Old 07-25-2014, 04:21 AM   #29
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Originally Posted by CapriRacer View Post
...snip...
But an increase in load carrying capacity by increasing tire size wouldn't necessarily increase ride harshness (unless the inflation pressure also increases.) In fact, the increased mass of the tire might help the ride harshness.
I'm not sure I understand. Let's say the D is 65 psi max and the E is 80 psi max. If you increased capacity from D to E, would you recommend the E rated tire also be inflated to 65 psi? I thought the idea was for tires on the trailer (whether ST, LT or P) to be inflated to their max. Though I could certainly have that wrong...
Old 07-27-2014, 06:42 AM   #30
CapriRacer
CapriRacer's Avatar
I'm in the , US
But if I move from an ST225/75R15 Load range E to an ST235/80R16 Load Range D, the load carrying capacity increases from 2830# to 3000#, but the inflation pressure goes down from 80 psi to 65 psi, so the ride quality goes up.
CapriRacer is offline   Reply With Quote
Old 07-27-2014, 10:37 AM   #31
2005 19' Safari
GLENDALE , AZ
Just curious, how many have switched to 235/80x16 load range D tires, versus 225/75x16 LR-E tires?
I have 225/75x16 LR-E.
Didn't even consider the 235/80x16, because they were too big (in diameter), and the 225/75x16's were almost identical in size to the OEM GYMs.
Old 07-27-2014, 11:00 AM   #32
W , New England
Thanks. So much to learn!
Kendra K31M tires 10ply with load range E, LeeJ Tires 4 12-13-2013 09:05 PM
Tires for 1987 Excella 8300 lbs. Load Range D or E? barbann Tires 7 05-24-2011 05:33 AM
Maxxis Tires -Load Range? Wingeezer Tires 43 12-11-2010 01:35 PM
1/2 ton tires- load C to load E John Tires 75 03-20-2009 09:15 AM
Increase Load Capability? RDM16CCD Axles 18 03-15-2006 03:15 PM
