Old 12-06-2015, 09:18 PM   #1
2018 30' Classic
Mannford , Oklahoma
TireTraker TPMS
Has anyone installed a TireTraker TT-500 tire pressure monitor system and how do you like it?
If so, did you get a booster? Their website says to install a booster ($49) for a metal skinned unit.
Gerald
geraldsmith is offline   Reply With Quote
Old 12-07-2015, 09:28 AM   #2
Cumming , Georgia
I am sure about Tire Tracker but if have any questions TST I am here for you. Typically the booster/repeater is not needed with Airstreams with TST.
Mike Benson
TST 770-889-9102
mbenson1234 is offline   Reply With Quote
Old 12-07-2015, 11:00 AM   #3
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
I use the TireTraker system with our 25fb with the Tundra and now our Ram and no issues with the distance.
I like it very much. Once charged up the receiver unit battery lasts a long time so you can share the dash 12v adapter with other devices.
I would order and extra set of O rings for the sensors. I found a couple of mine wore out after the 1st season.
When the trailer is in storage I'll remove the sensors and store them at home with the receiver. When I come to install them for a trip I'll take one sensor, add the battery, then choose a tire, wait about 10 seconds then remove it and the receiver will alarm showing the tire location. If I'm not at the correct tire go to that tire and screw it in.
The pressure reading is pretty accurate but always use a trusted pressure gauge to compare.
Kelvin
Old 12-07-2015, 03:09 PM   #4
Senior Member
sheriff1's Avatar
2014 30' Flying Cloud
Sparks , Nevada
Kelvin
I write on each sensor with a sharpie.
2015 F350 CC 4X4 6.7 Diesel
2010 27FB Silver Cloud "The Silver Spoon"
sheriff1 is offline   Reply With Quote
Old 12-07-2015, 03:15 PM   #5
KJRitchie's Avatar
2008 25' Classic
Thought about doing something like that. I'd have to get a white/yellow Sharpie since the sensors are black. I just never get around to doing it.
Kelvin
TPMS - Dill internal mount system wingfoot321 Tires 10 04-19-2016 08:39 AM
Why TPMS is worth it - in my case a DILL TPMS DaKarch Tires 2 08-04-2015 08:37 PM
Valve stems and TPMS cosmotini Wheels, Hubs & Bearings 8 08-06-2013 07:28 PM
Thoughts on TPMS mwells4654 Tires 33 11-02-2010 04:20 PM
Another TPMS... reday Tires 3 07-05-2009 04:53 PM
