Old 03-15-2016, 09:12 AM   #99
TRIPPPIN's Avatar
2012 25' FB Eddie Bauer
Southwestern Ontario , Ontario
Send a message via AIM to TRIPPPIN Send a message via MSN to TRIPPPIN Send a message via Yahoo to TRIPPPIN
Go for the Dill internal Tpms. They have the correct length and work great.
TRIPPPIN is offline   Reply With Quote
Old 03-15-2016, 09:56 AM   #100
2016 30' Classic
Erie , Colorado
TST has both internal and external sensors. If you go externals I use the non flow thru type. Shorter than the flow thru's and easy to remove. They don't stick out as far.
And yes, get the tires dynamically balanced. When I got my Classic I went to Discount Tire. Replaced all of the rubber stems, replaced all of the lug nuts with solid nuts and had a balance down with the sensors installed. Under $100 for everything.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 03-15-2016, 10:00 AM   #101
2015 23' Flying Cloud
Livermore , California
How did Discount Tire jack up the AS to remove the wheels?
cactusjk is offline   Reply With Quote
Old 03-15-2016, 10:06 AM   #102
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
Like this.
kscherzi is offline   Reply With Quote
Old 03-15-2016, 11:11 AM   #103
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
We got the TST with internal sensors installed with our Michelins so did all at once, including dynamic balancing at the tire shop.
Old 03-16-2016, 05:57 AM   #104
2007 28' Classic
Ivanhoe , Virginia
Not sure what all the worry about balance is about, I just put the tst's on the metal valve stems and went with it. Trailer seems to ride smoothly, everything stays in place, no sign of uneven tire wear. This on s different Rv's, same Tv.
senioryakker is offline   Reply With Quote
Old 03-16-2016, 07:54 AM   #105
Bandits's Avatar
2008 30' Classic
This picture illustrates the wrong way to lift an Airstream. Dexter Axle, the manufacturer of the axles that Airstream uses, specifically states not to lift the trailers in this way.
Bandits is offline   Reply With Quote
Old 03-16-2016, 08:09 AM   #106
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
To me it looks like the jacks are directly under the axle mounting bracket if you blow up the picture. It is acceptable to place a jack or jack stand in this spot.
Do not place the jack directly under the axle tube.
My trailer is left on jack stands all winter with the stands just under axle bracket.
Steve, Christy, Anna and Scout (Border Collie deceased 11-30-2016)
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 03-16-2016, 08:17 AM   #107
1975 31' Romany
Kansas City , Missouri
What is the correct lifting point on the trailer?
kosullivan is offline   Reply With Quote
Old 03-16-2016, 08:57 AM   #108
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Mine are aft and slightly inboard from the rear axle. They are marked with a small attached patch,
MICHAEL
AWCHIEF is online now   Reply With Quote
Old 03-16-2016, 09:14 AM   #109
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Western WA , Washington
This is one truly annoying thing about Airstream trailers. If the jack point is so critical, why don't they mark the doggone thing with a big yellow sticker and a "Jack here" sign so nobody does it wrong? Seriously, this is something about which there should be zero mystique.
Rocinante is our 2014 International Signature 27FB
Old 03-16-2016, 10:55 AM   #110
1998 30' Excella 1000
Livingston , Texas
My rig does have "jack here" labels on those jack points. And even have the owners manual instructions that highlight using them. I used them once to drop my tank covers. They put a huge amount of flex in the frame. Door could not even come close to closing. I now use the axle mounting plate as shown in the photo. In my opinion, much better for not stressing the frame.
Siegmann is offline   Reply With Quote
Old 03-16-2016, 10:59 AM   #111
Do the new (2015+) trailers still have the non solid lug nuts?
Old 03-17-2016, 08:50 AM   #112
AWCHIEF's Avatar
Images: 33
This is one truly annoying thing about Airstream trailers. If the jack point is so critical, why don't they mark the doggone thing with a big yellow sticker and a "Jack " sign so nobody does it wrong? Seriously, this is something about which there should be zero mystique.
Mine does, see previous post for picture of jacking point. Both sides have this little patch. One side still has the "Jack" sticker. It came of the other side somewhere down the road.
MICHAEL
Tire Pressure Monitoring System Kimball Wheels, Hubs & Bearings 25 05-29-2016 08:59 PM
Dill Tire Pressure Monitoring System wingfoot321 Tires 3 12-14-2011 08:03 PM
Tire Pressure Monitoring system chirocruzr General Motorhome Topics 10 04-17-2009 10:08 AM
Canadian Tire's $129 Tire Pressure Monitoring System SilverCottage Tires 9 10-30-2007 08:55 PM
PressurePro Tire Pressure Monitoring System 68 Overlander Commercial Listings 21 09-21-2007 04:49 PM
