Old 04-14-2007, 09:46 AM   #141
soldiermedic's Avatar
Florissant , USA
Just got mine
Behold!
My new aluminum rims with Goodyears on them.
Now if I only had a ready trailer to place them on .
Steve
Name:	new wheels.JPG
soldiermedic is offline   Reply With Quote
Old 04-14-2007, 06:50 PM   #142
1972 25' Tradewind
Madison , Wisconsin
Thanks for the info
Originally Posted by overlander63
According to the service manual I have, your coach originally came with C's on it. You can run the D's at the lower C pressure with no problem. Most of the time, D's are only about $5 each more than C's, anyway.
Thanks for the info. I was worried that I would need new tires sooner than I had anticipated. I had not decided if I would strip and repaint the tires I have now or get new ones. I definately will check the pressure on them.
Smokin Camel is offline   Reply With Quote
Old 04-14-2007, 11:21 PM   #143
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Originally Posted by pmclemore
Could 030 mean the 30th week of 2000?
Hi, No. From 2000 on to present ther are four numbers on the date part of the DOT code.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 04-14-2007, 11:29 PM   #144
Salem , Oregon
Images: 18
Originally Posted by Beginner
Define non-traffic hours (from what o'clock to when o'clock)
Beginner
Hi, in answer to your question; There are no non-traffic hours here in California. And there hasn't been any for, maybe, 20 years now. The best time to hit the road now, is whenever you feel like it because it doesn't make any difference, It's always crowded.
2005 Safari 25-B
Old 04-28-2007, 04:16 PM   #145
dpandorf's Avatar
2000 34' Limited
Somewhere in Western , North Carolina
Alcoa Aluminum Wheels/Marathon D tires
I've been reading this thread and the other tire threads trying to figure out if I screwed up.
I just bought a 2000 34' Limited and the previous owner had a flat on one of the original wheels. Had the spare on when I bought it.
Took the Alcoa Wheel to my local tire guy and we ordered the Goodyear Marathon ST225/75R15 D (max load at inflation: 2540@65)
After reading the tire threads, my manual specs say use tire: ST225/75R15LRC
Had my wife run out to the garage to look at the wheel and tire as I haven't put it on the trailer yet. (I'm in a hotel in Athens, Greece right now on standby, I'm a pilot babysitting an airplane over here, tough duty )
I have the Alcoa wheels and the wheel says max load 2200 lbs, max psi 95
Does that mean I'm ok with the D tire that can be pumped to 65 psi as long as I keep the load of the trailer below 2200 lbs per wheel?
Duane Pandorf
Blog | Google+
Air# 16888 | 2000 34' Limited | 2008 Ford F250
dpandorf is offline   Reply With Quote
Old 04-28-2007, 04:45 PM   #146
_
yes.
cheers
2air'
Old 04-28-2007, 04:49 PM   #147
dpandorf's Avatar
2000 34' Limited
Originally Posted by 2airishuman
yes.
cheers
2air'
Thks, I can go to bed now. Its 1:47 in the morning here in Greece. Hotel duty again tomorrow.
Duane Pandorf
Blog | Google+
Old 04-28-2007, 07:03 PM   #148
bhayden's Avatar
1978 24' Argosy 24
Woodinville , Washington
2Air gave you the short answer to your question
What you need to check now is the other tires on the trailer. In my opinion (assuming they're appropriate tires) you want to match them as closely as possible. If you run one tire that's a different pressure or size it will create a possibly signifcant overload on the other tire on that side of the trailer.
-Bernie
bhayden is offline   Reply With Quote
Old 04-28-2007, 07:56 PM   #149
Florissant , USA
Looks like I won't be needing these new wheels and tires. Anyone need 15" aluminum rims with new 255 75 R15s?
Mounted and balanced for your trailer!
Please?
Steve
Streaming Soldiers Blog
Old 04-28-2007, 10:12 PM   #150
dpandorf's Avatar
2000 34' Limited
Please?
Steve
Holy Cow Steve, what happened that you don't need these tire and wheels?
Duane Pandorf
Blog | Google+
Old 04-28-2007, 10:32 PM   #151
dpandorf's Avatar
2000 34' Limited
-Bernie
I have an appointment with a nearby RV service center to go over the rig on May 11th. I hope to have the Dometic fridge recall thingy repaired and while there get the undercarriage looked at. (wheel bearings, brakes etc)
I know it will cost a few bucks and some of it I could do myself but since this is new to me I would like to start off with a clean slate. Already read enough horror stories on this forum to take safety very seriously as I won't be the only one traveling with me.
I, of course, will have my better half along (wife) and my two boys. Back in my fighter days with an ejection seat my motto was always I risk my life every time I strap in but once airborne everybody on the ground is risking theirs
If I was willing to spend the money on a new TV to get the latest stuff why nickle and dime the safety of my trailer?
Duane Pandorf
Blog | Google+
Old 04-28-2007, 11:05 PM   #152
_
agree completely, and for that reason you may want to upgrade to disc brakes on the trailer...
they are very nice.
also agree with bernie's observation about mixing tires...
i wouldn't want c rated and d rated tires mixed together...
especially IF replacing them all together at once.
otoh IF in a jam and without other options,
the odd tire could be place in the center spot on a triple axle, or swapped with the spare.
this also assumes running well under the gvwr limits.
this would bug me in short order and no doubt i'd opt for new properly rated tires.
my 34 came with d rated tires, so IF yours has mostly c rated ones, and the manual indicates C tires...
did a/s changed the specs from C to D? perhaps when they uprated the triple's axles and gvwr?
as i recall the d rated are 65psi and the c rated are 50 psi in gd/yr marathon flavors...
i've had great usage on the marathons...
http://www.airforums.com/forums/f438...ons-27999.html
cheers
2air'
Old 08-09-2007, 02:26 PM   #153
1979 31' Excella 500
Battle Mountain , Nevada
Send a message via Yahoo to mikeandbecky
Trailer Tires...
OK. I have been following this thread, and, along with others, I am now getting confused, also!
Heres my situation. I'd like a few pointers, because I'm about to go and purchase 4 new tires( I have a good spare).
My 79' 31 ft. Excella 500 has four " D" rated tires on it it, and they are older, maybe five or six yrs. old. Upon inspection, they are ALL different brands...Towmaster, Goodyear, etc. I have barely pulled it anywhere, because one of my bigger concerns was getting around to replacing the tires first, before any seriously long trips. My original owners manual says the tire specs are 7.00-15XC tires. But, the PO had "D" rated tires on it. So, my question is, should I replace the Excella's tires with the original C rated ( like the popular ST 225/75R/15's, or should I go up to the ST 225/75R 15 " D " rated?
And, if I went with the original " C " rated, could a light truck tire work for the application as well?
Thanks for helping me sort this out!
mikeandbecky is offline   Reply With Quote
Old 08-09-2007, 06:26 PM   #154
lewster's Avatar
Naples, FL , Hood River, OR
Hey Mike,
I'll tell you what I did, although there are some that will dis-agree. I didn't like the Marathons with their 65MPH speed rating, tread separation stories, no ability to run in the extreme heat of the desert SouthWest where I frequently travel, etc. PLUS.....all of this on a single axel trailer....I DON"T THINK SO!!
I not only went with LT tires, but I bought new 16" rims for the BF Goodrich LT225-75-15 LRE tires that now adorn my 19CCD. These are the same tires that I run on my Sprinter van and have had no issues with them in over 80K miles.
The new BFGs have about 4K miles on them and they are great! I also sleep much better now that the Marathons are gone!
LT versus ST tires on a trailer 76Argosy Tires 18 08-29-2014 04:03 PM
Airstream trailer weights FrankR Link Archive 11 10-17-2003 07:09 AM
Trailer wiring & new trucks 3Ms75Argosy On The Road... 6 11-09-2002 09:45 PM
New trailer, old club rally Pahaska Other Rallies & Events 7 07-24-2002 01:26 PM
New years added to Trailer Forum 83Excella Our Community 3 07-08-2002 06:24 AM
