Old 03-15-2004, 05:17 PM   #1
mtpalms's Avatar
1971 23' Safari
Joshua Tree , California
Trailer-Aid for changing flats
Hi All! This is my first post in these forums. I did a search first and couldn't find an answer so here goes -
Would a Trailer-Aid: Click here to view it, be a good investment? I have noticed that changing a tire can be a difficult and frustrating thing using conventional methods, and I wondered if there are any pros or cons to using a Trailer-Aid. I notice Camping World sells 'em too - for $21 more than my source!
mtpalms is offline   Reply With Quote
Old 03-15-2004, 05:27 PM   #2
casarodante's Avatar
2012 31' Classic
First off, welcome to the forums!
I had looked at one of those but I am able to get enough elevation with these leveling blocks. Plus I can also use them normally.
Roger & Roxie (rore62) Smith (Air#178 - WBCCI#1646)
On the road!
2012 31' Classic - Nuestra casa rodante
Blog: https://www.casarodante.org - Old Airstream slides: https://airstream.casarodante.org
casarodante is offline   Reply With Quote
Old 03-15-2004, 06:45 PM   #3
I bought a six ton bottle jack for about half that price. It has the added advantage of being available if the tongue jack fails.
Mark
Old 03-16-2004, 02:06 AM   #4
Ann Arbor
Thumbs up trailer aid
I carry a yellow plastic Trailer Aid in my Airstream, but have only ever used it, so far, as a block under the electric jack. I carry the taller steel Trailer Aid in my horse trailer and that came in very handy once. Extremely stable and no worries about the trailer falling off or the jack failing. Also no need to unload the horses. In my view, a good investment.
Eugenie
maznblu is offline   Reply With Quote
Old 03-16-2004, 08:44 AM   #5
Trailer Aid
The best Trailer Aid for "Tandem axle owners," is a couple of lengths of 2 x 6's.
No need for any jack, ever.
Pull the trailers good tire up on the 2 x 6's and remove the flat.
Done. No safety issues, No flat surface requirements. No looking for that "right" jacking point.
Old 03-16-2004, 12:59 PM   #6
mtpalms's Avatar
1971 23' Safari
All very constructive replies, thanks. We've got an abundance of bottle jacks, and the leveling block and 2X6 ideas sound good, and less expensive than a Trailer-Aid.
Seriously Andy, how long would a 'length' of 2 X 6 be? I would guess 3ft would be adequate?
Old 06-09-2005, 08:10 AM   #7
2005 22' International CCD
Buckhorn , Ontario
Images: 59
Send a message via Skype™ to GT1963
Hi
Sorry to jump in on this thread or revive it - but as usual I am having problems starting a new thread - hope I have not been blackballed
Question: If you were to have a flat on a tandem which is the best one to go? Rear left or right - Front left or right.
I know none would be the ideal answer but if you are in a situation where you may have a suspicious tire - before you can get it changed.....
Thanks for any insight.
Everything will be alright in the end. If it is not alright now, then it is not the end.
GT1963 is offline   Reply With Quote
Old 06-09-2005, 10:35 AM   #8
wrepete's Avatar
1996 28' Excella
Geneseo , New York
The good thing about the 2 x 6's is they are often useful for leveling on the parking site. I use three of them [actually 2 x 8's], with the shortest one the same length as the footprint of the tandem wheels, then each is about 12" longer than the one above, centered beneath. I drill a couple of oversized holes to drop a bolt in to keep them from slipping away from each other. . . Many years of use have proved them to be very valuable for changing a tire, or parking both wheels on them. [I coated them with marine polyeurathane to keep them relatively clean, and to prevent soaking up moisture.]
Bud
1996 28ft Classic
2008 Silverado Duramax 2500HD
Hensley/BrakeSmart/EnKay
wrepete is offline   Reply With Quote
Old 06-09-2005, 12:27 PM   #9
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Originally Posted by GT6921
Hi
Left Front.
You have the best chance of seeing it when it goes, because it is closest to you. It will also be away from most plumbing. If the tire is that bad you are concerned it is going to blow, why not just remove it, and limp to a tire store on three wheels, and replace the bad tire?
Old 06-09-2005, 03:37 PM   #10
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
There was a thread a while back where DavidZ71 solicited opinions on which tire would be most likely to go. I believe the consensus was either of the aft tires because the forward tires have a tendancy to, in effect, "set up" a piece of debris to puncture the tire behind it.
Although you asked for the "best" tire, I thought it might benefit you to know the most "likely" tire to give problems.
Tom
