Old 07-04-2015, 01:07 PM   #43
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Originally Posted by avionstream View Post
Curious, what did the T man have to say?
I think he covered it above, but the conversation starts here and goes through the next couple posts.
Originally Posted by AtomicNo13 View Post
Was that an e rated Carlisle?
D rated.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 07-06-2015, 11:46 AM   #44
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Originally Posted by SCOTTinNJ View Post
How about putting it this way. What would you suggest in a 15" tire on stock rims for a 8800# gvwr trailer? Serious question. My exact trailer spec.
Since no one addressed your question and with no other data I would seek a tire with a load capacity of 2600#.
However you might want to weigh your trailer hooked up to the TV in it's maximum capacity. Or add weight for things like full water tank if you weighed the trailer with empty water, waste, grey water & propane tanks. Assuming that number is less than 8800#s, divide that number by 4 and divide that number by 85. Move the decimal to the right by 2 places. Round up to the nearest 100. Then I maintain tire pressure at max load as this is what I expect out of the tire. BTW I rarely travel faster than 65mph and this is a factor for capacity.
If you weigh the trailer and the axle load is greater than rated GVWR you will need to put the trailer on a diet! RVs like many humans gain weight as they age.
For what it is worth this is what I do. Others may have a different input or thought process or what ever. There is a margin built into the above and running at less than full load increases that margin.
>>>>>>>>>>>>Action
Old 07-06-2015, 11:51 AM   #45
Gainesville , Florida
Again Maxxis e rated ST tires will do just fine.as I posted earlier in response to this question. Maybe it was deleted.
Old 07-07-2015, 10:25 AM   #46
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Determine the axle rating for the trailer. The tire rating should, at the recommended inflated pressure, equal or exceed the axle rating.
The OP has a 2010 Flying Cloud (per his signature) and the 2010 parts manual stated it came with 3,800 pound rated axles. In a perfect world, each tire would need to support at least 1,900 pounds.
In weighing the individual wheel locations on our 2013 25FB, which also had 3,800 pound rated axles, we have found that there is one tire that carries nearly 200 pounds more than the others. The 25 FB right rear had the most load. The Classic had three at nearly the same weight and the left rear was lower by 150 pounds partially due to the removal of the water heater with 6 gallon storage capacity tank.
While the total weight of our Classic camping ready was 9,261 pounds, the two 5,000 pound rated axles were supporting 8,064 pounds. Thus, the factory installed Load D Goodyear tires rated at 2,540 pounds each had adequate load capacity with nearly a 25% reserve.
So the issue on lighter Airstream trailers may not be Load D versus Load E, but the quality of the materials used to build the tire and proper inflation at all times.
Tires...Tires...Tires Bob Thompson Tires 277 07-30-2015 01:30 PM
Argosy Airstream Motorhome 1974 24' Rear bunk bed all options All new tires eBay Watch Airstreams on eBay 0 10-13-2013 03:40 PM
All-terrain vs. All season tires ESCAPE POD Tow Vehicles 5 01-19-2010 01:38 PM
Satellite TV AND Radio, Theatre-like Sound, Cable, iPod, and Bluetooth all in one!!! 78GussyTX Audio, Video & TV 12 11-12-2008 09:36 PM
Help tires, tires, tires. jimmini Tires 9 10-18-2008 07:54 PM
