Old 11-02-2012, 11:02 AM   #15
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
You might think about the wheels before you buy D rated tires. My trailer came with steel wheels and C tires from the factory. I think the wheels are only rated to 50 psi. If you have Aluminum wheels and they are rated to 65 psi then you need the D tires. 65 psi tires at 50 psi seems like a recipe for faliure to me. A tire that most likely will work on the trailer is a 235-15 like the Michlen LTX. Or the Goodyear. These come in a extra load tire that is rated at about 2000 lbs and for 50 psi inflation. And not subject to a high failure rate like the ST tires. I have over 4 years and a whole lota miles including Alaska on mine with no problemsIf you just have to have the ST tires or do not want to deal with making a radical change I would go with the GYM. Load range C if you have steel wheels and a suggested inflation 50 lbs or under. Load range D for Al wheels and inflation over 50. My neighbor lost 2 Towmasters on his 5th wheel late this summer. Lot of colateral damage too. His second major tire failure in 4 years.
Anyone road tested Towmaster tires Kistler Tires 38 03-04-2014 09:06 AM
Towmaster Tires pap Tires 47 11-05-2009 06:23 PM
Which brand of tires should we get? Tin Lizzy Tires 6 08-08-2006 11:33 AM
Need to rent a small trailer for a trade show in FL astronomad Our Community 1 01-12-2004 05:56 PM
67 trade wind tires? john hd Tires 6 01-15-2003 05:44 PM
