Old 06-26-2012, 09:05 AM   #1
Cave Creek , Arizona
Question Trouble with Super Cargo tires?
Just returned from a long trip to Chicago from AZ, and in OK had a tire blowout. Because of original tires I had all 4 replaced with Super Cargo, ST225/75R15. The next day one immediately went flat and after two stops to have it checked had to replace it. I still have the tire, but do not know of any way to get my money back or warranty. Has anyone had trouble with and or experience with these tires? I talked to the place that sold them with no help since I could not return the tire.
jameswbruce1 is offline   Reply With Quote
Old 06-26-2012, 09:31 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Who are they made by? Using GOOGLE I found at least 6 different manufactures for a tire under that name.
MICHAEL
Old 06-27-2012, 10:14 AM   #3
Hi, thank you for your question. I have looked at the tire inside and out and other than Super Cargo radial tubeless Made in China there is no mfg. name. I should have been more careful when I had the tires put on.
Old 06-27-2012, 10:36 AM   #4
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Buy some GYM if you want to stick with ST tires. Buy some Michlein LT or Goodyear LT tires if you want failure free traveling. Going to generic ST tires to get away from GYM is like jumping into the fire from a slightly warm spot.
Old 06-27-2012, 10:51 AM   #5
richinny's Avatar
2011 34' Classic
there are code numbers stamped into the sidewall that indicate who made them.
Barry's Tire Tech
you may find it here:
All the D.O.T. Tire Plant Codes
Ricky
