Old 11-09-2007, 11:09 PM   #15
soldiermedic's Avatar
Florissant , USA
I have two new 15" aluminum wheels with good year marathoners mounted on them if you need two tires.
Check the classifieds.
Steve
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 11-15-2007, 08:55 AM   #16
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
I have read some of the tire threads and have become crosseyed and babbling. When I don't know an answer, it's hard to separate opinions (bad ones) from facts and "factoids" (Norman Mailer's word for things that look like facts, but aren't).
For the record, my new Safari's Marathons appear to be Canadian (hard to read all those little black on black words on the tire). On the threads, some report problems with Canadian tires too. Airstream claims as of last week there are no recalls on Marathons.
I have no idea what makes a trailer tire different from a truck tire (LT). If LT's are better than trailer tires, I will replace with same when the time comes (I don't know what that time is either). Any good opinions or even facts on LT vs. trailer tires?
Gene
Old 11-15-2007, 09:32 AM   #17
Gene
The Goodyear Marathons have stronger side walls that LT tires.
Also the composition of the rubber used in the Marathons, is better than the LT's, permitting them to last much longer from exposure to UV.
Old 11-17-2007, 01:33 PM   #18
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Opinions ......... mine is
If it's black, round and rated to do the job I buy it when I need them. I usually buy tires to put on a vehicle to go from point A to point B. The purpose is to get to point B.
I usually find maintence is where I spend the most effort on tires. Making sure the pressure is correct. Inspect for tire damage frequently. Rotate and balance them as needed. The tires I frequently have issues with have either old age or over 50% wear on them.
Installing them and washing them once a year doesn't get it for me.
>>>>>>>>>>>>>>>>>Action
Old 11-17-2007, 05:19 PM   #19
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
I replaced my Marathons/rims with 16" Mitchlin LTX (D) range tires. Will let you know when I have a blow out.
Michael
ArtStream is offline   Reply With Quote
Trailer Tires Lumatic Tires 171 05-18-2013 10:32 AM
Can I get taller trailer tires? Pacerized Tires 22 04-19-2007 07:01 PM
Trailer Tires? Austin Runner Tires 21 06-27-2004 11:42 PM
Trailer tires Dan Phariss Tires 46 08-19-2003 09:32 AM
Trailer Tires? Dave&Heide Tires 14 02-16-2003 06:01 AM
