Old 02-26-2010, 06:02 PM   #1
1978 31' Excella 500
Toronto , Ontario
Tires for 1978 31 ft Excella
Can someone suggest a replacement tire for the 700 X 15's ? They are currently on the original aluminum rims . I have been offered a 12 ply . Isn't that overkill ?
78ourstream is offline   Reply With Quote
Old 02-26-2010, 07:38 PM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Hi, and welcome to the forums. You only need a load range D tire, so yes, the 12 ply is a bit much. You can go with an ST225/75R15 tire, which is close to the 7.00x15, or you can still get LT7.00x15 tires, though they can be a bit tough to find.
Old 02-27-2010, 05:53 PM   #3
Toronto , Ontario
Thank you Terry , I was wondering whether I could go radial after the bias plys .
Old 02-27-2010, 07:00 PM   #4
Toronto , Ontario
I do have another thought . I have been given a tentative price of $90 each installed , not sure of the brand ( still being sourced ) . Will the 12 ply be too hard of a ride ? I am worried about the trailer being jarred too much . Probably good for tire life and rough roads though . I have read of tires blowing , etc and not being able to tell from the TV . It did happen to me with my 68 Overlander ( now long gone ) . Thnx
Old 02-27-2010, 09:07 PM   #5
1980 31' Excella II
Drummond Island , Michigan
You do not need 12 ply tires. They are designed for stock and equipment trailers and are very stiff. Also the max inflation pressure for those tires exceeds the safe limit for your rims and valve stems. There is another caveat about running higher pressures in older rims that have run at much lower pressures all their life. A 225/75R15 ST tire Load range D will be more than adequate for your needs. They are common, easy to find and relatively inexpensive. The radials are slightly wider than a 700-15 bias ply tire. This subject has been discussed extensively in other threads in the forums which can be researched easily. I have an '80 31' Excella running 225/75R15 ST without a problem. However I must caution you that trailers as old as ours generally have experienced axle suspension failure ie. the rubber rods in the torsion tube have degenerated to the point there is little or no suspension travel and literally before we replaced the axles the only bounce in the suspension in our trailer was in the tire sidewalls so be carefull.
Ahzmyrah is offline   Reply With Quote
Old 02-28-2010, 08:50 AM   #6
Toronto , Ontario
Tires for 1978 Excella
Thank you , so much help so fast . I will go with the radials . I am planning a trip out to the East coast for a month . I don't want to be stuck having to run mismatched tires if I have a blowout . How can I know the condition of my axles ? Can they be checked when I am changing tires ? Thnx
Airstream 1978 excella 500 31 ft 1 owner eBay Watch Airstreams on eBay 0 02-09-2010 11:40 AM
1978 Airstream excella 500 eBay Watch Airstreams on eBay 0 10-10-2009 03:10 PM
Looking to Purchase 1978 Excella 500 Sarafina 1978- 1979 Excella 500 6 03-22-2004 09:37 AM
1978 Excella door lock startrekker2001 Doors & Locks 0 08-28-2003 01:59 PM
1978 Excella 24' Motorhome billhabing Airstream Motorhome Forums 3 04-16-2003 11:57 PM
