Old 04-14-2017, 06:00 AM   #21
paiceman's Avatar
Upper St Clair, PA , PA-Summer/FL-Winter
Airstream does not buy these tires from Michelin, they buy them from a local tire dealer. I was in contact directly with Michelin two Airstreams back concerning my intended use of Michelins on one of our previous Airstreams. My email reply, from the VP of Marketing was short and sweet. "The Michelin Corporation does not manufacture a tire suitable for use on travel trailers and therefore your use of any Michelin tire on a travel trailer will void any and all warranties from The Michelin Corporation either written or implied".
I put Michelins on, I had Michelins on our next Airsteam and I use them on our 2017 Classic. If there is an issue I am counting on taking care of it ourselves.
SAFE TRAVELS
Bud
Starting to Look (AGAIN) Number 5 Hopefully
USAF Training Instructor (TI) - 68-72
Old 04-14-2017, 07:16 AM   #22
Obviously-NOT
james.mileur's Avatar
Kalispell , Montana
Better than BAT
Bud, thanks for being so descriptiveto help us understand the other club we joined when we bought the 17 Classic
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
james.mileur is offline   Reply With Quote
Old 04-14-2017, 07:53 AM   #23
CapriRacer
CapriRacer's Avatar
I'm in the , US
My experience says that tires should not be loaded to more than 85% of their rated load for the pressure used. The rated load for an LT225/75R16 LR E is 2680# @ 80 psi - 85% = 2278#. The weight report shows that the LR position is 2350# (107%), but the rest are nearly to that value. I wonder if there are situations where the trailer is loaded more heavily and that's why there was a failure. I also wonder how well the pressure was maintained.
CapriRacer is offline   Reply With Quote
Old 04-14-2017, 08:02 AM   #24
Gainesville , Florida
wasn't there a recall on mich tires a few years ago. perhaps these tires fell into that recall and were not replaced.
Old 04-14-2017, 08:53 AM   #25
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Yes, there was such a recall. I remember buying my tires and then hearing about it - checked dates and mine were not included. I forget the dates though. Probably have it all in my files!
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 04-14-2017, 10:37 AM   #26
Mollysdad's Avatar
Originally Posted by Tireman9 View Post
Be sure to file a complaint with NHTSA. This failure needs to be in their database.
What is one to report?
"A Michelin tire failed when I used it in a manner it was not designed for and Michelin recommended against."?
Mollysdad is online now   Reply With Quote
Old 04-14-2017, 10:37 AM   #27
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Subject tire is not a part of the recall I can find. Last date of manufacture for the recall was in 2012, this tire was 2013.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 04-14-2017, 10:55 AM   #28
2016 22' Sport
Clinton , Montana
I haven't seen any questions regarding what "speed" the OP was traveling when the tire failed? Did I miss something?
Rpatrick16 is offline   Reply With Quote
Old 04-14-2017, 12:04 PM   #29
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Is 80 psi necessary?
I am running 70 psi with Sendel T03 wheels, Firestone Transforce HT LT 225/75R16 tires, Centramatics, and Dill TPMS.
I am thinking the tires will hold 2,500# of weight at 70 psi.
My trailer weighs 8,800# on the trailer axles.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 04-14-2017, 12:32 PM   #30
AirMiles's Avatar
2018 27' Globetrotter
Apollo Beach , Florida
Is 80# Necessary?
I believe Capriracer, the tire engineer, answered this question above. He suggested to have a 15% safety factor or 2278# at 80 PSI. Here is the load table for Michelin tires so everyone can determine the load at different "minimum" pressures. http://www.rvtirepressure.com/assets..._inflation.pdf
Unless one has weighed each tire's load individually, the tires may not be carrying the average load, as was the case for the OP with the tread separation. I have yet to decide on a tire pressure for my 25FB, but am leaning toward max PSI.
P.S. I believe tire loads for a given tire size and classification ( LT, P, ST) are independent of manufacturer and can be used for any manufacturer. The above table is from Michelin for RV usage.
2018 Globetrotter 27Q, 32 nights 4,935 miles, 600W Solar, PD4655L, 6V Batteries, ProPride, 16" Michelin's, 2019 F250 PSD
Sold: 2017 Flying Cloud 25FB, 316 nights 40,150 miles, 400W Solar
Sold: 2013 Casita SD17 89 nights 16,200 miles
Solar Production: 213 kWh in 248 days of use
AirMiles is offline   Reply With Quote
Old 04-14-2017, 12:46 PM   #31
aftermath's Avatar
Spokane , Washington
Thank you for this post. This tells me everything I wish to know regarding Michelins. I wonder if the company is making this statement widely known when they sell their tires to trailer owners.
aftermath is offline   Reply With Quote
Old 04-14-2017, 01:01 PM   #32
Anna Maria , Florida
Originally Posted by blkmagikca View Post
Some of the info:
DOT B3JH 009X 0213
Tread depth 12/32
Estimated mileage 30,000 mi.
Tires were purchased 7-22-2014 at JC along with complete new axles (rated at 4,500 lbs ea), new T03 rims - all installed and aligned at JC. Centramatics were also installed.
Tires were inflated to 80 psi, and inflation was checked on all tires that morning before driving. There is a Dill TPMS system installed on both the TV & AS.
In 2015 I had the Escapees SmartWeigh done and *ALL* weights are within limits. I had posted the results of the SmartWeigh about 2 years ago, but I'll post it again once I locate the file.
ST tires are out of the question - I have had 2 tread separations plus a blowout on ST tires, which is why I am using Michelin tires.
More info when I have it.
Thread separation issues with Michelin tires is rare. This is the first I read on this forum in 4 years. Of all the Michelin tires I have ran over the years I never experienced one.
Unlike the GYM ST tires whose failure rate is common.
franklyfrank is offline   Reply With Quote
Old 04-14-2017, 01:24 PM   #33
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
I also run 72-75 on my michelins, 13...31' classic 62-68 mph..never a problem with Michelin or gym's...now at sunny calif....
Old 04-14-2017, 02:10 PM   #34
paiceman's Avatar
No. I called the factory some years ago and I asked if they were in an agreement with Michelin. At that time I was told no, they are purchased from a local dealer.
SAFE TRAVELS
Bud
Old 04-14-2017, 07:01 PM   #35
2003 30' Classic
Fresno , California
Has anyone out there had any experience with Cooper tires of the same size and ratings on an Airstream? I have used Cooper tores in the past with great results. It seems everyone changing tires and tire size are going to the LT Michelins. Not sure why...????
ldireland is offline   Reply With Quote
Old 04-14-2017, 08:23 PM   #36
Long Island , New York
There are many many tire threads, with the following being one of the most recent and informative on the switch to 16" Michelins IMO:
http://www.airforums.com/forums/f438...es-148274.html
Here are the search results for 16" Michelins:
https://www.google.com/search?q=16%3...:airforums.com
As you can see the topic has been discussed in quite a few threads.
And Cooper tires have been discussed here:
Old 04-14-2017, 09:26 PM   #37
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Answer to 2 questions
1. Michelin determined that the tire was not subject to a recall. This was the first thing they did when their dealer called in with the DOT number.
2. I tow at 62 mph (100 km/hr).
I have received the Michelin claim form and am in the process of filling it out. Once I have a final decision from Michelin I'll post the details. Thanks for all the feedback - How Michelin handles this claim would be of interest to us all.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
blkmagikca is offline   Reply With Quote
Old 04-14-2017, 11:41 PM   #38
"Space A" S/O Registry 11
2006 34' Classic S/O
Fort Worth , Texas
Discount Tire and probably American Tire (I believe their affiliate in some parts of the US) will sell you a road hazard warranty that covers everything that can happen to a tire. That specifically includes trailer use. When I got my Michelins at the factory that batch of pre-mounted tires had leaky valve stems. Discount Tire replaced all the valve stems under their warranty even though they were being used on my Airstream trailer. I was impressed with their liberal policy.
guskmg
Old 04-15-2017, 07:00 AM   #39
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
Originally Posted by FCStreamer View Post
Michelin specifically states NOT to use those tires on a trailer.
Do you have a link?
boondockdad is offline   Reply With Quote
Old 04-15-2017, 07:08 AM   #40
Dearborn , Michigan
Images: 21
Some of the info:
DOT B3JH 009X 0213
Tread depth 12/32
Thanks for the post and excellent info.
When one of my GYM did the same thing, it had about 3-4" larger diameter. I'm no scientist, but I figured when the belt flew off and the tire stretched out like a balloon- it would have impacted the PSI, right? That is, the tire pressure would have dropped. My TPMS didn't register a change, either.
Inflation PSI - Michelin LT225/75R16/E LTX M/S2 PSU1981 Tires 52 07-24-2018 12:52 PM
Michelin 225/75R16 Defender Tires kds Tires 11 02-13-2017 09:58 PM
4 Michelin LT225/75R16 Tires and Chrome Wheels warfieju Airstream Classifieds 1 02-24-2016 08:38 PM
16" Michelin LT245/75R16, Clearance? GCinSC2 Tires 49 03-02-2014 08:46 AM
Goodyear Marathon tread separation ... and our solution RossFam05BH Tires 226 06-26-2010 11:27 AM
