Yes, I knew the Marathons are rated for more weight but would rather be setting as high as I could and wanted to retain the original look as well. I doubt I will ever even come close to the max weights anyhow. I usually pay more attention to the letter rating of the tire, actual numbered weights seem to be pretty much subjective anyways.
I have a set of Michelin XCA 7.00R15 tires on my unit, load range C, max inflation 60psi. Does anybody know if these are still made? They seem like a very good tire, and radial to boot.
(in Florida)
I have a 72 27' International with Goodyear Marithon radials
ST 225 /75 R15 Load range C.
On the door side of the trailer the wheels rubbed the inside of the wheel well. It looked like the wheel well was bulged out so I screwed and pop rivited it back, then patched the wheel well.
I just did a complete brake job and new wheel bearings and now look to have about 3/4" space.
I like the Goodyear tires but prob need a more narrow tire.
Check the tire to wheel well clearance on each side of the trailer.
A quirk in the production process may have happened in your case. If the dimensions are not equal, then please let me know, and I will guide you accordingly, to determine why.
