Old 04-07-2007, 06:22 PM   #99
1976 25' Caravanner
Campton , New Hampshire
Originally Posted by soldiermedic
So if I buy new 15 inch rims since the old 15s are in pretty bad shape, I can put any Light truck tire on it?
Steve
Not necessarily , I believe in your vintage the dual axles came with C load rating and the single axle came with D load rating . Check the load rating for your axle . Like the Three Bears , not too much , not too little , but just right.Good luck
ticki2 is offline   Reply With Quote
Old 04-07-2007, 06:37 PM   #100
soldiermedic's Avatar
Florissant , USA
I only have a single axel.
soldiermedic is offline   Reply With Quote
Old 04-07-2007, 08:32 PM   #101
lewster's Avatar
Naples, FL , Hood River, OR
Going 16"
I'm about to take the plunge and replace my OEM alloy rims and 15" ST Goodyear trailer tires with 16" alloy rims and Michelin 225/75-16 LRE truck tires....the same ones I have been using on my Sprinter. Just because the CAN be inflated to 80psi doesn't mean that you HAVE to inflate them to that. I intend to put 65psi in them, just like I run the 15's in my CCD now.
I also run the front of my Sprinter at that pressure and have not had a problem in 70K miles. I don't want a tire failure from excess heat at ANY speed and just don't feel comfortable running the Goodyears at their MAXIMUM pressure all the time!!!!
lewster is online now   Reply With Quote
Old 04-07-2007, 09:20 PM   #102
1984 31' Excella
Norfolk , Virginia
Images: 11
Trailer Tires
Soldiermedic
Go to this website.
http://airstream.net/members/documen...%20Catalog.pdf
This is a 1968 Catalogue for Airstreams.
On page 28 (by pdf count) is a list of standard specifications for the trailers.
The 9th irem down lists the size, wheel and load range for the different configurations (6 ply=Load Range C:
8 ply = Load Range D).
Email Airstream and ask them what tire they recommend for your trailer. If they come back with an answer of "Goodyear Marathon ST225/75R15" then look up that tire on the goodyear website and write down the outside diameter and width of the Marathon.
Email Michelin and ask them what the outside diameter of the Michelin XCA 700x15 8 ply truck tire was.
With the max width of the Marathon and the outside diameter of the Michelin XCA and staying with an 8 ply tire (Load Range D) you can crawl through the tire specification charts and pick out out what you want.
For a jump start, the Eagle Alloy 0589-7766 (16 inch aluminum wheel, pull up my pictures to see what they look like) and the B. F. Goodrich Commercial T/A should work just fine.
Beginner
Beginner is offline   Reply With Quote
Old 04-07-2007, 09:31 PM   #103
dmroot's Avatar
1971 23' Safari
Portland , Oregon
Wierd wierd tire wear pattern
This is such a rich thread of tire info that I am posting pics and a question that I had placed over on my 1971 Safari thread...
Yesterday we replaced the four old 8-ply tires on our dual axle 1971 Safari (which we just bought and towed home on Monday). The front two tires had a very odd diagional-cupping wear pattern on them.
Here are the pics...Has anyone seen this on an airstream before? Any ideas on the cause?
ID:	35314   Click image for larger version
dmroot is offline   Reply With Quote
Old 04-07-2007, 11:48 PM   #104
1960 24' Tradewind
santa barbara , California
soldiermedic ,you can use 700-15 LT tires bias ply if you desire .The goodyear
workhorse rib is one good choice ,in 8 ply load range D. you also can use the ST radial trailer tire in 15" ,but I strongly recommend to research your ST
tire of choice before purchasing (read problems) and beginner definately has given very good recommendations and info . your single axle needs an 8 ply rated D tire ,a C range is too light for your trailer ,however sugarfoot
has been running some cool wide white tires on her 60 trdwnd single axle
without any problems ,but shes careful on the weight to not excede the capacity of the tires .
Scott
scottanlily is offline   Reply With Quote
Old 04-08-2007, 05:36 AM   #105
1984 31' Excella
Norfolk , Virginia
Images: 11
dmroot
What size are these tires?
What type of tires are these, bias or radial?
What who made them?
Judging from the pictures those tires with the drastically uneven tread were in the early stages of disentegration.
Determine whether or not you have steel belt pieces sticking out because the next test will shread your hand if they are.
To tell if the belts have slipped on a belted tire(either radial or belted) lay your hand across the tread area of the tire, finger tips on one sholder, heel or wrist over the other sholder(palm against the tread).
Then rub your hand (flatly, palm against the tread) all the way around the tire tread area.
The tread area should be quite flat and or symetrical.
Small flat depressed areas 3-5 inches in diameterare usually caused by a combination or bad shocks and out of balance tire/wheel/brake drum(running gear).
Other shaped areas that seem to be raised and are longer than wide are usually belt seprations.
Beginner
Old 04-08-2007, 06:29 AM   #106
1976 25' Caravanner
Dmroot
Check your brakes , it looks like those tires were skidded. Is it just one place around the tire or several?
Old 04-08-2007, 02:21 PM   #107
dmroot's Avatar
1971 23' Safari
Portland , Oregon
The old tires are now at Les Schwab heading for the tire graveyard...but we replaced them with the same size: 700-15/8. The old ones were Toyo and the new ones are Nan Kang Highway N101 Blackwall (or at least that's what they put on our reciept).
Getting the running gear up to snuff is our next step...We are planning brakes and bearings next. We are also doing a lot of reading on axles (just in case that was the problem) and we need to understand this 'balancing of the axles' thing to be sure we get that done somehow...
Old 04-08-2007, 06:58 PM   #108
1984 31' Excella
Norfolk , Virginia
Images: 11
Trailer Tires
Don't understand what you mean by "Balancing the Axles".
It would be nice if we could find a machine shop that would dynamically balance brake drums to 1000 RPMs though.
Beginner
Old 04-09-2007, 09:53 AM   #109
Beginner
Beginner.
Ouch, 1000 rpm for a 15" tire, by my quick calculations, would mean a speed of 89.25 MPH.
Way too fast, to be safe.
DMROOT.
Your photos show tires that were "grossly out of balance."
You donj't balance "axles," but you do balance the complete running gear as an assembly. That's the tire, wheel, hub and drum.
Old 04-09-2007, 12:23 PM   #110
1984 31' Excella
Norfolk , Virginia
Images: 11
Trailer Tires
Dealing with engines I have found it better to dynamically balance at a slightly faster speed than everyday use.
I didn't look up the revolutions of the tires at 62 MPH but figured them to be near 700 rpm give or take.
Anyway
1000 rpm would well cover any contingency.
Will I tow 89 MPH, no.
Didn't mean to give you a start.
Beginner
Old 04-09-2007, 12:38 PM   #111
Anyway
Beginner
It's not the "start" that hurts people, it's the "sudden stop" because of an accident.
Towing at a high speed is risky.
But, when we are younger, we sometimes do silly things.
Like the time, in 1973, I towed a loaded 31 foot Airstream with a hot Buick, with a calibrated speedo, total weight 14,500 pounds, at 115 MPH.
Anything past 90 MPH, makes the Airstream handle like a super dream.
Captured it on film, but can't find the film.
Old 04-09-2007, 01:31 PM   #112
Florissant , USA
Andy,
I need new wheels and tires for my 68 safari. I was wanting to switch to 14" rims, but many have said it isnt a good idea. The trailer is getting a new "Lighter" floorplan than before.
What would you recommend for aluminum rims and tire, and where can I get them?
LT versus ST tires on a trailer 76Argosy Tires 18 08-29-2014 04:03 PM
Airstream trailer weights FrankR Link Archive 11 10-17-2003 07:09 AM
Trailer wiring & new trucks 3Ms75Argosy On The Road... 6 11-09-2002 09:45 PM
New trailer, old club rally Pahaska Other Rallies & Events 7 07-24-2002 01:26 PM
New years added to Trailer Forum 83Excella Our Community 3 07-08-2002 06:24 AM
