06-30-2015, 09:42 AM
2010 28' Flying Cloud
Lower Alabama
, USA
Tires - Good insights for one and all!
Too often I see a basis of opinion presented like, "I have towed for 35 years and never wrecked, so I know what I am talking about" or "I am a former politician, old and wise, have three graduate degrees, . . . "
Advice based on raw luck or multiple advanced degrees in social science doesn't give me comfort when making serious decisions on equipment and how I use it.
Here is a blog by a tire engineer. I find the information presented on RV tires by this gent to be very helpful and based on real data vs. "I have never wrecked". I discovered it in another thread here on the forum and wanted to point it out in a separate thread in the hope that it may help you too.
RV Tire Safety: "Interply Shear" and other Techno Babble
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
06-30-2015, 10:04 AM
Spokane
Thanks Alan for this information. You are quite right, a forum is a place for people to voice opinions and many will quote all sorts of stuff to strengthen theirs. It gets comical if you look at it in the right light.
I wish he would have discussed the ongoing controversy between RV tires and LT tires. I have heard so much on both sides but am still in the dark.
06-30-2015, 10:38 AM
2012 27' Flying Cloud
W
, New England
Isn't that Tireman9's blog? He contributes to the tire discussions here quite a bit!
06-30-2015, 10:59 AM
1974 Argosy 20
Kooskia
, Idaho
I agree that often anecdotal information and appeal to authority is not necessarily proof of anything. However, experience does have some merit, and especially experience referred to to contribute to a collective mindset of effectively what would be "long term tests". I replied to a post the other day about lube for leveling jacks. Several people responded as I did that I had good success with WD40 as a lube. In my case for over 35 years. I think there is some value there in the collective experiences.
It is a very difficult area. When does repeating something which is wrong enough times make it collectively right? That happens very commonly, but the thing is still wrong and becomes very difficult to change peoples views on it.
Our individual views on things like hitches are a prime example. We don't usually have a lot of experience with different hitches over our lifetime, so the one we have is usually OK, unless we get one we like better, then it becomes the best (compared to our other experience). That does not make it the best hitch however, and certainly not best for each and every combination of tow vehicle and trailer.
So, again, collective experience MAY have some value. And yet, it may not. It is very difficult. I wish there was a simple answer, but I don't see one.
06-30-2015, 11:41 AM
Ravenna
, Ohio
I think if you visit the blog and use both the "label" list on lower left and even the search box in upper left you will find a number of posts and comments on LT type tires on towables. Even have one specific to what I believe an owner MUST do if considering a change from ST to LT type tire.
You might even want to set a goal of working through the 200+ posts over the next couple of months. I wouldn't expect anyone to remember all the info but at least you would know that a topic was discussed and could then go back and review the details.
AS forum rules do not allow me to post direct link to my own blog even if I have a post on the specific question being asked, so I do try and follows the TOS here.
It gets a little tiring entering the same reply to the same questions over and over on the ten RV forums I try and monitor so one one forum I started to post links tot he posts with answers. This resulted in my being banned from that forum so those folks are on there own now.
PS Thanks Alan
Retired tire engineer (50 years). Write a blog on RV Tire Safety Net. Give seminars for FMCA across the US. Tucson AZ in Mar 2024 is next.
06-30-2015, 11:58 AM
Lower Alabama
, USA
Yes it is and he does contribute a lot. Search his blog for lots of info.
Alan
Air #64439
06-30-2015, 12:08 PM
2013 25' FB International
Liberty Corner
, New Jersey
Is there a tire that comes close to being ideal? One that would support at least 30% greater load than an AS rating, hold air for a long time, have low cord shear (single steel cord?) and work on 15" wheels....
06-30-2015, 01:01 PM
2012 25' Flying Cloud
Battle Lake
We have more than one tire engineer coming on the forum and they give good information; however they contribute science to the selection of tires for our Airstream rather than personal experience (generally speaking).
We have a great deal of personal experience available on this forum with tires and Airstreams. Collectively it is meaningful to me. There is even a poll of Airstreamers' tire failures relative to brand and size. We have the experience of at least one dealer who has been in business selling and servicing Airstreams for 40 years, who has made suggestions on tire selection, pressures and use.
Genuine experience from a large group is meaningful. Not the fellow who reports 40,000 miles on his GYMs and still going strong, but the volume of fellows who report repeated failures of their GYMs.
And the volume of fellows who report switching to 16" Michelin LTX M/S and none ever having a failure. In spite of the warnings about interply shear from sidewall scrubbing (I'm not a scientist, please excuse the crude terms), lowered pressures, overspeed, overweight, and so forth from the tire engineers.
It is useful to consider the entire body of information on this forum when choosing tires for your Airstream, what pressure to use, and how to use them when installed.
When analyzed in this way, the "default" tire for our Airstream is quite clear to me; the same one Airstream now puts on it's premium trailer.
Doug and Cheryl
06-30-2015, 01:18 PM
2004 25' Classic
Prescott
I have the Continental Vanco 2 15" tires now that have been great, but are getting old ( 6 yrs. old! ). This tire has been discontinued, so now I am looking at the Nokian Rotiiva AT tire. It is an LT tire, size LT235/75R15 116/113 S. Has a max. load rating of 2,760 LB. Still trying to find more info on them, but looks interesting.
Julia & Bob
W/ Deedee & Boo
AIR #30685
06-30-2015, 01:20 PM
Full time Airstreamer
2014 30' FB FC Bunk
Anywhere
, USA Living.Somewhere.Yonder
Add to that a speed rating of over 65 mph (not that I usually go that fast, but it's nice to have headroom) and we can double the order to save shipping!
@living.somewhere.yonder | Instagram
06-30-2015, 01:47 PM
2002 30' Classic S/O
Garden Valley
, Idaho
There's an old saying that "it's not worth a Continental", and I sure found that to be the case, at least on new truck tires that have come with them installed. I refuse to run any Continental tires, regardless. You might can find some off brand tire that has a similar or the same specs, but IMHO you still can't beat what the majority of folks on this forum have gone to on their As and many of their tow vehicles, and that's the Michelin E rated MS/2's.
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
06-30-2015, 03:11 PM
Full Time Adventurer
2007 27' International CCD FB
Nomadic
, USA
Touching on this point, folks often equate experience with wisdom or that experience means you're right. But folks can do something wrong for 30yrs and luck out and still be WRONG in the end. If that makes sense.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
06-30-2015, 04:27 PM
1972 25' Tradewind
McHenry County
Also consider the technological changes in 35 years.
Materials and manufacturing advances change the equation. Good or bad. Your call. That's another thread.
My ’67 Globetrotter had an original spare tire laying in the trailer when I bought it. It was labeled 600 15 8ply House Trailer. It was good enough then, why not now?
Today even things 10 years old are obsolete and it's recommended tires be replaced after 5 years. Science marches on.
Tom.
06-30-2015, 05:06 PM
2014 31' Classic
2015 23' International
Apache Junction
I absolutely no prior RV experience before I picked up the first Airstream. I did have GYM ST model tire failures on my dual axle 10,000 pound rated motorcycle trailer where the tread delaminated from the tire. I have seen many types of trailers beside the road with tire failures.
I found this forum and did a lot of reading, especially in the tire forums. The continuous discussions about tire failures and the damages caused by such an event encouraged more reading to discover if there was a tire that was more reliable.
My personal experience with the one brand that I have been using exclusively for over 45 years on my cars and trucks encouraged me to install that same brand mentioned over and over again (in an appropriate size).
I decided that I would install Michelin tires on all future Airstream trailers.
06-30-2015, 07:34 PM
1995 25' Excella
xxxxx
, xxxxxx
I am looking for the same info. I plan to put tires on my 25 ft Excella in the next couple of weeks.
06-30-2015, 07:59 PM
Liberty Corner
, New Jersey
06-30-2015, 08:08 PM
1995 25' Excella
xxxxx
, xxxxxx
Well, the Carlisle Radial RH was on my short list even before reading that article.
06-30-2015, 08:39 PM
W
, New England
Interesting - apparently even in the Greenball 22575r15 the speed rating is L or 75 mph which would allow someone to regularly keep it sub 65 but occasionally pass at 75 if needed without worry (well - that's not completely true :-).
Very interesting!
07-01-2015, 08:17 AM
Ravenna
, Ohio
Be careful with the new all steel tires comming to the market.
I'm not saying they may not work but when doing some research I discovered that the people you may talk to at the retail level do not know a lot about tires and certainly not much about RV application.
Many low cost tire distributors seem to have order takers answering the phones.
Info on web sits may be incomplete or even incorrect such as mixing LT tire info with ST tire info simply because the tire measurements were similar.
Load Range vs Ply Rating info may or may not be correct.
You may need to know more about tires than the salesman does.
07-01-2015, 08:32 AM
Ravenna
, Ohio
It's fine to choose the collective thoughts as long as you understand that even the majority can be wrong.
RE the Poll on tire failures. Too many confuse failure with proof of a defect and certainly many don't seem to differentiate correlation with causation.
I have previously pointed out that according to the posts on this blog, RV trailers built by workers living in the area where the ZIP code starts with 45xxx have a very high percentage of problems so the workers must be bad at their job so you shouldn't buy the RV brand they build.
See the problem?
I suggest you read this post and this one about the quality of the information in the poll.
