Old 08-08-2014, 07:57 PM   #1
SilverEagle6's Avatar
2013 25' Flying Cloud
2008 30' Classic
On The Road To Wherever We End Up , Traveling the USA
Tst tpms
I've had this system on my trailer for almost three months and had no issues. Just checked tire pressure with a good gauge and have 63psi in all four by the gauge. The TPMSIve reads 68psi in all four. I did not reset parameters, tires cold, no sun. Should I just take note of the difference and drive on or is something up? Next leg is 190 miles.
Jeanne and John, and always with us...Jake
2008 30' Classic Ltd Rear twin, 2014 Ford Super Duty
WBCCI 3100, unit 12, TAC USA-1, Escapees 129379
https://instagram.com/silvereagle3100/
SilverEagle6 is offline   Reply With Quote
Old 08-08-2014, 07:58 PM   #2
Tincampers's Avatar
Sneedville , Tennessee
Did you have to install metal valve stems with this system?
Tincampers is offline   Reply With Quote
Old 08-08-2014, 08:02 PM   #3
2008 30' Classic
I did not
Old 08-08-2014, 08:22 PM   #4
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
I have the TST 507 external sensors on my trailer, and I find the pressure reading varies a few pounds. It seems random (different tires are higher/lower on different days). They do seem pretty good about showing pressure increases as the tires heat up, so I don't worry about the variation.
However, I don't think I have ever had the readings be off by as much as five pounds.
SSquared is offline   Reply With Quote
Old 08-08-2014, 09:21 PM   #5
2008 30' Classic
Went back to recheck the reading of the TPMS and found that the temperature reading is five degrees lower then the temperature reading on three other readings, mine, my neighbors, and my cars OAT gauge. Today's temp has pretty much reminded the same, with no sun and fairly cool. So now I have higher pressure reading and lower temperature reading on the TPMS. Any thoughts?
Old 08-08-2014, 09:35 PM   #6
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I have had some variations. I moved sensors and carefully tracked the tires move to... 2-3 psi variation max. Between all 6 sensors the variance is usually a spread of 3 psi.
They do not match the electronic tire gauge. Rather, they read a little higher.
What they do is give you feedback. They are "close" enough. They warn of issue quickly... And they help monitor real ops.
Happy to have them!
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-09-2014, 06:22 AM   #7
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Internal or external?
There's a lot of variance between gauges. The only thing is worry about is where you've set the alarm parameters. If you're loading at 65 cold, you might set the high pressure alarm for 80 (about 15% above cold). If the sensors think you're starting at 68, you're likely going to get to at least 75 (10% rise in normal use) so not much headroom before hitting the alarm.
Pretty minor thing to worry about :-)
SteveSueMac is online now   Reply With Quote
TPMS - Dill internal mount system wingfoot321 Tires 10 04-19-2016 08:39 AM
Voyager interferes with TST TPMS SteveSueMac Lights - Interior & Exterior 11 12-09-2014 08:03 AM
TST TPMS fit and repeater SteveSueMac Tires 6 08-17-2013 12:29 PM
Valve stems and TPMS cosmotini Wheels, Hubs & Bearings 8 08-06-2013 07:28 PM
Another TPMS... reday Tires 3 07-05-2009 04:53 PM
