Old 04-18-2018, 12:36 PM   #1
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
Tires and TPMS choices
So, looking for some direction now on tires and TPMS.
For tires, with 15" wheels, seems like lots of folks are holding out that the new GYE's are a good choice. Since Michelins don't offer a LT in that size now, and the GYE's are much less expensive, wondering out loud if that is worth the risk or should I upgrade wheels to 16 and stay with Michelins?
On the comments about internal installed TPMS vs external, what is the recommended solution/brand?
2017 28' Twin Flying Cloud
2017 F250 King Ranch, 4X4, Blue-Ox WDH
Summer in Lincoln, MT- Winter in Austin, TX
Old 04-18-2018, 02:51 PM   #2
1986 31' Sovereign
Miami , Florida
I have GYEs but only about 1500 miles on them so no useful data. My TPMS is a dead simple, external system called a Pressure Pro. You do need metal valve stems. There are lots of reliable systems, just do a search.
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 04-18-2018, 03:17 PM   #3
r carl's Avatar
Lin , Ne
How much weight is going to be on your tires?
Old 04-18-2018, 07:28 PM   #4
TSchleff's Avatar
2005 30' Classic
Omaha , Nebraska
We are having GYE tires put on the Airstream tomorrow. From what I gather by reading other posts people seem to be having a good experience with them. I have to tell you I have pulled our trailer for 40,000+ miles on two sets of GYMs and never had an issue. I guess I was just lucky because there was obvious problems. I just wasn't aware of the issues. But we do store our trailer indoors and I'm very religious about checking the air pressure and travel around 65 mph (actually 67 was my preferred speed) on the road. I hope we have good luck with the GYEs as well.
Regarding the TPMS I have the EEZTire Pressure Monitoring System, which I will have to adjust with the new tires, but have had excellent luck with that system and would highly recommend it. I purchased the "security" version, but I think I will take off that portion as I really don't think people will steal the monitors. (I no sooner say that and they will "walk away".)
TSchleff is offline   Reply With Quote
Old 04-19-2018, 11:15 AM   #5
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
We installed the Dill 1506-453 TPMS on both trailers. Purchased from and installed by a local Discount Tire along with 16" Michelin LT225/75R16/E LTX M/S2 tires mounted on 16" SenDel T03-66655T wheels on our 2014 31' Classic and 15" Michelin LTX (P) 235/75R15 XL tires mounted on 15" SenDel T03-56545T wheels on our 2015 23D International Serenity.
Old 04-19-2018, 12:03 PM   #6
Mollysdad's Avatar
I'm doing a grand experiment.
I bought two different styles of metal valve stems, Dill TR-416, and Dill 902-W. When I get the wheels off, I'll know. Then I've ordered a "Beadbreaker 450" and decided to install the valve stems myself. I hope I don't regret it, but if I break the bead near the valve stem, cut out the rubber stem, I should be able to install the new metal stem and re-inflate the tire without a visit to the tire store.
Adding the TPMS should then be a piece of cake.
I'm leaning towards the TST 507 external with color monitor.
Old 04-19-2018, 04:23 PM   #7
gypsydad's Avatar
Wow, your a brave man! Since I will be getting new tires, I will let the dealer install for free....just not sure which TPMS to get; internal or external...
For tires, I was told Michelin does not offer the Light Truck tires in 15" anymore so that's the delema also...do I get the GYE's and save some money or do I go up to the 16" wheels/Michelins...decisions....
Old 04-19-2018, 05:19 PM   #8
r carl's Avatar
Lin , Ne
I went with these.
https://www.tirerack.com/tires/tires...omCompare1=yes
Old 04-19-2018, 05:51 PM   #9
2013 28' Flying Cloud
Penn Yan , New York
Tires
Installed Goodyear Endurance last year. Pulled the AS from central NY to south Florida, a few trips across Florida and returned back to central NY. The tires worked great. I have the TST 507 monitors and love them.
Unless you have a tire machine I probably wouldn’t attempt to break the beads to change the valve stems. If this is done at a tire store they will dismount the tires and clean the beads to insure they won’t leak. With the monitors installed have the tires balanced at the same tire store. My opinion.
Good luck.
delrossa is offline   Reply With Quote
Old 04-19-2018, 06:00 PM   #10
Mollysdad's Avatar
Brave, yes; smart? We'll see.
I've been to a number of tire dealers in my city and haven't been too impressed. I was very impressed at Discount Tire, where I sourced some valve stems, but the nearest Discount tire is 40 miles away. Clean, nice folks working there. I couldn't believe a city the size of Tampa doesn't have one.
Plus, if I do it myself I won't have to leave the trailer up on jack stands while I take the tires to a dealer and hope he doesn't mess up something.
I watched a lot of videos on bead breakers, I don't need to unmount the tire, just stick my hand inside. The one I purchased is pretty compact and I figured I'd add it to the tool kit if I ever had to do it again.
I've never been shy about thinking I can do as well as a guy working in a tire shop. I hope I'm right.
I can always go back to tire stores if I decide I need pro equipment.
Old 04-19-2018, 06:22 PM   #11
gypsydad's Avatar
Wow; your a brave man! (still!) If I were there, I would look for a Good year dealer or even a Walmart that has a tire center. (Sears?) My AS dealer here yesterday said they use Walmart to install tires and monitors for customers. May be worth the call...by the way, 40 miles is a road trip...lunch, beer, and their done!
Old 04-19-2018, 07:53 PM   #12
steverino's Avatar
2018 30' Classic
Ivins , Utah
Whichever one you use, watch them like a hawk. A couple of years ago, when I switched to 16" Sendels and Michelin tires, I used America's Tire (which is same company as Discount Tire in California). I was very specific with the service writer regarding where to jack the trailer, and offered to point out the appropriate spots to the technician.
By the time I finished talking to the writer, I walked outside and saw that the trailer was already up in the air on floor jacks, placed on the axles. Grrr. I had them lower it and move the jacks to the axle mounting flange at the frame.
steverino is offline   Reply With Quote
Old 04-19-2018, 09:11 PM   #13
CruizinDux's Avatar
Tracktown USA , Oregon
Here is a recent thread on ALT tire options...
http://www.airforums.com/forums/f438...-179905-2.html
My post #27..
we just returned from a 7500 mile trip to Nashville, etc and back and they were great. Had the GYE's installed a week before departure. Finally worked thru the speed rating issue and margin as suggested by tireman9 (http://www.airforums.com/forums/f438...sa-157249.html) and kept speed to 65 with occasional bursts to pass.
As noted in the #27 post I had settled on the Nokians as IMO a great good LT tire alternative but at the last minute, switched to the GYE's due to good reports, but also not having to wrangle with the spare holder mods as the Nokians are a slightly larger diameter tire for my FC20 requirements.
CruizinDux is offline   Reply With Quote
Old 04-20-2018, 01:01 AM   #14
Mollysdad's Avatar
I'll keep that as plan B. I'd have to do it twice because I'm not towing the trailer there and I'd remove two wheels at a time. My experience with tire shops is they think you're an idiot and they want to knock it out as fast as possible. I hate being the bad guy, but I can. "Let's do it my way."
Thus jacks under the axle and over tightening the metal stem to failure.
Heck, the last time I got car tires, I could't even get them to replace the valve caps, let alone think about service.
Four 225/75R16 LTX Tires on Sendel Rims with TPMS! Powerarrangr Airstream Classifieds 1 05-19-2017 08:56 AM
Why TPMS is worth it - in my case a DILL TPMS DaKarch Tires 2 08-04-2015 09:37 PM
My Battery and Distribution Setup and Choices. crabbey1 Electrical - Systems, Generators, Batteries & Solar 19 09-28-2014 01:57 PM
corian color preferences and vinyl floor choices? 2airishuman General Interior Topics 9 02-28-2005 07:57 PM
choices choices technautica Our Community 7 12-23-2003 06:46 PM
