Old 11-26-2010, 07:27 PM   #15
x
XXXX , XXXX
Stephen check out these wheels for $85.00. Your set up from VTS will be $65.00. $80.00 more gets you these.
Aluminum Trailer Wheel Style: SERIES #03 Size: 15 x 6 Bolt Pattern: 6 x 5.5 Bore Size: 4.25 Load Rating: 2830 lbs @ 80 PSI Offset: 0mm Hispec
They also have tires and can ship them to you already mounted on the rims.
wasagachris is offline   Reply With Quote
Old 11-27-2010, 08:28 AM   #16
1965 28' Ambassador
Malta , New York
I'm sold
All I can say is wow!!! these are beautiful!!! I'm going with these instead. Will they carry the tires you recommended in your previous post? I'll have them mount and ship everything.
Airstreamdmb is offline   Reply With Quote
Old 11-27-2010, 08:46 AM   #17
x
XXXX , XXXX
Stephen I was just looking at their site. That rim plus Goodyear Marathon tire,chrome center hub, lug nuts, valve stem and balancing $200 each wheel.
Rim $85
tire $100
hub $3.50
nuts$3.50
valve stem $2.00
Balance $6.00
Old 11-27-2010, 05:39 PM   #18
1965 28' Ambassador
Malta , New York
Goodyear Marathon??
Rim $85
tire $100
hub $3.50
nuts$3.50
valve stem $2.00
Balance $6.00
Chris; thanks for researching this on their site. I didn't think you were a fan of Marathon tires since you had mentioned the other brand in your post. Is this the setup you are also going with yourself? Can you send me a link of the correct tires on their site too. I see several listed there for Marathon. Any other details too as far as hub,nuts,valve stem, etc. thanks. I'm thinking I will keep the old tires and rims I currently have and slap these on each fall for storage and bring the good rims and tires inside out of weather and away from UV rays for protecting the rubber over the winters. Thanks
Old 11-27-2010, 06:40 PM   #19
x
XXXX , XXXX
I have no personal experience with GYM`s. There are several threads regarding tread seperation and tire failure for them. However they sell lots of these tires and that is what the airstream dealers sell. I did some research here and Yoko`s were $129,GYM`s $135 and Michelins were $170. Lots of guys are going with Michelins.
Tires: ST225/75R15 LRD Goodyear Marathon Radial Special Trailer Tire
Nuts: Stainless Steel Capped Lug Nut -- 1/2 inch, 3/4 Hex
Center Cap: Stainless Steel Center Cap -- 4.25 Open End w/ Plastic Plug
Valve Stem: Valve stem TR600HP high pressure chrome for 0.453 valve hole, snap in style with 100 psi cold inflation pressure 2.48" overall length
Balance: Spin Balance Aluminum Wheel and Tire Assemblies
I have`nt decided what tire to go with my yoko`s are fine but old so they should be replaced before I go on a long trip,which won`t be until next fall at the earliest. I`m a long way away from using the trailer. I`m still trying to get the shell closed up for winter and I have no interior yet. Just an empty shell on a brand new chassis.
Old 12-04-2010, 09:17 AM   #20
1965 28' Ambassador
Malta , New York
thanks Chris; my two son's are voting for th original retro look with the black rims and moon covers instead of the newer modern look. Anyone looking to cast a vote please chime in with a posting or two. I do want my kids involved with my restoration/renovation project too, so I'm leaning to following their request. We will be doing the new axles and new rims in the Spring.
Old 01-29-2011, 02:27 PM   #21
1965 28' Ambassador
Malta , New York
Chris just verifying this is everything I need and these will fit my 65 airstream. I plan to order 2 new axles too from Andy.
Old 09-06-2011, 06:44 PM   #22
1965 28' Ambassador
Malta , New York
New tires rims axles
Here's what it looks like now that it has new rims tires and axles replaced.
tires, wheels
One more Airstream part or not question richinny General Repair Forum 0 09-09-2010 08:16 PM
73 TW two part question, cushion material moparjohn Upholstery, Blinds, Walls & Interior Finishes 6 08-14-2010 07:25 PM
'65 Globetrotter missing interior part question... classicfins General Interior Topics 1 09-07-2009 02:09 PM
Snow tires? 3Ms75Argosy Tires 1 11-15-2006 01:34 PM
Skylight part question ColtSAA45 Roof Vents, Skylights & Fans 3 04-22-2004 08:05 PM
