Old 09-23-2003, 06:46 AM   #1
1990 32' Excella
jonesboro , Arkansas
Question Tires ?????????
I am back again. I was on before about a tire recall and was satisfied with what i found out untill I found out that my local goodyear dealer could not read. There was not a official recall but they were exchanging some of the old marathons on 5th wheels to the new marathon S series due to side wall blowout from the high weight and lateral movement othe units. The new tire still has 2 ply side walls but the plies are now twice as thick. What I found out from another dealer was that my tires were not 2 years old but 10 years old . They had been well preserved and covered when not rolling. So I am in the market for tires .
ANY recommendations out there ???????? Thanks.
joel is offline   Reply With Quote
Old 09-23-2003, 10:15 AM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
I just got new GoodYear Marathons. 225/75R15 Load Range D
I think they are fantastic, compared to my old tires.
I can recommend them.
Uwe
www.area63productions.com
Old 09-23-2003, 11:33 AM   #3
silverback's Avatar
2006 28' Safari SE
Sierra Vista , United States
Question Load range D for my 22 'CCD?
Our CCD came with load range C tires which may be fine for our weight (4200-5000+). An old airstreamer we met on our last outing with a 28' classic said go to the D's no matter. He said it stopped all his tire problems. What do you think?
KL
silverback is offline   Reply With Quote
Old 09-23-2003, 12:16 PM   #4
5 rivets, 1 loose screw
Rog0525's Avatar
1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
Somebody correct me if I'm wrong but I think Airstream equips their new trailers with Goodyear Marathons. I bought 2 load range D's for $80 each at a local tire store.
Rog
Rog0525 is offline   Reply With Quote
Old 09-23-2003, 12:34 PM   #5
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
What I found out from another dealer was that my tires were not 2 years old but 10 years old.
If they are ten years old, they should be replaced regardless of the miles or appearance. We too have the Goodyear Marathons...
Shari
Old 10-15-2003, 08:11 PM   #6
Marathon tires
I just got a set plus spare from the local Sams, they sure put a lot of wheel weights on them to get them ballanced,the old truck tires did not have that many weights on them. They put them inside and out, its a good thing that they do not charge by the pound.
Gene Wissink is offline   Reply With Quote
Old 10-16-2003, 09:21 AM   #7
Images: 59
Tires
Gee, I hope Andy/InlandRV has something to say about this situation.
Sounds to me like the wheel and tire were both out of balance on the same side. Maybe you should take them back and have them rotate the tire 180 on the rim. There has to be a standard maximum weight that can be added before the setup is rejected.
If you decide not to take them back, I would take a picture of the weights so that you will know if any fall off and need replacing.
Old 10-16-2003, 09:52 AM   #8
Images: 55
Sounds like you had your wheels/tires dynamically balanced. This is IMO the best way to have them balanced. Old steel wheels can really be our of balance. I recently had bias ply tires balanced on steel wheels and they must've added 1# per tire inside and out to get them perfectly balanced.
As long as you have an experienced person balancing everything, you should be OK. Check the weights often though to ensure you haven't thrown one off.
Now, make sure you balance your hubs, and then the hub/wheel/tire assy, and you'll be set!
Tripp
Tripp is offline   Reply With Quote
Old 10-16-2003, 11:03 AM   #9
Images: 59
Tires
I assumed (bad me) that since the previous tires didn't take that much weight that the rims weren't that badly out of balance. I would still not want to have 1 lb of lead on a new tire, whether dynamically balanced or not. Just sounds like a lot.
Old 10-16-2003, 12:15 PM   #10
Images: 55
It IS a lot of weight. I was told that your tires could "be in balance" without being "set at zero" or in otherwords, be perfectly balanced, just within spec.
I specifically requested mine to be "perfect", and thats when they suggested the dynamic balancing-balancing inside and outside of the rims.
The tech assured me that it would be fine, as I too had the same reaction. I was like "WHOA! whats going on here?!".
Mine were also with my bias ply Carlisles. I was switching them out from the factory mags to steel wheels. (I'm having the mags polished and installing them with Marathons for my 73 31' that I'm currently restoring.)
The Carlisles are 'C' range for my 25' Tradewind.
Tripp
Old 10-16-2003, 02:06 PM   #11
Images: 59
Tires????
I really wasn't aware that anyone (except Andy at Inland RV) still did bubble balancing. All my tires for the last 20 years have been dynamically balanced. Also, I really don't follow the logic that more weight means its more perfectly balanced.
I had a pair of 11R22.5s mounted on the steer axle of my Peterbilt and I don't think they took over a 12 oz of lead.
Keep at 'em
Don in Minnetonka
Old 10-16-2003, 05:15 PM   #12
wheel balance
The most weight that I found was 7 1/2 oz on one tire, it looked like a lot until I added up the numbers, I thougtht the new axle assemblies were balanced.
Old 10-16-2003, 06:53 PM   #13
Images: 59
Tires?
I just bought a new axle and hubs-I plan to balance the hubs before I mount them. When I asked the Dexter rep who he would recommend, he said"Nobody balances their hubs!"
I suppose that includes the factory.
Old 10-17-2003, 12:49 PM   #14
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Factory balance
Don,
Especially the factory does not balance hubs. Not that they do not care. It's just that time vs: money thing. The less the factory (any manufacturer) has do to to get the unit to acceptable tolerance the better place in the market. Typically warranty dollars come from a different "pot" so if work has to be done later it does not effect the market price.
This is the difference between mass production and a individual's taste. Because some individuals may want that and others may not. There are different uses for the unit. If an individual wants an Airsteam for a 2nd home to be moved very little, tire/wheel balance is not a high concern.
And yet if you have the opportunity to balance the hubs seperate from the tire/wheel assy I would encourage it. And then again I usually move to over do things given a choice.
>>>>>>>Action
LT versus ST tires on a trailer 76Argosy Tires 18 08-29-2014 04:03 PM
Tires Causing Sway? Pick Tires 14 12-03-2006 04:38 PM
Questions about trailer tires... cactushead Tires 2 10-22-2003 05:58 PM
need quick opinions on tires... vbob Airstream Motorhome Forums 14 03-01-2003 07:22 AM
tires? trailer will sit after move goodgrey Tires 4 12-06-2002 02:10 PM
