Old 09-28-2013, 07:14 AM   #15
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
We have a 2005 Classic 30, which we tow about 7,500 miles, 40 nights\yr. It HAD 4 Marathons mfd 14th week, 2009 and we use a TST TPMS, which monitors temp in addition to pressure, on the trailer and both tow vehicle and trailer spares.
So,how many 7500 mile trips before the failures?
Old 09-28-2013, 07:22 AM   #16
dznf0g's Avatar
Oswego , Illinois
Originally Posted by ROBERT CROSS View Post
IMHO....a "proper" sensor is metal and will have the gizmo's inside the tire, not stuck on the end of the stem....
But I don't use them on the AS and know nothing.
No, you're right. At the time of my purchase (3 years ago) the system I wound up getting had (IMO) the best reviews for signal reception....etc., but is not available with internal sensors. It is always a compromise, I guess.
BUT, external sensors have been around for a long time, and I haven't heard of any "rash" of stem failures due to them. Have any of you?
I'm still suspicious though.
-Rich-
Old 09-28-2013, 08:40 AM   #17
kmaggard's Avatar
1994 21' Sovereign
Paradise Valley , Arizona
Any brand names recommended? Where is a good place to buy? You would need to have the tires rebalanced after install?
WBCCI# 2520
AIR# 77458
Ken and Ben the Saint
Paradise Valley, Arizona
kmaggard is offline   Reply With Quote
Old 09-28-2013, 08:44 AM   #18
2006 25' Safari
Images: 8
Good question. kmaggard. I noted pass-thru air models and different ones looking around with no reviews.
Old 09-28-2013, 09:14 AM   #19
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
I'm very happy with the TST TPMS I bought. The link below is for a kit with 6 sensors - I got 4. You can get up to 22...
Purchased direct through TST and found them very responsive to calls.
http://www.tpms.com/TST_507_TPMS_INT...07tpmsint6.htm
SteveSueMac is online now   Reply With Quote
Old 09-28-2013, 09:17 AM   #20
dznf0g's Avatar
Oswego , Illinois
I have the Doran RV model and have been very happy with it for 3 years. It has correctly indicated a problem 3 times with plenty of time to pull over before 20% of air loss. Minimal signal loss and always finds it again within minutes.
They say no rebalance needed, but it is 1/3 oz sensor. I have Centramatics....so no worries anyway.
-Rich-
Old 09-28-2013, 09:26 AM   #21
W , New England
Dznf0g - I'm so tempted by centramatics or the ceramic beads (which according to TST won't be a problem with my internal sensors).
I had these installed together with the new Michelins and as a whole that's what got balanced.
Old 09-28-2013, 10:10 AM   #22
2006 25' Safari
Images: 8
I have rubber stems and no TPMS yet. I purchased metal valve stem extenders for easier air checking/filling and found exactly the same thing - marks all over the wheels from the extenders swinging all over. I will be getting metal stems eventually.
Old 09-28-2013, 10:28 AM   #23
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
I was reviewing the information I found for the TST tire system. I would like to know if these sensors need to be mounted internal to the tire or external on the valve stem. I think I saw both but am not sure.
I like the concept that they will monitor truck and trailer together and yet separately as needed. Some of us have trucks without their own sensing system.
Thanks all,
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 09-28-2013, 10:33 AM   #24
2005 19' Safari
GLENDALE , AZ
Any recommendations on metal tire valve stems? Sources?
Old 09-28-2013, 10:41 AM   #25
dznf0g's Avatar
Oswego , Illinois
I think these are the ones I got. After calling Tire Rack and Summit Racing, with no luck. The issue here is my Sendel wheels have a small diameter recess in the face of the stem hole, so I needed the ones with both lock nuts on the inside, rather than one outside and one inside. The .453 hole is the one I needed (I hope....some guessing here as I was measuring with current wheels assembled)
Flush Mount Metal Chrome Tire Valve Stems High Pressure Bolt in 4 Pieces | eBay
-Rich-
Old 09-28-2013, 11:38 AM   #26
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
The Dill TPMS is a intermal unit with all metal valve stems.Avalable at Tire Rack cheap and works good.
Moflash is online now   Reply With Quote
Old 09-28-2013, 11:43 AM   #27
W , New England
Thanks all,
You can get either. Just check their website.
Old 09-28-2013, 11:45 AM   #28
W , New England
The internal mounted TSTs I got we're attached to metal stems out of the box.
By the way - I sound like an ad for TST but I have no affiliation with them other than being a happy customer...
Where can I buy a TPM system Castaway Tires 19 08-23-2016 07:47 AM
Which Dill TPMS sender unit for SenDel T03-66655T wheels switz Wheels, Hubs & Bearings 25 09-08-2015 09:43 PM
Dill TPMS PJohnson Tires 20 05-15-2014 12:02 PM
15" Wheels ednormandy Wheels, Hubs & Bearings 6 07-25-2013 09:55 AM
Tire Pressure Monitor Systems Bluto Tires 68 09-21-2011 06:59 PM
