Old 05-02-2018, 08:14 AM   #201
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
During the off-season you may want to get the weight off the tires, air down them down and keep them covered. (our trailer sits 5 months on jack stands).
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 05-02-2018, 08:21 AM   #202
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Originally Posted by Bill M. View Post
Might not have been run 6 years. My new set of Michlins that were installed last week have a tire that was made in late 15 and 3 made in 16. Sorta bummed me out. but sitting in the warehouse has to be easier on them than running on the road.
I would go to the tire shop and tell them I want them replaced with new tires, date codes no older than a few months. 2 years is almost a third of the life of a tire. You should have gotten a 30% discount.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Al and Missy is online now   Reply With Quote
Old 05-02-2018, 08:58 AM   #203
Ravenna , Ohio
Originally Posted by boondockdad View Post
A&M, thanks. Wasn't anything like the damage when my ST's let go, but it's definitely a claim and trip to J/C.
Thanks for weighing in Tireman.
I might have pushed this set a little too long?
Good picture (full sunlight -except for shadow and in good focus) If I was trying to learn more about the tire condition this is what I would need. Can work around the shadow by simply taking another picture from different angle.
Separate issue. What was the measured load on that tire position? You say the tire was LR-E does that mean you set the CIP (Cold Inflation Pressure) to 80 on travel days?
You can review my blog (see my profile as I can't publish in a post) for more info on TPMS and how I suggest the warning levels be set.
Retired tire engineer (40 years). Write a blog on RV Tire Safety. Give seminars for FMCA In Perry GA & Minot ND.
Tireman9 is offline   Reply With Quote
Old 05-02-2018, 10:12 AM   #204
Long Island , New York
Al
Please add a hearty "second" to this suggestion. Shameful that the tire shop [and Michelin?] sold you tires that old!
Old 05-02-2018, 11:05 AM   #205
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
I winterized it late November 2017, and prior to bringing home from storage checked tire pressures. They were all 65-68psi. I brought them all up to 78-80psi, and that’s what they read every morning during the trip.
Checking during fuel stops it was usually 84-86psi IIRC.
boondockdad is offline   Reply With Quote
Old 05-02-2018, 08:11 PM   #206
Dearborn , Michigan
Images: 21
I was getting very odd wear prior to this tire blowing. Here's a pic from July 2016.
I had two different tire shops inspect it. They both said it looked like bad shocks- when the tire bounces down the road at highway speed without proper "absorption" it takes 'chunks' out.
At this point, I think a proper alignment check is in order.
Old 05-02-2018, 08:40 PM   #207
1999 30' Excella 1000
small town , Maryland
Originally Posted by streaminwild View Post
Hopefully this is the only incident. If more people report the same separation, then Michelin owners (myself included ) have a problem. Until then, I'm not worrying about it. Glad Michelin stands by their product.
I now have a problem. I was hoping this thread had a quick death, with no more responses....wishful thinking I guess. I kept the 15 inch rims and put Michelin's LTX no E on them. Your blowouts are on 16 inch rims with higher E rating tires. Thank You for updating this thread for my safety concerns blkmajikca and forum members. I've learned a few things from you guys and tire expert. We all have each others back when it comes to safety
streaminwild is offline   Reply With Quote
Old 05-02-2018, 09:24 PM   #208
Ravenna , Ohio
Careful there are P type LTX and LT type LTX You said no E on the tires. If true that means you got P type which would carry much less load. Also P type need to be derated by 9% of the tire sidewall max load capacity when applied to a trailer of truck or SUV.
Old 05-02-2018, 09:40 PM   #209
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
A 15" Michelin is a "P" (passenger) tire, not an "LT" (light truck) tire. I use them on my 27FB Flying Cloud. It's important to de-rate their total capacity, dividing it by 1.1. This takes a tire with 2184# capacity down to 1985# per tire (I think a newer version than the ones I have adds another 80# or so per tire - not 100% sure...).
As my trailer loaded for camping sees about 6000# according to CAT scale tickets, on average I'm seeing 1500# per tire leaving 485# of "headroom" on each tire. That gives me an EXTRA 20+% capacity - AFTER de-rating them for use on a trailer.
I think the tire guys usually recommend 15-20% capacity room given the ability for each tire to see a different weight and some other factors.
If your trailer is heavier than that, or a single axle, these aren't the right tires for that application.
As for the OP's 16" LT E-rated tires - I'm not an expert but that picture posted of all the chunks taken out of the treads suggests there's something different than overloading going on there.
The end of this season will be 5 years for these tires on my trailer and I am considering the GYE 15" E-rated ST tires. They seem better made than the old GYMs and are made in America. We'll see!
Good luck and safe travels everyone!!
Old 05-03-2018, 06:53 AM   #210
CapriRacer
CapriRacer's Avatar
I'm in the , US
I do not think the wear pictured had anything to do with the failure. To my eye, that is an alignment problem, or perhaps bad shocks (as the tire shop guys said).
The wear pattern for a tire failing from a tread separation is wear at the shoulders that will grow along the shoulders and not anywhere else.
CapriRacer
Please visit my website: http://www.barrystiretech.com/index.html
CapriRacer is offline   Reply With Quote
Old 05-03-2018, 06:53 PM   #211
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
The chunks that came out of the tire was the result of the peeled off tread hitting and tearing up the banana wrap.
Just to put it all in perspective, there is no doubt that, in my case, the tires were from a defective batch. Three of the 4 tires had tread separations just after the 3-year mark, even though they were well within the 7-year Michelin warranty period. My insurers agree that the batch was defective, and are proceeding accordingly.
I'll be replacing the Cooper LT tires I now have when they are 3 years old.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
blkmagikca is offline   Reply With Quote
Old 05-04-2018, 09:30 AM   #212
Ravenna , Ohio
^x2
Old 05-06-2018, 05:09 PM   #213
Dearborn , Michigan
Images: 21
aaaaand number three of the four Michelin LTX's let go on the way to Jackson Center.
Taking the old girl down to repair damage from number two blowing up, I noticed a grinding sound. Thought it a bad bearing. Stopped to inspect and noted curbside front Michelin LTX M/S dated "0412" was significantly larger, and rubbing on aluminum wheel well trim. Looked like it was five minutes from blowing all to heck.
For anybody keeping score:
DATE POSITION MILES ON TIRE
07/2017 streetside front Michelin LTX M/S tread separation flat 28,700
04/2018 streetside rear Michelin LTX M/S tread separation flat 30,500
05/2018 curbside front Michelin LTX M/S belt separation inflated 31,900
all date code "0412"
Old 05-06-2018, 05:47 PM   #214
A bad batch of tires? Probably happens even to Michelin.
What a drag!
Thanks for the update.
Peter
Old 05-06-2018, 06:30 PM   #215
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
..... Stopped to inspect and noted curbside front Michelin LTX M/S dated "0412" was significantly larger, and rubbing on aluminum wheel well trim. Looked like it was five minutes from blowing all to heck.
LTX is a marketing term for Michellin. Were those LT tires or P tires?
>>>>>>>>>Action
Old 05-06-2018, 06:41 PM   #216
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Tire were 6 years old. It was time to replace.
Old 05-06-2018, 07:45 PM   #217
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Santa Fe , New Mexico
Agreed. 6 years and 30K+ miles of use and abuse...doesn't make any difference whose name is on the tire...it was time to change.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 05-06-2018, 08:12 PM   #218
Dearborn , Michigan
Images: 21
What’s odd is- I had those same tires on my Suburban for 55,000 miles.
Not so much as a slow leak, and they were subject to waaay more abuse than what they got on my Airstream.
Is it sitting 6 months under load (winterized) that causes the problem?
Old 05-06-2018, 08:15 PM   #219
Dearborn , Michigan
Images: 21
>>>>>>>>>Action
I know they were E load rating. Not sure diff between LT and P
Old 05-06-2018, 08:16 PM   #220
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Yep, and the trailer tires get an immense amount of side force while turning and backing into camp sights.
Inflation PSI - Michelin LT225/75R16/E LTX M/S2 PSU1981 Tires 52 07-24-2018 12:52 PM
Michelin 225/75R16 Defender Tires kds Tires 11 02-13-2017 09:58 PM
4 Michelin LT225/75R16 Tires and Chrome Wheels warfieju Airstream Classifieds 1 02-24-2016 08:38 PM
16" Michelin LT245/75R16, Clearance? GCinSC2 Tires 49 03-02-2014 08:46 AM
Goodyear Marathon tread separation ... and our solution RossFam05BH Tires 226 06-26-2010 11:27 AM
