Old 11-03-2011, 04:19 AM   #239
casa3805's Avatar
Corpus Christi , Texas
Images: 41
Wow, talk about providing an informative answer....Thanks so much!!
Chuck & Skye
Rock and Roll Will Never Die!
WBCCI 3805
AIR 54011 Since July 2011
casa3805 is offline   Reply With Quote
Old 11-11-2011, 09:50 PM   #240
1984 31' Excella
Norfolk , Virginia
Images: 11
Tires Tires Tires
Hi Bob
Its good to hear from you again.
Just got back from a round robin of about 2000 miles+.
I'm still running of the Commercial T/As you turned me on to back in 2006 or so.
I still have no sidewall cracks and still only touch up the tire pressure in the spring. I check the pressure on a regular basis and still have the TPMS installed.
Yes, I took some heat from from my comments, you took much more.
Your suggestion saved me a lot of work. Again thank you.
For those who are starting out on the journey of discovery concerning tires this thread is a must read primer, read it from end to end, there's a treasure trove of information here.
When we head west I will make it a point to arrainge a reunion.
Happy trails my friend.
See you down the road
Beginner
Beginner is offline   Reply With Quote
Old 12-26-2011, 02:17 PM   #241
bhayden's Avatar
1978 24' Argosy 24
Woodinville , Washington
Not sure if this belongs in this thread or not but one of the items on my list to Santa was an Infrared Thermometer.
Non-Contact Infrared Laser Thermometer
Since I've been such a good boy I got what I asked for
Some of the stuff from Harbor Freight is cheap and some is inexpensive. I'd rate this tool so far as inexpensive. It seems to work great on everything from 68 F pets to 116 F coffee to 418 F wood stove. The wood stove readings are really slick because I can now measure the temperature differential across the entire cook top which makes cooking much easier. Hard to go wrong for $40 when a commercial grade instrument is about $200 more .
bhayden is offline   Reply With Quote
Old 01-18-2012, 02:57 PM   #242
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
This is a long thread, but I think it has a lot of really salient info -- and I read six years of posts on it, along with several others regarding the stock Marathons. After giving this a lot of thought (and having a brand new 2012 Intl CCD), I decided to dump the 15" wheels and go to 16" so I could avail myself of tires that are a better quality fit with a mega-expensive hunk of aluminum. Here's a shot of all 5 of the new Michelin 225/75R16 LTX's that I'm going to install. There are 4 of the Dill TPMS transmitters in them as well. I'm feeling a whole lot better about future trips in Silver Leaf as a result of doing this. Anyone want brand new 15" wheels with brand new Marathon ST's? Will be on Ebay soon.
ID:	149140   Click image for larger version
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 01-18-2012, 03:05 PM   #243
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Would suggest that you put your old rims and tires in the classified section...someone will surely want/need them!
Enjoy the new shoes!
TB & Greg and Abbey Schnauzer
#3954
Old 01-18-2012, 03:32 PM   #244
casa3805's Avatar
Images: 41
BAB
Agree this is one of the most informative threads out there. Bob and Rednax came by the house a couple months back to do a walkthru for me on my old trailer. Tires ended up being the discussion of the day. I am ready to pull the trigger but have not had a lot of luck finding the wheels he used. Do you mind posting the brand/model number of yours?
Chuck & Skye
WBCCI 3805
Old 01-18-2012, 06:37 PM   #245
BAB
BAB's Avatar
2015 30' Classic
Chuck,
Wheels are Tredit 03's (all silver, clear coated), I ordered them directly from Tredit. Five of them including shipping was $618.50. Tires came from Tire Rack, LT225/75R16. Both suppliers incredibly fast. Wheels arrived in less than 5 days, tires took 3. I had tires mounted at local tireshop, including a Hunter computerized road force balance, cost was $104. If you add all this up it was not inexpensive, but I feel really good about being proactive....and very thankful for what I learned both from this thread and some other detective work I did on going to LT tires vs. the standard (and not so terrific) Goodyear Marathons.
_________________
ProPride 3P
AIR# 58452
Old 01-18-2012, 07:01 PM   #246
casa3805's Avatar
Images: 41
Thanks so much. Time to make that move!
Chuck & Skye
WBCCI 3805
Old 01-18-2012, 07:23 PM   #247
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I try not to get caught up in all this tire discussion....as interesting as it is. For the past ten years, or so, I use 700 x 15 bias ply tires on four different Airstreams. I have been to all corners of the country, over all types of roads, and never had even a flat. I use the same tires on all four farm hay and equipment trailers and never had a problem...other than a blow out when I ran a loaded hay trailer over a huge rock at a barn entrance. I have to replace the Flying Cloud tires this year just because they are coming up on four years old and 35,000 miles. I will replace with 700 x 15 bias again. I do have Marathons on the Curtis Wright. Ignorance is bliss.
Old 01-18-2012, 07:39 PM   #248
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
There, you went and said it. Now you've jinxed youself. You went and said the forbidden words " I've never had even a flat".
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 01-19-2012, 04:07 AM   #249
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Originally Posted by casa3805 View Post
BAB
Chuck,
Southwest Wheel is a possible source if you wish to work with a local vendor (HQ: San Antonio). I've been over there several times recently and will be back in a few more days on trailer-related items:
Southwest Wheel
1917 N Padre Island Dr
Corpus Christi, TX 78408
Phone: +1 361.289.0301
Ross
Old 01-24-2012, 10:07 AM   #250
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
What a fascinating thread. Opinions wanted. I am currently in the process of putting a new axle assembly on my 1964 Bambi II. It has 14 inch wheels. Would there be any benefit to going to a larger wheel or is that even possible or a smart thing to do? And what tires would be the best for me to change too. The current tires look ok but are about 8 years old.
Old 01-24-2012, 10:18 AM   #251
Changing to 15 inch wheels will offer much more safety.
Depending on the lug pattern of the drums, you will need to have 5 or 6 lug wheels, to match the drums.
The tire size then can be 205/ 15 load range "C".
Old 01-26-2012, 02:44 PM   #252
casa3805's Avatar
Images: 41
Step 1
BF Goodrich Commercial TA
LT 225/75R/16 (5 each)
TireRack.com Easy on line buying experience, quick delivery.
Don't they look pretty before they get used?
Going on my 27ft Sovereign.
Chuck & Skye
WBCCI 3805
1968 GT tires that will fit... RECOMMENDED ALUMINUMINUM Tires 5 10-31-2011 11:30 AM
Wide White Wall Tires wasagachris Tires 14 08-04-2011 09:32 PM
Tires and Alignment Airstream12557 Land Yacht/Legacy Motorhomes 0 06-08-2011 05:04 AM
Towmaster Tires mshamilton Tires 0 05-08-2011 09:38 AM
