02-07-2015, 01:59 PM
Lynn
Beaverton
, Oregon
Tires...when to add air
While on the road, can anyone recommend a portable air compressor? 120v vs 12v?
Lynn
02-07-2015, 02:16 PM
2012 25' FB International
Trent Woods
, North Carolina
On the road 120v does not make a lot of sense to me. Most 12v compressors have to work pretty hard for trailer pressures, the cheap ones are not reliable. I have one from VIAIR. Expensive, but reliable and some models with 100% cycle time(no rest period needed).
Larry
02-07-2015, 03:33 PM
I'm In
, Kentucky
Larry
Which model do you have and does it provide enough air to blow out the lines for winterizing? We're going to be returning to cold weather in a week and I need to winterize again. I'm looking for something small for tire pressure but also to blow out the lines again.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
02-07-2015, 03:50 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
See'n as I carry a genet anyway I use a 120v Black&Decker.
I also have a 12v pump & small tank on the Burb for the Grover if needed.
02-07-2015, 03:51 PM
Full Time Adventurer
2007 27' International CCD FB
Nomadic
, USA
Viair is great, there are small portable ones which I've used and they are all amazing. I am upgrading to their Heavy Duty Constant Onboard Air to run my tools. Plus I want to be able to re-inflate 35s quickly from when I air down to 10psi.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
02-07-2015, 04:10 PM
Trent Woods
, North Carolina
I have the 450P auto and I have no idea how it works for blowing out lones, I do not do that. It is 1.66 cfm and 150 psi
Larry
02-07-2015, 07:15 PM
Nomadic
, USA
So I wanted to recommend something else, that's worked really well for us,
Q Industries MV50 SuperFlow High-Volume 12-Volt Air Compressor
I still keep it in my Ram. Matter of fact almost everyone in our Offloading club uses this pump to air up their tires after offloading. It's been great, and it's affordable for anyone's budget.
Had mine since 2012.
02-07-2015, 07:42 PM
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington
, Ontario
Viair 350P, never leave home without it. It is an excellent 12 volt air compressor that proves you get what you pay for. It is very high quality and I have not had a need for the larger capacity Viair units. It has substantial alligator clips that must be attached directly to the battery and it will reach all the Airstream and TV tires when attached to a battery on the yoke. I have not tried to use it for winterizing. Very happy with the purchase. Jim
02-07-2015, 07:59 PM
2005 25' International CCD
Lilburn
, Georgia
We have used the Ryobi battery powered 18v air compressor for year. It will adjust the pressure in all 4 tires several times on one charge. We take it along for pumping up the bicycle tires, but it works good for the trailer and TV also.
02-07-2015, 08:04 PM
Biloxi
, Mississippi
12V 100 PSI High Volume Air Compressor
I have been using this one for several years, it quickly adds a few pounds and is very solidly built and reliable for being so inexpensive.
MICHAEL
