Old 06-30-2016, 02:14 PM   #15
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
I have found that a jack that will not hold a load is directly dependent on the quality of the jack. I have seen several jack made from Chinesium that wouldn't hold a load. Usually a hydraulic jack will not pump up any higher if it is overloaded. In your case the fluid is seeping past the valve.
Your jack is on the light side but should do the job. I typically use a 5 ton bottle jack (domestically manufactured).
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 06-30-2016, 02:18 PM   #16
StreaminGeo's Avatar
2004 25' Safari
Hanford , California
I think that temporarily I'll go with the Camco 21 Yellow Trailer Aid ramp, but I'll check all of the other suggestions for possible future use.
Thanks for the suggestions, everybody!
StreaminGeo is offline   Reply With Quote
Old 06-30-2016, 02:22 PM   #17
Ayr , Ontario
Originally Posted by Gneiss Guy View Post
Agree with twinkie. To change one tire on a tandem trailer, why use a jack at all? Just pull the other tire on that side onto a few blocks and the "bad" tire will be off the ground. As long as you have chocked the tires on the opposite side, there is little chance of the trailer falling. It's just a safer way to do the job.
Don't forget to loosen the nuts before you get the tire in the air. When my tire failed in Iowa and I had no jack I just pulled the unit onto a curb in an abandoned parking lot.
gator.bigfoot is online now   Reply With Quote
Old 06-30-2016, 03:08 PM   #18
1975 Argosy 22
Eugene , Oregon
If you have a tandem axle trailer get one of these:
Andersen Manufacturing 3620 Rapid Jack
A description From the Amazon web site.
"The Rapid Jack is your best friend when it comes to fixing a flat tire or removing a wheel on your multi-axle trailer or dually truck. Simply place the small end of the Rapid Jack under the closest good tire and drive up! NOTHING COULD BE EASIER! It can also be used as a jack wheel holder, a jack post block, and a pad block (see pics). Doubles as a wheel chock."
Works great, is light and easy to use.
https://www.amazon.com/Andersen-Manu...derson+leveler
mrdfred is offline   Reply With Quote
Old 06-30-2016, 04:23 PM   #19
1993 25' Excella
CLeveland , Ohio
Originally Posted by VT Wanderer View Post
I have 2 axels on my 27 ft. FC. I have only had one flat - spike thru the tire. Used my Camco 21 Yellow Trailer Aid (ramp) - simple and easy. Don't even think of a jack - too many issues that could be dangerous for you and/or the trailer.
I agree. Spend the 30 bucks and never worry about a jack slipping again. I bought one last year thinking I would be wasting money and I was wrong. Tire changing is safe, easy and fast.
Here is one place to look at it:
https://www.amazon.com/Trailer-Aid-T.../dp/B000I4JPZE
Akronguy is offline   Reply With Quote
Old 06-30-2016, 07:42 PM   #20
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Maybe they should have been rotated?..
Old 07-02-2016, 06:17 PM   #21
2004 25' Safari
One last question. (?) I got the tire changing ramp. How long can I leave a trailer up on such a ramp? Can I take a tire off and have it replaced (might take all day) with the trailer on the ramp or should I put the spare on and back it down until the new tire can be put on?
Old 07-02-2016, 07:00 PM   #22
CRH
1995 25' Excella
xxxxx , xxxxxx
It will be fine sitting on one wheel.
CRH is offline   Reply With Quote
Old 07-02-2016, 07:27 PM   #23
2004 25' Safari
Thank you!
Old 07-02-2016, 09:55 PM   #24
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
If you decide to stay with ST tires, which I along with many other AS owners advise you change to LT tires, you might consider a set of Centramatics, which balances tire and drums automatically as driven. There are many threads on the tire subject and many converts to LT tires due to premature ST failures, some with huge damages to their AS from the ST tire blowing out and damaging wheel wells, body parts and black/grey valves destroyed.
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 07-03-2016, 07:54 AM   #25
2004 25' Safari
Okay pappy, I'll take that into consideration. Thank you!
Old 07-04-2016, 06:57 AM   #26
1967 26' Overlander
Spartanburg , South Carolina
Originally Posted by Jacob D View Post
A question comes to mind. Why would one tire wear out? I can only think of a few reasons, axle bent, axles out of alignment in which case you would think two tires would wear out, a defective tire, mis-matched tires or maybe something else I haven't thought of. Is it time to replace all 4? If they are older than 6 or 7 years the answer is probably yes.
Regarding your other question, my rule of thumb is carry a bottle jack with capacity equal to your trailer weight and wooden blocks to augment the height if the screw out part isn't long enough plus one to put next to the trailer unless A/S provided a jack point.
Correction: I meant to say twice your trailer weight.
Jacob D is offline   Reply With Quote
Old 07-04-2016, 07:33 AM   #27
2004 25' Safari
Okay, thank you.
Old 07-05-2016, 04:29 PM   #28
2004 25' Safari
I just wanted to let everyone know that the tire changing ramp worked great! Very easy!
Thanks for all of the input!
Two tire questions. Hans627 Tires 36 03-12-2015 06:34 PM
Did changing to two 6 volt Batts. affect ride grizbear Towing, Tow Vehicles & Hitches 5 02-26-2015 11:24 AM
Two 12V vs. two six volt batteries spat61 Land Yacht/Legacy Motorhomes 37 04-22-2010 11:50 PM
Two plus two cello The Pet Forum 1 09-26-2006 02:00 PM
Two 6 volts or Two 12V series 27 LI Pets Electrical - Systems, Generators, Batteries & Solar 0 09-07-2006 06:06 PM
