Old 04-30-2016, 07:09 PM   #1
Francisco , Indiana
Tpms
Wondering what kind of tpms everyone has. I have a Hawkshead and I hate it. I can not get the hang of setting it.
We have monitors in all our tractors, sprayers and combine, I have no problem with them but this Hawkshead has me buffaloed.
My great nephew got it set for me once but when I need to change it I am out of luck. Why would I need to change you ask. Because when you set the pressure in cooler climates then go to warmer ones it tells you your tires are getting hot when they are not. Also your tire pressure will climb when going to warmer climates and then your pressure is to high.
I ruined a tire just East of Nashville last summer because that sensor had no reception at that time.
I want something that works and doesn't take a teenager to set.
Hickory
hickory is offline   Reply With Quote
Old 04-30-2016, 07:45 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
TST, it works as advertised.
MICHAEL
Old 04-30-2016, 07:55 PM   #3
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
After the one we had being an expensive pain in the rear, and after trading for a tandem axle Airstream upgraded to Michelin 16' tires, we decided the simplest solution was no TPMS.
Perhaps we should have one after nearly five years and many cross-country trips, but we're not convinced. Perhaps when they develop the trailer offerings beyond the gadget stage we'll take another look.
Doug and Cheryl
Old 04-30-2016, 10:36 PM   #4
Arcticfox's Avatar
2013 28' Flying Cloud
Central , Canada
We use the TST also and it has been great!
Trying to use my camera to create memories - not photographs!
Arcticfox is offline   Reply With Quote
Old 05-01-2016, 12:29 AM   #5
2015 30' Classic
Pleasanton , California
The Hawkshead system and TST system appear to be based on the same reference design. The specifications are identical, panel layout is the same, buttons the same, sensors the same, etc. So it's likely that any identified shortcomings in one system would be present in the other.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 05-01-2016, 12:54 AM   #6
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Have installed the Dill 1506-453 TPMS system senders in both the 23D and the Classic tires along with the mounting of the Michelin 15" tires on the 23D and the Michelin 16" tires on the Classic.
The only challenge was that CostCo failed to mark the 16" tires with the letter of the sender in side, so they had to break the tires down to get that information. Each tire data sender mounted as the tire valve mechanism has a matching receiver chip that goes into the proper socket in the display.
Due to senioritis, I have had to call Dill on occasion to get my mental hard drive refreshed on how to do something when on the road and they have always been very helpful.
Now where are my glasses???????
Old 05-01-2016, 06:01 PM   #7
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
Used to have the TST old version.
It appeared to be working OK, then had a tread separation on a GYM. Tire didn't explode, just increased in diameter by about 2-3". Didn't set off PSI alarm.
Not running any TPMS since upgrading to 16" LTX, and I'm good with that.
boondockdad is offline   Reply With Quote
Old 05-01-2016, 07:09 PM   #8
RonaldC303's Avatar
Washington , Utah
For the Dill interior mount sensors, how do you know what size valve stems to select, the 0.453" or the 0.625"?
Ron
RonaldC303 is offline   Reply With Quote
Old 05-02-2016, 03:25 AM   #9
switz's Avatar
2014 31' Classic
Images: 8
At least in both the 15" T03-56545T and 16" SenDel T03-66655T wheels, we installed the 453 size.
Old 05-03-2016, 10:01 PM   #10
RAH
2013 30' Flying Cloud
Cincinnati , Ohio
For TPMS I have the TireTraker. Our model is the TT-400. Since I have a 30' trailer I also got the signal relay that I hardwired into the battery box. They are easy to program and pretty care free.
There is a new model TT-500, which looks to be a color screen instead of B&W. I prefer the B&W, no need to have all of that light in the truck.
I have never had the TPMS alarm go off, so I don't know if it is needed. Hopefully it will stay that way. I have 15" Michelins on the AS.
Good luck.
RAH is offline   Reply With Quote
Old 05-03-2016, 10:27 PM   #11
2015 28' International
Ofallon , Missouri
Just bought a TST based on info from this forum. I have not installed it yet, I need to change to metal valve stems first. First trip with it Memorial Day so will be checking it out.
mpsgolf is offline   Reply With Quote
TPMS - Dill internal mount system wingfoot321 Tires 10 04-19-2016 08:39 AM
Why TPMS is worth it - in my case a DILL TPMS DaKarch Tires 2 08-04-2015 08:37 PM
Valve stems and TPMS cosmotini Wheels, Hubs & Bearings 8 08-06-2013 07:28 PM
Thoughts on TPMS mwells4654 Tires 33 11-02-2010 04:20 PM
Another TPMS... reday Tires 3 07-05-2009 04:53 PM
