05-30-2016, 01:16 PM
#121
2015 23' Flying Cloud
2023 Interstate 19
Scottsdale
I will go with the standard although Ti should be right.
Originally Posted by SSquared
I got TST 507s three years ago. The kit came with a bunch of ID stickers and some documentation on their numbering plan.
For a dual axle trailer, the front axle IDs are T1 for the left and T4 for the right, and the rear axle IDs are T5 for the left and T8 for the right.
05-30-2016, 02:15 PM
#122
2016 30' Classic
Lorton
, Virginia
Are there any internal TPMS trailer wheel sensor kits like those fitted on OEM vehicles?
You wouldn't have to worry about all this theft/metal valve stem nonsense.
05-30-2016, 07:21 PM
#123
2023 Interstate 19
Scottsdale
I think TST has some. We have made so many mods to the new AS we settled for the 507. We put Centramatics balancers on the wheels so will hold off on metal stems for a while.
05-31-2016, 06:28 AM
#124
Biloxi
, Mississippi
Cost of metal stems, install and rebalance with sensors attached was less than $30. Theft? I have never heard of this happening. Anyone?
MICHAEL
05-31-2016, 06:33 AM
#125
2012 25' FB Eddie Bauer
Southwestern Ontario
, Ontario Canada
Yes we have the Dill Trailer TPMS and it works well like the factory sensors on most cars. FYI We use the included antenna extension to place the antenna near the rear of the TV. We tow a 25E.
06-05-2016, 02:46 PM
#126
2023 Interstate 19
Scottsdale
I set up my TST 507 for the 4 TT tires and the monitor still shows the right front TV tire. Is that normal?
06-05-2016, 06:02 PM
#127
2016 26' Flying Cloud
London
, Ontario
I doubt it. On my TST System....the Rep set up the 4 TT wheels as RF RR LF LR and I added a sensor for the spare tire which was positioned to show up as point on the tow vehicle. So I have a small box with one sensor showing up and a larger box behind it with 4 displays showing up. Info alternates from one location to the next and keeps rotating as you go down the road. Pm sent.
You're a long time underground!
06-05-2016, 10:51 PM
#128
1975 31' Romany
Kansas City
, Missouri
I did the exact same thing and it took me a while to figure out how to delete the front tire. You can either go into program mode and enter all ffffff"s manually or you can figure out which code is a duplicate by resetting all the sensors and it will erase it
06-06-2016, 06:03 AM
#129
2023 Interstate 19
Scottsdale
How do you reset all the sensors?
06-06-2016, 12:40 PM
#130
1975 31' Romany
Kansas City
, Missouri
I just put the sensors under the head unit like you set them the first time. Put them in a different order and they will be relearned. It took me a long time to figure out how to erase the right front wheel. I assume I started programming when that wheel was flashing.
06-07-2016, 01:57 PM
#131
2013 30' Flying Cloud
2011 25' FB Flying Cloud
reno
, Nevada
This is normal. It is used to test the monitors at the factor. If you want to delete this, follow the instructions below.
Press and hold the Code button
Use the + button to move to the tire to be deleted
Press and hold the Set button till it beeps
This should delete the unwanted tire
06-07-2016, 04:02 PM
#132
1989 32' Excella
Cumming
, Georgia
How to delete a position
Press and Hold the "CODE" button until it beeps.
USE THE + and - keys to move to the position that you want to delete.
Press and hold set until it beeps and that position will return to all FFF's
Let me know if you need any more help.
06-07-2016, 04:48 PM
#133
Tavares
Pretty happy with my TST 507s.
I put them on the wheels, retrofitted with metal stems. They come online relatively quickly (5 +\- 1 min) on all four wheels.
One question ya'll might know: on a typical day, three of my sensors will show one reading (say 55 psi) but one will persistently show 2-3 psi lower (say 52 psi). I've confirmed it is the sensor, not the tire, by moving it to another tire.
Do you guys see this as normal variation? Looking at the Truck Systems web sight, it seems I recall the sensor accuracy being somewhat less than that variation.
Your thoughts?
Rich
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.” - J.C. Watts Jr.
06-07-2016, 06:06 PM
#134
2015 30' Classic
Sherwood
, Oregon
Yup, that is the instruction that I got when I called TST. They test the unit at the factory by setting up the off-driver side tire. We have two trips with the TST and love it. When I said we have an AS they shipped our unit with the antenna extension but we have not needed it.
2015 Classic 30A, Blue OX Sway Pro, 2016 F350 4x4 Ultimate Lariat crew cab SRW, LWB, 6.7 PSD, 20" wheels, Ingot Silver Metallic, DiamondBack tonneau cover, TrailFX wheel-to-wheel step bars.
Sold: 2014 25FB International Serenity
06-07-2016, 06:10 PM
#135
2012 30' Classic
Wildwood
, Missouri
Just bought and installed these sensors after visiting Alumapalooza and meeting with a rep. I called the company and Debbie was so kind to walk me through the process of setting up the system - with her help it was a piece of cake. This weekend will be the first weekend out with new tires and the new sensors.
06-08-2016, 05:01 AM
#136
2023 Interstate 19
Scottsdale
TST Tire Pressure Monitoring System
The manual says plus 20 % and minus 10%. Is that what very one is using for the Marathon 14" tires?
06-08-2016, 05:07 AM
#137
2023 Interstate 19
Scottsdale
Many thanks!
06-09-2016, 02:23 PM
#138
Master of Universe
2008 25' Safari FB SE
Grand Junction
The TST sensors come with an allen screw serving as a lock for the stem. You use an allen wrench (provided) to tighten it. Unless someone has the same TST system and the allen wrench, why would anyone steal a sensor?
A 2 psi variation in the readings can be caused by sun on one tire, some variation in the tire making it run a little hotter or cooler, or slop in the sensor or monitor design. A 3 psi variation in hand held pressure gauges is pretty common (the kind with a metal thing that slides out under pressure is probably even less accurate). If you have 80 psi (LR E tire filled to capacity) 2 lbs is 2.5%, not bad for anything reading pressure that isn't too expensive. For a LR D tire at capacity (65 psi), 2 lbs. is 3%.
So far, after a bit more than a year, our TST system is working fine and seems to work better than the TPMS systems we have had before.
Gene
Gene
06-09-2016, 03:02 PM
#139
2023 Interstate 19
Scottsdale
One recommendation was set to plus 20 psi and minus 10 psi.
Still looking for some settings help.
06-09-2016, 06:46 PM
#140
2012 27' Flying Cloud
W
, New England
Here's the link to the manual online.
http://tsttruck.com/wp-content/uploa...ser-manual.pdf
Good luck!
