Old 04-09-2006, 11:38 PM   #169
1992 34' Limited
Falls Church , Virginia
OK, sorry to that this thread here....
Hello all -
Reading this thread with interest. Got new tires about 1 year ago - replaced what was there with exact same tire - different manufacturor.
Wondering if I am running with incorrect pressures.
'92 34' Classic Lmtd - triple axle. ST225 75R15 on original 15x6 rims.
GVWR of 8900 (on tag).
GAWR of 2800 per axle. Is that per wheel, ie each side??? 2800 x 3 =8400 That is under GVWR!?
Same tag says to inflate to 50psi cold. Tire says cap. is 2450 at 65psi.
ARG@#(*%#(!!!!!!!!!!!!!!
Help!!
I think I confused myself into a panic here....
Thanks for all thoughts
Axel
SilverToy is offline   Reply With Quote
Old 04-10-2006, 06:25 AM   #170
Images: 59
Originally Posted by SilverToy
. . . . .ARG@#(*%#(!!!!!!!!!!!!!!
Axel
Axel,
You are in excellent shape. The axle rating is for two tires, so each tire needs to handle half the axle weight, or 1400 lbs.
That is only about 60% of the tire capacity, so 50 psi in the tire is a reasonable inflation pressure.
The axle rating plus the tongue weight is how the GVWR is calculated, so 8900# is a good number.
Now have a donut and pat yourself on the back!
markdoane is online now   Reply With Quote
Old 04-10-2006, 11:45 AM   #171
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Axel
Put another way.....
at 65PSI the tire cap is 2450 (I don't know what it is at 50 PSI) and you have 6 tires. So 6 X 2450 = 14,700 pounds of capacity for the tires. Take 90% (a 10% safety margin) and you really don't want to subject your tires to a total load of greater than 13,230.
Now your axles are rated for 2800 and you have 3. So 3 X 2800 = 8,400. Take 90% of that and you do not want to subject your axles to a total load of greater than 7560.
Do weigh your trailer in camping condition to find out if you are taxing your axles, since your total tire capacity far exceeds the axle ratings.
>>>>>>>>>>>>>>>>Action
Old 04-10-2006, 06:37 PM   #172
Cartoon Character
Porky Pig's Avatar
2004 34' Classic
On The Road , U.S.A.
Originally Posted by Action
Put another way..... at 65PSI the tire cap is 2450 (I don't know what it is at 50 PSI) ...
2150 .
Porky
TrailerGypsies.com
WBCCI #3405 Escapees #80360
I live the life I love and I love the life I live.
-- Willie Dixon
Porky Pig is offline   Reply With Quote
Old 04-13-2006, 10:08 AM   #173
Cracker's Avatar
Pittsfield , Maine
Correct Pressure??
This discussion finally came around to my question! During my factory vist, Airstream replaced my original Goodyear Marathon tires, load range "C," with new Goodyear Marathon, load range "D" tires. As Porky pointed out, the capacity of the "D" tires is 2,540 lbs at 65 psi, as opposed to 2,150 lbs at 50 psi for load range "C" or "D." Airstream originally recommended that the tires be inflated to 50 psi for my 2000 30' Excella. Accordingly, in order to achieve the softest ride, I would assume that the lower 50 psi pressure is still correct? I don't believe that Airstream is willing to arbitrarily increase my CCC by 1,560 lbs!
Cracker
Cracker is offline   Reply With Quote
Old 04-20-2006, 08:19 PM   #174
1984 31' Excella
Norfolk , Virginia
Images: 11
Tires....Tires...Tires
Here is something I read recently about adjusting tire pressure to load. Just wanted to get some feed back on this concept. This is easier with two people.
Take a piece of chalk and draw a line across the tread from sidewall to sidewall.
Move the unit forward enough for the tire to make two or three revolutions and stop with the remnants of the line so you can see it.
Check the line on the tire. If the line is gone in the center of the tire and fresh at the sholders then you have too much air in the tire. Conversely if the line is gone at the sholders and remains in the center, the tire is underinflated. The idea is to have the line disappear evenly across the tire from sholder to sholder.
I tried this with my tv. I still have the portable scales. I weighed each wheel and wrote the weight down. then did the chalk thing. When the chalk wore off evenly, I rechecked the tires and sure enough the tire with the least weight on it had the least pressure in it and the least amount of pressure seemed reasonable to me.
Any one ever heard of this. Any reason why not to use this method? Sure seems simple.
Again...Beginner, but learning
Beginner is offline   Reply With Quote
Old 05-12-2006, 11:09 PM   #175
GoldFever's Avatar
2007 23' International CCD
Hemet , California
Tire aging?
Should tires be replaced periodically even if not used much and showing little wear? I had two blowouts on my 25 foot Excella trailer roughly 4 years ago to tires that were on the trailer when I bought it. I believe they were about 3 to 4 years old when they blew. A friend (also with a 25 foot trailer) swears by replacing tires every 4 years no matter what condition. Safety and peace of mind on trips makes for a happy traveler.
PS - I am approaching the 4 year "anniversary" of new tires.
Gary & Susan Norgan
2007 International 23ft Ocean Breeze
Hemet, CA
"The key to flexibility is indecision"
GoldFever is offline   Reply With Quote
Old 05-13-2006, 12:12 PM   #176
Tire questions.
Tires are replaced because of mileage, and because of time, no matter how few miles they may have traveled.
Replacing tires because of wear, is not a question.
Replacing tires, that have aged, but that have but a few miles on them, seems to be an uncertainty.
Rubber, has a memory, and must be flexed frequently, or the memory simply dies.
Flexing the tire itself, leads to a greater useful life, because of that flexing.
All of us have rubber bands at home, that are years old, because we use them often.
Most of use have also seem rubber bands, that were seldom used, that just simply turned gummy or brittle, and yet were from the same package as those that are still good.
Tires, basically react to use or non use as the case may be, in approximately the same way.
The Airstream trailer is some what the same way.
Historically, those owners that use their trailer very often, will typically pay "less" for routine repairs, than those owners who use the trailer just a few days a years.
Our repair records, more than prove that point, over and over again, year after year.
And besides that, Grandma, who is always right, still contends that, " if you don't use it, you will lose it".
I know she is talking about the Airstream trailers, because Grandpa, is still around.
Andt
Old 05-13-2006, 06:56 PM   #177
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
The tire companies know their products better than anybody else. Their rubber engineers/chemists have spent years developing the very complex rubber compounds which go into making tires. There may be up to 30 compounds in a single tire. Some of these compounds contain special additives which leach to the surface to protect the rubber from Ozone and UV attack. Flexing them causes the additives to come to the surface faster, so there is some truth in tire may age more just sitting around. The bigger variable however is the environment they are in. Tires in CA,AZ,NM,TX, FL, and the rest of the south are exposed to more sun and Ozone than those parked in a barn in Wisconsin. You really can not apply the same aging rules to all enviroments. The Trailer rated tire have more anti-aging additive because the companies know they will not get as much wear per year as a car or truck. We should get someone out of the tire industry to make a contribution to this thread. What a dealer learns from his experience in California does not necessarily apply to possible tire usage in New England.
Old 05-13-2006, 07:26 PM   #178
1960 24' Tradewind
santa barbara , California
i would say the tire rule is a good one,My 60 tradewind I purchased in nebraska had tires in excellent shape ,at least visualy,no cracks ,as new tread .YES a blow out on I 70 .The trailer was not loaded with anything heavy ,no water or cargo ,no sheets on the bed even. I checked inflation before traveling.The tires were not new however,just looked fine.They were some years old,still looked great.They failed .I go with the 4 year rule.I agree about harsher sun environments ,they are harder on an exposed tire.Sitting in a barn unused ,the tires still deteriorate ,cannot stop that from happening .
sitting unused they too deteriorate. dwightdi posted very good and informative information.I agree with most of it except the last sentence
which I dont get .If gnorgan is from hemet then he needs to change those tires,hemet is hot !! in the summer easily 100 degrees.
Scott
scottanlily is offline   Reply With Quote
Old 07-06-2006, 01:31 PM   #179
acrane's Avatar
1980 31' Excella II
Stonewall , Mississippi
Carlisle 10 Ply E Radials
My husband and I have a 31", 7100 lb Excella. Have been recommended to purchase a ST225/75R15 E Carlisle.
I have heard the Carlisle are not good.
Any recommendations?
Alice Crane
acrane is offline   Reply With Quote
Old 07-06-2006, 01:42 PM   #180
Alice Crane
Since you own an Airstream, you must have some faith in the company.
That being the case, would it not be a wise idea, to also trust them with their choice of tires for the past many many years?
They use Goodyear Marathons, for a number of good reasons.
If you chose to use another brand, then you are doing the testing.
Old 07-06-2006, 01:59 PM   #181
bhayden's Avatar
1978 24' Argosy 24
Woodinville , Washington
My husband and I have a 31", 7100 lb Excella. Have been recommended to purchase a ST225/75R15 E Carlisle. I have heard the Carlisle are not good.
Over the years Carlisle has used a number of suppliers. Recently they bought/merged with Titan; another tire manufacturer.
http://www.fool.com/boringport/1999/...port990811.htm
If I read this right Titan and Carlisle trailer tires will be made togther in the factories in China and/or Thailand. Looking at the list of factories around the world I'm not convinced Carlisle actually owns the factories but rather contracts capacity from other industry giants. I'm not at all clear on who does the engineering and design for the trailer tires, if tires from different plants are the same or how often the product changes due to market forces. Again, anyone that's bought tires recently I'd love to know the plant code for the tires.
I've seen claims that Carlisle is the number one supplier for new trailers sold in the USA. I don't know if it's true but, like Goodyear there are certainly a high number of them out there so it would be expected that you'd see a proportional number of failures reported.
A load range D tire should be more than adaquate for your trailer. There's some difference of opinion on using higher load range tires. Do they provide more of a safety margin or will they last longer? One thing for sure is that your rims are rated for a certain pressure and to exceed that pressure (quite likely with load range E tires at max) is a bad idea.
http://www.discounttire.com/dtcs/inf...ionAnxiety.dos
-Bernie
bhayden is offline   Reply With Quote
Old 07-06-2006, 02:15 PM   #182
Bob Thompson's Avatar
Corpus Christi , Texas
Images: 67
For the Record it is not necessarily wrong for a company to spec a product and have it manufactured by a contractor. Toyota has done it successfully for years. Corolla's and Tacoma's are made at a NUMMI plant in California. The '07 Camry's will be made at a Subaru Plant. I believe there are a number of B F Goodrich tires made by contractor's.
If you want to find out if Carlisle makes a good tire, Google "Carlisle Failure" or "Carlisle Blow-out" and see what others are saying. You might also try it with "Marathon Failure" or "Marathon Blow-out"
So Long!
Bob Thompson is offline   Reply With Quote
1968 GT tires that will fit... RECOMMENDED ALUMINUMINUM Tires 5 10-31-2011 11:30 AM
Wide White Wall Tires wasagachris Tires 14 08-04-2011 09:32 PM
Tires and Alignment Airstream12557 Land Yacht/Legacy Motorhomes 0 06-08-2011 05:04 AM
Towmaster Tires mshamilton Tires 0 05-08-2011 09:38 AM
