Old 06-10-2016, 06:36 AM   #141
2015 23' Flying Cloud
Livermore , California
Thanks for the link. Interested to know if others go with the recommended 20% and 10% high/low settings?
cactusjk is offline   Reply With Quote
Old 06-10-2016, 06:38 AM   #142
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
You're welcome. I personally go with those recommendations. My tires want 50 PSI. My alarms are set for 60 and 45 on the high and low ends. I have the TST TPMS with internal sensors.
Old 06-10-2016, 06:45 AM   #143
Good to know. I know some base it on actual TT weight as measured on a truck scale but I prefer to take the easier approach for now.
Old 06-11-2016, 12:50 AM   #144
NWRVR's Avatar
2015 30' Classic
Sherwood , Oregon
Yes, I inflate to 65 and set the TST to 20% high and 10% low. I have the stem mounts.
2015 Classic 30A, Blue OX Sway Pro, 2016 F350 4x4 Ultimate Lariat crew cab SRW, LWB, 6.7 PSD, 20" wheels, Ingot Silver Metallic, DiamondBack tonneau cover, TrailFX wheel-to-wheel step bars.
Sold: 2014 25FB International Serenity
NWRVR is offline   Reply With Quote
Old 06-13-2016, 07:19 AM   #145
Airstreemer's Avatar
1989 32' Excella
Cumming , Georgia
Tst tpms
I recommend the cap sensors over the flow through because they are more durable and less likely to be damaged.
There are thousands of Airstreams using this system now with no problems
Airstreemer is offline   Reply With Quote
Old 06-13-2016, 07:22 AM   #146
1989 32' Excella
Cumming , Georgia
Those are reasonable settings.
It may depend on the ambient temperature of the area you are traveling i.e. Altitude, extreme heat or cold.
Good starting point though
Tire Pressure Monitoring System Kimball Wheels, Hubs & Bearings 25 05-29-2016 08:59 PM
Dill Tire Pressure Monitoring System wingfoot321 Tires 3 12-14-2011 08:03 PM
Tire Pressure Monitoring system chirocruzr General Motorhome Topics 10 04-17-2009 10:08 AM
Canadian Tire's $129 Tire Pressure Monitoring System SilverCottage Tires 9 10-30-2007 08:55 PM
PressurePro Tire Pressure Monitoring System 68 Overlander Commercial Listings 21 09-21-2007 04:49 PM
