Old 10-20-2007, 08:33 PM   #1
tjj's63's Avatar
1963 28' Ambassador
Orange , California
towmaster trailer radial tires- keep same brand or trade up?
hey all- I'm going to pick up my 63 ambassador in MO and tow it out to CA. i found out that there are currently Towmaster trailer radial tires ST 225/75 R 15 with a max load of 2150# on her. these need to be replaced before my trip. do i stick with this brand, or switch to something entirely different. i need to get this info to MO soon, so any help would be appreciated. i've been reading all the stuff about blow outs and what not and would like to avoid that issue... thanks!
tjj's63 is offline   Reply With Quote
Old 10-21-2007, 08:15 AM   #2
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
Time to retire
Hi!
I've used Towmaster 225 75R15 ST on my 1995 28 Excella.
I like them. I now have Marathons, but plan to switch back to Towmasters at the next tire change.
Michael
ArtStream is offline   Reply With Quote
Old 10-21-2007, 09:21 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Towmasters are no longer made on this side of the pond. The molds were shipped to China last spring.
There is not a manufacutre of that size trailer tire other than in China now.
A bit costly but what I did was convert to 16 in wheels and Michelin LT 225 75 16. The Lts are rated for highway speeds while most trailer tires are limited to 65 mph.
2004 Excursion 4x4
Old 10-21-2007, 10:40 AM   #4
tjj's63's Avatar
1963 28' Ambassador
Orange , California
and i also need a "d" rated tire, right? it looks like the ones i have are currently "c" rated.
Old 10-21-2007, 10:53 AM   #5
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Towmasters in Missouri.
Ozark Traveler RV in St. James still has Canadian Towmasters. I use 'em and trust 'em. Don't forget the wheel bearings too for that long a trip.
Old 10-21-2007, 11:10 AM   #6
HowieE's Avatar
Images: 12
If you can get Canadian Towmaster it may be worth the side trip on your way to Mo. Or better yet see if they would ship them to Mo.
I used Towmasters for years but will not but up with them coming out of China with thier standards.
2004 Excursion 4x4
Old 10-21-2007, 11:15 AM   #7
tjj's63's Avatar
1963 28' Ambassador
Orange , California
i'll have to check out a map and see if they are on the way, i'll be on hwy 40 for most of the trip, then hook up with 44 all the way in to st louis. i plan on having the bearings packed, new seals and have them look at the brakes and all that good stuff, too. i was waiting on my friend to get me the info so i could set up a time to have it done.
Old 10-21-2007, 12:11 PM   #8
USN/LAPD Retired
Safari-Rick's Avatar
North Las Vegas , United States
That's all great in all to get a pair of Towmasters but, don't expect warranty service on them if there are no dealers out in the US of A. Even though you hear the stories of Marathons, at least if you run into problems on the way back to Cali you'll be able to get them fix/exchanged under the warrantee.
That's my 2 cents worth.
2007 Dodge Ram Quadcab 6.7L Diesel w/jakebrake
"Better to have more then you need, then need more then you have because you don't have enough!"
AIR #: 8129
Safari-Rick is offline   Reply With Quote
Old 10-21-2007, 12:18 PM   #9
HowieE's Avatar
Images: 12
You don't see posts on warranty work on Towmasters the way you see problems posted on Marithons so why would you consider buying a tire that may cost you your trailer or siginificant sheet metal work just for the protection of having warranty work on a know bad tire.
2004 Excursion 4x4
Old 10-21-2007, 01:00 PM   #10
USN/LAPD Retired
that's true what you're saying HowieE but, in either case if he's on the road he'll have to purchase what's available and in most cases it will be GY or Maxxs's.
Don't get me wrong, short of going to a larger rim size there ain't much of selections out in the real world.
AIR #: 8129
Old 10-21-2007, 01:15 PM   #11
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Welcome, neighbor, and goo dluck with your trip. I've had Marathons on both my trailers, and have never had a problem. When it is time to change the tires, I will have to look for an alternative, because the Marathons are getting such a bad rap lately. The more I hear about them, the scarier it gets. I will go the route of 16in wheels and truck tires, more than likely. You might consider this as well, from the get go. Save yourself the entire taxing tire discussion. Trailer tires apparelty just plain stink.
For what it's worth, I mount and balance my own tires,and I can not confirm sidewall stiff ness being a factor in trailer tire design. I found the sidewall on the Marathons rather soft and pliable. I found the overall quality of the casting of the tire rather poor, actually.
Go with the 16's if you're going to keep the trailer.
Here's whee youc an get wheels:
www.trailertiresandwheels.net
Here's their page with the 16" wheels:
16" ALUMINUM TRAILER WHEELS FOR FIFTH WHEEL TRAVEL TRAILERS, TOWABLE RV'S, CARGO TRAILERS, HORSE TRAILERS, LIVESTOCK TRAILERS AND MORE
Then you can run a LR d or E truck tire, and forget about the debate once and for all. Thisis what they use on heavy 5th wheels, btw.
Uwe
www.area63productions.com
Old 10-21-2007, 02:04 PM   #12
_
Originally Posted by HowieE
...There is not a manufacutre of that size trailer tire other than in China now...
well, not exactly....
there are still plants in other parts of the world making them...
even in the USA!
Denman Tire Corporation
http://www.denmantire.com/catalog/Trailer.pdf
i've never seen or used these but someone found this domestic maker and posted it recently...
ohio is still part of the union right?
no uwe's got the goods on a proper wheel/tire swap..
and the important thing for the o.p. is....
IF the current wheels on the 63 amb' are original don't break them with higher rated tires overly inflated
cheers
2air'
Old 10-06-2012, 03:16 PM   #13
USN/LAPD Retired
Ok guys, I'll be the first to admit that I'll have to eat my words in my previous post. Where Marathons are made in China, I just got a pair of TowMasters from Costco and were made this year 3/2012 in "Indonesia". Looked at all the reviews on the "net" about them vs GY and went with the TowMasters as they had a greater plus review then the Marathons made in China. And the fact that Costco has a good rep on most of it's products. We'll see how the story plays out.
AIR #: 8129
Old 11-02-2012, 10:08 AM   #14
1995 34' Limited
Diss , Norfolk
If you go on www.ebay.com there is a guy selling them at $88 a throw new. However he only ships to the US. So if there is someone out there willing to let me ship one to him the he can forward it to me over in England please give me a call either here or teddyspicnics@googlemail.com Many thanks for any help anyone can offer me
teddyspicnic is offline   Reply With Quote
Anyone road tested Towmaster tires Kistler Tires 38 03-04-2014 09:06 AM
Towmaster Tires pap Tires 47 11-05-2009 06:23 PM
Which brand of tires should we get? Tin Lizzy Tires 6 08-08-2006 11:33 AM
Need to rent a small trailer for a trade show in FL astronomad Our Community 1 01-12-2004 05:56 PM
67 trade wind tires? john hd Tires 6 01-15-2003 05:44 PM
