Old 03-17-2016, 11:46 AM   #113
2015 23' Flying Cloud
Livermore , California
So is it safe to use these jack points to change a tire?
cactusjk is offline   Reply With Quote
Old 03-18-2016, 08:04 AM   #114
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Yes, on page C-3 of my owners manual that is the approved and recommend lifting point for tire changing.
MICHAEL
Old 05-30-2016, 10:05 AM   #115
What High/Low Temp settings should I go with for a FC 23? Factory Defaults?
Old 05-30-2016, 10:35 AM   #116
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you are in fact questioning the temperature setting and not the pressure setting. If you are using the TST system the temperature setting is factory set at 158. That is the temperature that Michelin has suggested since tires will fail above 180 degrees they give that margin of safety. If you are using another system i would assume that recommendation would be advisable.
As far as pressure setting high would be 20 psi above cold pressure and low 10 psi below cold setting.
2004 Excursion 4x4
Old 05-30-2016, 10:38 AM   #117
Yes I have the TST 507. The trailer has Goodyear Marathon tires rated at 65 psi so I will use your high low recommendations. Thanks.
Old 05-30-2016, 10:57 AM   #118
Any recommendations on how to number/set up 4 TST 507 sensors for a dual axle TT?
Old 05-30-2016, 11:57 AM   #119
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
I got TST 507s three years ago. The kit came with a bunch of ID stickers and some documentation on their numbering plan.
For a dual axle trailer, the front axle IDs are T1 for the left and T4 for the right, and the rear axle IDs are T5 for the left and T8 for the right.
SSquared is offline   Reply With Quote
Old 05-30-2016, 12:21 PM   #120
HowieE's Avatar
Images: 12
If you are not comfortable with a left to right front to rear numerical system using the tags that came with the system consider getting a fine pointed permanent marker and marking each wheel per your idea.
Mine are 1 -10 front to rear.
2004 Excursion 4x4
Old 05-30-2016, 02:16 PM   #121
I will go with the standard although Ti should be right.
Old 05-30-2016, 03:15 PM   #122
2016 30' Classic
Lorton , Virginia
Are there any internal TPMS trailer wheel sensor kits like those fitted on OEM vehicles?
You wouldn't have to worry about all this theft/metal valve stem nonsense.
Zybane is offline   Reply With Quote
Old 05-30-2016, 08:21 PM   #123
I think TST has some. We have made so many mods to the new AS we settled for the 507. We put Centramatics balancers on the wheels so will hold off on metal stems for a while.
Old 05-31-2016, 07:28 AM   #124
AWCHIEF's Avatar
Images: 33
Cost of metal stems, install and rebalance with sensors attached was less than $30. Theft? I have never heard of this happening. Anyone?
MICHAEL
Old 05-31-2016, 07:33 AM   #125
TRIPPPIN's Avatar
2012 25' FB Eddie Bauer
Southwestern Ontario , Ontario
Send a message via AIM to TRIPPPIN Send a message via MSN to TRIPPPIN Send a message via Yahoo to TRIPPPIN
Yes we have the Dill Trailer TPMS and it works well like the factory sensors on most cars. FYI We use the included antenna extension to place the antenna near the rear of the TV. We tow a 25E.
TRIPPPIN is offline   Reply With Quote
Old 06-05-2016, 03:46 PM   #126
I set up my TST 507 for the 4 TT tires and the monitor still shows the right front TV tire. Is that normal?
Tire Pressure Monitoring System Kimball Wheels, Hubs & Bearings 25 05-29-2016 08:59 PM
Dill Tire Pressure Monitoring System wingfoot321 Tires 3 12-14-2011 08:03 PM
Tire Pressure Monitoring system chirocruzr General Motorhome Topics 10 04-17-2009 10:08 AM
Canadian Tire's $129 Tire Pressure Monitoring System SilverCottage Tires 9 10-30-2007 08:55 PM
PressurePro Tire Pressure Monitoring System 68 Overlander Commercial Listings 21 09-21-2007 04:49 PM
