Old 03-28-2011, 12:55 PM   #1
timzog's Avatar
1980 20' Caravelle
Ogden , Utah
Tires for 1980 Caravelle 20'
I am trying to find tires for my single axle Caravelle. It has 15" wheels. The manual says 7.75x15ST, Load Range C, inflated to 35 psi. I did some online searching and couldn't make sense of these requirements. Can anyone help me find a good supplier and give me suggestions on brands. I've read that bias ply are superior for trailers, but I am willing to listen to experience. I believe GVWR is 3500 pounds.
Tim
timzog is offline   Reply With Quote
Old 03-28-2011, 01:35 PM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Tim!
My Minuet shares most specifications with your Caravelle. I have been running Goodyear Marathon ST tires in the following size:
ST225/75R15
While load range C was acceptable for the coach, I elected to go with load range D for a wider margin of excess capacity. I know that many have had problems with the Marathons, but I have had nothing other than good luck with mine since 1981. My only deviation from Marathons for my coaches was in 2008 when I couldn't source a set and had to settle for Carlisle ST tires in the same size and rating -- and thus far, I have been satisfied with their performance on my tandem axle Overlander.
My first tow on both of my coaches was on bias ply trailer tires -- and in my opinion, the radials offer superior control and performance.
Good luck with your investigation.
Kevin
Kevin D. Allen
AIR #827
caravelle
Eddie Bauer AS uses Michelin Tires? Secguru Tires 67 05-29-2014 12:33 AM
White letter tires on Airstream Road Ruler Tires 2 03-09-2011 07:14 PM
Tires and tire size KyMoonshine Tires 5 03-08-2011 04:28 PM
When to start thinking about replacing tires? bonginator Tires 2 02-18-2011 02:16 PM
How do you install new tires? Steve & Susan Tires 23 02-16-2011 03:37 PM
