Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Tires
Old 06-09-2004, 03:44 PM   #1
Tires good or bad?
2 years and approx 6000 miles ago I replaced the bias ply 7.00 X 15 to ST225 75 R15 Denman tires. A couple of weeks ago I was headed out camping and as I was checking the air pressure in the tires I noticed that the right front tire had cracking around the bead area of the tire next to the rim. The cracking is about 1/8 of an inch deep in some places. There are no other cracks on the tire like you would normaly see from weather cracking.
The left front one is starting to do it also. I took off the right front one went to the local tire shop. Had it dismounted and let them check it. The said they had never seen that before and it was probably just weather cracking and it would be ok. I dont buy the weather cracking only at the bead area right next to the rim. I dont know how safe it is. The tires were manufactured in May of 2002. Anytime I am pulling it the tires are always inflated to the max psi on the side of the tire which is 65 psi these are load range D tires. The last thing I was wondering is that when I had the tires put on. I noticed that the rims are not a conventional type. When I say that I mean the rim edge different to say a regular auto rim. When the shop balanced them they had to stick the weights on the inner diameter as the regular tire weights would not work on the rim edge. I am wondering if this rims bead area radius is too sharp and its stressing the tire at the bead area. Also these are aluminum wheels.
Any insight would be appreciated.
72 Excella500 is offline   Reply With Quote
Old 06-09-2004, 06:22 PM   #2
Retired.
. , At Large
I will try to answer your questions in order:
I have seen this cracking before, usually because the tire was overinflated, or used non-radial approved wheels with radial tires. Radial tires have a rounder cross-section than bias tires, which have straighter sidewalls.
Weather checking, also known as dry rot, shows up most often further toward the tread of the tire. Excess heat can also contribute to a tire deteriorating near the rim, but you would probably notice this as dragging brakes, and smoke coming from the hub area.
Something to think about, have you checked to make sure your rims are capable of having the 65psi pressure? Most rims have a maximun weight and tire pressure stamped on them.
As for the wieghts, putting them all on the same side will cause a counterbalance, and can actually cause more vibration than if you hadn't balanced them at all. Special weights are available for these rims, and even if they can't get them, there are always the old fashioned tape-a-weights.
I think it would be a good idea to replace your tires with a good name brand, first-line tires are usually made in a foreign country with minimal quality control. Most folks here prefer Goodyear Marathons, they are a quality tire, with nationwide availability and waranty coverage.
One more thing to check, make sure your rim is 6" wide, if it is too narrow it can cause problems like this.
Old 06-09-2004, 08:09 PM   #3
Thanks for responding. The tire weights are the stick on kind. I didnt find anything on the wheels that say anything about pressure or weight capacity. One odd thing I did see when I had the tires replaced was the one rim said INDY in the middle. I am leaning to what you said about the radial tires on rims that were originaly designed for bias ply tires.
Old 06-10-2004, 11:10 AM   #4
till's Avatar
Lisle , Illinois
Images: 108
So is it safe to say that if the "original rims" are from a bias-ply time, then they need to be replaced when you go to new radial tires??
Tedd Ill
AIR#3788 TAC IL-10
No trailers...
till is offline   Reply With Quote
Old 06-10-2004, 04:42 PM   #5
Retired.
. , At Large
Not necessarily. Most rims that are not for radial use will say so in a stamping on the rim. The exception to this is, of course, some aluminum wheels made before the early '70's. Which, of course, is where the two of you are at with your wheels.
Very nice looking silver painted steel wheels can be had for your coach for well under $100.00 each, probably more on the lines of being able to buy 4 steel wheels for the price of one and a half aluminum wheels. Chrome lug bolts and center cap would complete the ensemble very inexpensively.
Tedd, as long as your tires hold air now, I would wait until you are almost ready to put it on the road before investing in tires (and wheels), because the clock starts ticking the day you get them. 5-7 years will pass faster than you realize, and it is not something that buying now will save in the future.
Old 06-10-2004, 07:53 PM   #6
till's Avatar
Lisle , Illinois
Images: 108
Terry,
I'm in no hurry to get the rims and tires replaced. That will wait till the shell is back on the repaired frame. I think that black rims with the chrome hub caps will look good.
Tedd Ill
AIR#3788 TAC IL-10
No trailers...
Old 06-11-2004, 08:30 AM   #7
I think I will replace my wheels. Can anybody tell me anything that I should know other than I need to get wheels rated at 2600 pounds and use load range D tires. Are the wheels supposed to have any kind of offset?
Old 06-11-2004, 09:51 AM   #8
Rims have not been used for over 30 years.
That term, however wrong, come from the days of the "split rim wheels."
By definition, the "rim" is the outer part of a wheel, which of course has no use to an Airstream owner.
Lets get the newbies on the right road instead of perpetuation a misnomer, by todays standards.
The correct wheel is 15" X 6" with 6 holes on a 5 1/2 inch bolt circle, zero inset, with a rating of 2600 pounds.
Junk yard wheels are a "disaster" in the making. A "spare" is supposed to be a "for sure" and not a "maybe."
Safety, safety. It can "never" be said enough. Lack of it, creates liability, which keeps attorneys and courts, very very busy.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 06-11-2004, 10:04 AM   #9
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Andy, what about the "radial vs. bias-ply" question? Is it ok to put radials on my original 2600# rated 15"x6" wheels?
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 06-12-2004, 10:05 AM   #10
Chuck.
As they say in Hawaii, "cousin, it's OK."
Andy Rogozinski
Inland RV Center
Corona, CA
Old 06-12-2004, 12:03 PM   #11
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Chuck.
Great! thanks!
now, one step further: would it be preferrable to use one over the other?
Air:291
Wbcci: 3752
'73 Safari 23'
Old 06-12-2004, 12:10 PM   #12
Chuck.
Radials are far safer and have less problems.
I have to go with Airstreams choice.
Since they switched to radial tires, the tire problem has been greatly reduced.
Also, regardless of the type tire, proper running gear balance always insures a softer ride for the trailer as well as tire longevity.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 06-12-2004, 02:58 PM   #13
Retired.
. , At Large
Thanks for the correction, Andy. My using "rims" is from when I started doing this stuff, over 30 years ago. Old habits (and terms) die slowly.
Old 06-12-2004, 03:11 PM   #14
Argosy20.
I know, but our new generation has no idea what we older folks are saying.
Just like we don't understand, "you know what I'm saying," or, "you know what I mean." Whatever!!
Maybe we should call the new generation language "English 2."
Andy Rogozinski
Inland RV Center
Corona, CA
Old 06-12-2004, 03:16 PM   #15
Images: 59
Argosy20.
One thing our older generation is good at is learning. Today, I also learned that 'rims' is the incorrect terminology. Out with the old, in with the new.
I always thought that a 'wheel' was a rim, with tire mounted; a complete and functional assembly.
Good Axle/ Bad Axle blucloud Axles 2 05-23-2004 04:15 AM
Take the good with the bad. Katt Doors & Locks 7 04-05-2004 10:32 PM
bad day airstreaming beats good day a power company part 2 john hd Off Topic Forum 9 02-13-2004 08:12 AM
bad day airstreaming beats good day at power company! john hd Off Topic Forum 5 01-29-2004 04:04 PM
The good and bad TRAPEZE Airstream Motorhome Forums 1 01-01-2003 06:21 AM
