Old 04-12-2010, 08:55 PM   #1
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
tires on a Chevy1500 1991
Replacing tires on a Chevy1500 1991 Truck 15in. I plan to get an equalizer hitch to pull a 65 AS 28 ft. 4040lbs.What type of TV tire ,load range,and pressures would be recommended?
bwaysteve is offline   Reply With Quote
Old 04-12-2010, 09:15 PM   #2
1980 31' Excella II
Drummond Island , Michigan
Look at the placard mounted on the drivers side door frame of your truck. The tires, max load and max tire pressures they and the truck are designed for are described on that placard. Buy tires that will meet or exceed the max load specification for your vehicle. Do not put anything less on the truck.
Ahzmyrah is offline   Reply With Quote
tires radials or bias ply tires larry b Tires 22 06-27-2010 05:36 PM
Tires ready to blow out! Should Marathon tires be outlawed? marchesi Tires 21 08-22-2009 10:11 AM
1991 plumbing Brad Hunt Plumbing - Systems & Fixtures 2 09-12-2007 07:12 PM
My 1991 Limited has done it now. catson4 General Repair Forum 4 09-07-2007 11:39 AM
Tires, anybody ever heard of Specialty Tires of America? lebolewis Tires 3 06-08-2006 04:11 PM
