Old 08-15-2010, 04:56 PM   #1
Goldthwaite , Texas
Tires for 1962 Overlander
What tire is best to replace "split rim" wheels set up?
R. House is offline   Reply With Quote
Old 08-15-2010, 05:24 PM   #2
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Use a 6 lug wheel trailer wheel rated @ 2800# ,there is several discussion and opinions on best tire and D or E load range,you make that choice. Dave
easyride is offline   Reply With Quote
Old 08-15-2010, 06:29 PM   #3
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings R. House!
Welcome to the Forums and the world of Vintage Overlander ownership!
I believe that the '62 Overlanders take the same wheels as my '64 Overlander. The new wheels that I purchased for my Overlander met the following criteria:
  • 15" x 6"
  • Zero Offset
  • 6 on 5.5" Bolt Circle
  • 4.25" Center Hole
  • 2,600 pound Weight Rating
My suggesting would be load range D if you have a tandem axle Overlander or load range E if your Overlander happens to have been one special ordered with the single axle . . . .
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Old 08-15-2010, 06:40 PM   #4
We suggest the Goodyear Marathon, load range "D".
However, the most important thing to have done, is to have the complete running gear balanced.
Tire, wheel, hub and drum, as an assembly.
Unbalanced running gtear, is subject to fail, regardless of the brand.
Many people blame the tires, instead of improper balancing, or none whatsoever.
There isn't a tire made, that's perfectly in balance, nor is there a hub and drum that's perfectly in balance, either. Wheels, maybe??
Old 08-18-2010, 03:59 PM   #5
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
New rims and I second Kevin's suggestion or the "D" rated tire for your double axle Overlander.
I would also suggest a tire brand that can be serviced (if a warranty issue comes up) nationwide if you do a lot of traveling.
>>>>>>>>>>Action
1962, 1962 overlander
NEW to the USA with 1962 26' Overlander! malinki Member Introductions 5 05-12-2010 12:19 PM
1962 vintage Airstream Overlander restored eBay Watch Airstreams on eBay 0 08-01-2009 11:20 PM
My New 1962 Overlander Project BarryIowa 1960 - 1964 Overlander 226 06-25-2009 06:30 PM
1962 Overlander Curtain Sliders gnored Upholstery, Blinds, Walls & Interior Finishes 0 06-12-2009 10:35 AM
looking for other 1962 Overlander owners Frank's Trailer Works 1960 - 1964 Overlander 14 03-21-2009 04:44 PM
