Old 08-07-2009, 09:29 PM   #15
Benjo's Avatar
1949 18' Trailwind
Huntsville , Alabama
Good illustrations for tire measurements.
Benjo is offline   Reply With Quote
Old 08-08-2009, 04:51 AM   #16
shermybaby's Avatar
1956 26' Cruiser/Overlander
Kennewick , Washington
Images: 13
Send a message via Yahoo to shermybaby
Thanks. stumbled onto them a while back and thought they would be appropriate here.
shermybaby is offline   Reply With Quote
Old 08-10-2009, 08:14 PM   #17
Benjo's Avatar
1949 18' Trailwind
I do believe i will need a 7.00 x 16. I will drop by a tire dealer to make sure.
Looked on Coker and they want an arm and a leg for a tire that size. Aren't there any other options???
Old 08-11-2009, 02:05 PM   #18
Benjo's Avatar
1949 18' Trailwind
I thinking about these tires:
Bias Ply Trailer Tire Size 7.50-16E
Old 08-11-2009, 04:04 PM   #19
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
I have no problem running bias ply tires on our 53 Victoria, after all that's what the suspension was designed around.
A modern quaility bias-ply, e rated trailer tire, mounted on steel wheels should do fine.
Ran them on our 63 Safari for 12 seasons with no problems. Just pay attention to them and use the best wheels.
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 08-11-2009, 04:22 PM   #20
Benjo's Avatar
1949 18' Trailwind
Looks like I'll be using a tube on my setup. Do you run a tube or tubeless?
Some feedback on that issue would be great!
Old 08-11-2009, 06:14 PM   #21
shermybaby's Avatar
Images: 13
I currently have bias ply tires with tubes on my '56 and they hold air like nothing else. My tubes are real rubber and not butyl and leak very little air over time. I will have to replace the tires though and been thinking of new aluminum wheels with tubeless radials...easier replacement available on the road if there is a problem.
Old 08-11-2009, 06:45 PM   #22
Benjo's Avatar
1949 18' Trailwind
"easier replacement available on the road if there is a problem" the thought has crossed my mind more than once. What size wheel/tire are working with?
Old 08-12-2009, 01:10 PM   #23
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Tubed tires, not just bias type, run quite hot compared to radials.
Yokohama RY-215's are available in 7R-15 (7.00 x 15) in a Load Range D radial; I used them on my trailer. Do not know if they are too heavy for yours (2,040-lbs per tire at 65psi).
I would be careful about tire height and section width, not just load capacity. The wheel should also be load-rated. Were it me I would be replacing all studs and lug nuts, too.
Old 08-13-2009, 01:41 PM   #24
1984 31' Excella
Norfolk , Virginia
Images: 11
Wheels
Here is how you measure a wheel:
Great diagram of Wheel Backspacing and Other Measurements - Chevy Truck Forum - GMTruckClub.com
This gives you the definition of off set and back set with a picture.
Beginner
Beginner is offline   Reply With Quote
97 Airstream 19 1/2 ft Class B Generator New Tires Ford eBay Watch Airstreams on eBay 0 04-04-2009 01:00 AM
97 Airstream 19 1/2 ft Class B Generator New Tires Ford eBay Watch Airstreams on eBay 0 03-21-2009 01:13 AM
Tires, anybody ever heard of Specialty Tires of America? lebolewis Tires 3 06-08-2006 04:11 PM
Free Vintage rims w/tires jlawrence Tires 1 11-12-2005 06:52 PM
