions for doing this -- I have been doing business with my tire retailer for more than 30 years so haven't felt the need to check this information on the tires that I have purchased.
Good luck with your research!
Kevin
Kevin D. Allen
AIR #827
Old 07-09-2005, 02:19 PM   #3
1970 25' Caravanner
Pasco , Washington
Thanks so much for your help I will pass this info on to my husband. We need tires bad, we just bought this trailer last week and it was a blessing we got it home! It had sat parked for about 14 years. It sits in my driveway as my husband's project and I want to get it going and go camping!
Liz
Old 07-10-2005, 06:58 PM   #4
USN/LAPD Retired
Safari-Rick's Avatar
North Las Vegas , United States
Question
One place that you can check on type of tires is "Tire Rack" here's the web address: http://tirerack.com
You'll see that they are mostly truck and car tires but contact them and they will recommend the best and most affortable tires for our rig.
They have super prices and will answer any and all questions!
Take care,
Rick P
2007 Dodge Ram Quadcab 6.7L Diesel w/jakebrake
"Better to have more then you need, then need more then you have because you don't have enough!"
AIR #: 8129
Safari-Rick is offline   Reply With Quote
Old 09-02-2005, 03:25 PM   #5
1986 34' Limited
Prospect , Tennessee
Which Goodyear Marathon ST's
I just bought a 1986 Limited with three axles. The tires are old, bias belted and say they are 700-15's. I plan to replace then with the Goodyear Marathon Radials and it was suggested to me by a tire man that the 225/75/15's (D) rated are the closest match. Does anyone know for sure?
Lee Davis
Originally Posted by overlander64
Greetings Liz!
Kevin
Lee Davis is offline   Reply With Quote
Old 09-02-2005, 04:46 PM   #6
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Lee Davis
Lee, ST225/75R15D Marathon tires would be fine for your coach. It will also be fine for the Tradewind in the first post in this thread. The issue with rims splitting is not entirely accurate. If you have load range C tires, and you put load range D tires on them, and inflate the D rated tires to their maximum pressurre, you run the risk of the wheel assembly catastrophically coming apart. This is not a "split rim" issue, it is something different entirely.
Old 09-02-2005, 04:47 PM   #7
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
I just bought new tires yesterday from tire rack. They were $ 78.00 each plus shipping for Marathons in the load range D. They also have load range C available, for a few $ less.
I also just bought new alloy wheels from www.trailertiresandwheels.net, and am very pleased with the quality.
Uwe
www.area63productions.com
Old 09-02-2005, 04:49 PM   #8
Well Preserved
1993 21' Sovereign
$78 is not a bad price. I would get the D rated tires, the difference in price is not enough to warrant the lower rated tires. If your coach is supposed to have C rated tires, you can inflate the D rated tires to 50PSI, which should be the C load range maximum pressure. It won't hurt a thing.
Old 09-02-2005, 07:21 PM   #9
1987 29' Sovereign
Sparta , Tennessee
Send a message via Yahoo to wingfoot321
Lee,
Your are dead on with the ST225/75R15 D Load Range. My friend has a 92 34' coach and he uses this same tire and runs at 55psi on air. This is 10psi lower than Goodyear's spec. but, he figures he gets a little softer ride and less movement of things inside the trailer. Only trade off is a little bit of premature edge wear. He still gets enough miles that the tires age out rather than wear out.
The lower pressure would be good for your old rims.
The st225/75r15 is slightly smaller than an old 700-15 but, less than 1/2 inch on diameter.
Two tires will be 2540lbs x 2 = 5080 per axle (plenty of safety factor)
The axle should be 3400 or 3600 lbs weight rating.
The wheels should be checked. I think they will be 2600lbs. Should be stamped on the wheel.
wingfoot321 is offline   Reply With Quote
Old 09-02-2005, 08:36 PM   #10
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
I am usually not much of an online shopper, like to put my eyes and hands on things before plunking down the cash, but every tire store in town was better than $ 100.00 per tire. I mentioned that I'd rather buy local, and quoted the tire rack price, with shipping, but none of them were interested in my business.
I will mount and balance the tires next week, can't wait to see them on the old 63...
The new wheels are super light weight, with hardened inserts for the lugs, and are rated at 2830lbs. I had very goodluck with Marathions on alloy wheels on my previous trailer, a 1971 Tradewind.
Uwe
Old 09-03-2005, 04:48 AM   #11
Well Preserved
1993 21' Sovereign
If you were closer, I would be happy to negotiate a deal with you, based on Tire Rack's price. We have Marathons on our 63 Overlander, and are very satisfied with them.
LT versus ST tires on a trailer 76Argosy Tires 18 08-29-2014 04:03 PM
need advice re. 1969 tires, brakes, etc. Dave Cole Tires 6 01-29-2007 06:04 AM
61 Tradewind tires lee_jachter Tires 11 10-04-2002 12:00 PM
New tires for my 1956 Bubble.... kzener40 Tires 8 07-27-2002 12:41 PM
Best wheels & Tires... Andy R Wheels, Hubs & Bearings 4 04-15-2002 10:41 AM
