11-03-2016, 04:15 AM
1967 17' Caravel
Oak Creek
TPMS recommendations
Thank you for all the info!
What TPMS do you use? I need to buy that too. I've read many reviews but not sure what to believe.
11-03-2016, 04:46 AM
2012 27' Flying Cloud
W
, New England
I don't know what others use - I use the TST TPMS 507 internal model. There are pros and cons to everything. I like the internal sensors except for when I'll need to change the batteries which requires removing the tires and having them reinstalled. That's supposedly a 5 year interval. I've had mine going on 4 years.
But the beauty of any TPMS (internal or external from any company) is the real time temp and pressure monitoring. Little extra insight and peace of mind just in case something goes wrong.
There are several threads in the forums dedicated just to TPMS that can provide more insight. Here's the one I use - Mike is great to work with! And I get no compensation for this and am not related in any way. Just a happy customer!
https://tsttruck.com/product/tst-507-internal/
11-03-2016, 09:04 PM
2016 30' Classic
Houston
I use the TST 507 system with external sensors and like it.
11-03-2016, 09:09 PM
2014 30' Flying Cloud
Tampa
I use the TT-500 system.
http://www.ourflyingcloud.com/2016/0...-pressure.html
I really like it. Easy to install and read, works great on my 30'.
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2018 Nissan Armada SL Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
11-03-2016, 09:24 PM
New Borockton
, Alabama
PressurePro is the only one made in the USA if that matters and never any problems with sensor issues, reception etc. You do get what you pay for on this technology.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
11-03-2016, 09:30 PM
1976 29' Ambassador
Madison
, Officially SD but are traveling full time.
Dill TPMS
We installed a Dill TPMS system six years ago. Our TV did not have TPMS so I purchased the set that will manage 10 tires. Since our AS has two axles we only installed 8 sensors. It has worked very well. Like all TPMS units, the batteries have to be changed every 5 or so years.
11-03-2016, 10:09 PM
2017 28' International
Virginia Beach
, Virginia
I purchased the http://eezrvproduct.com/TIRE-PRESSUR...Z-RV-TPMS8.htm. A little tricky to set up but very reliable with no issues transmitting from my 18 foot trailer to my cab.
11-03-2016, 10:50 PM
2017 25' International
Los Osos
I use the TST 507 system with external sensors. Audible alarm, easily read display, rechargeable portable display, dependable transmission without booster.
Much better than the Dill system in my last trailer which had none of the above.
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
11-03-2016, 11:17 PM
2013 28' Flying Cloud
Central
, Canada
We use the TST 507 system also, as do several of our friends. The system has been flawless and the company that sells them is first rate!
Trying to use my camera to create memories - not photographs!
11-04-2016, 11:31 AM
2016 19ft flying cloud
Spokane
How about one for a single axle?
11-04-2016, 03:19 PM
Tampa
Number of axels doesn't matter. You just buy the number of sensors you need, two in that case.
11-04-2016, 03:43 PM
2012 25' FB Eddie Bauer
Southwestern Ontario
, Ontario Canada
We use the Dill Trailer TPMS which is an internal mount. Works well for us and no rubber valve stem issues that some have with valve mount systems. The battery should last as long as the Michelin ltx tires and I plan to change both at the same time approx. 6-8 years.
11-04-2016, 04:13 PM
Niagara-on-the-Lake
, ON Canada
TST did a special kit for me, upon request, with three monitors for the 507 - one on each road wheel and one for the spare.
Ray B.
11-05-2016, 02:52 PM
Los Osos
I had metal valve stems installed before installing the TST sensors.
11-05-2016, 07:45 PM
1967 17' Caravel
Oak Creek
What is the reason for the metal valve stems?
I'm looking at the externally mounted TST.
11-05-2016, 08:17 PM
Los Osos
The external sensors can work against rubber valve stems and potentially cause failure.
TST sensors work on either rubber or metal stems.
Metal stems are more robust. I use them on everything.
11-05-2016, 09:51 PM
Central
, Canada
We use metal stems on our system also. They just give the stem a little more strength and that limits the amount the sensor moves with the rotation of the tire. If I had it to do again, I would still install the metal stems.
11-06-2016, 03:41 AM
1967 17' Caravel
Oak Creek
Metal stems it is. I'm starting from scratch so I'll have the tire place do it when they mount the tires to the wheels.
Something as small as metal valve stems is the reason these forums are so great. I'd have never known that and doubt or local tire place would have told me.
Thank you!
11-06-2016, 03:46 AM
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
The Dill sender is mounted internally to the tire and has a metal valve stem as part of the sender. I have the Dill 1506-453 TPMS system installed in both trailers and tow vehicles.
Both tow vehicles have metal stems as well.
11-11-2016, 06:41 PM
Ravenna
, Ohio
I bought and use Tire Traker because of lifetime warranty and "Morning Reset" feature that allows me to get fresh reading in AM while I drink my coffee rather than getting out in the rain on my knees with a hand gauge.
