Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Tires
Old 03-21-2008, 09:27 AM   #1
lisa.bivens
Profile:  2008 25' Safari SS SE
Memphis , Tennessee
tires
I have a 25 ft. Safari SE 2008. My tires state max. PSI 65# but I was told to keep 50 - 55# for a smoother ride. I am driving to Calif. and wondered if I should keep at least 60# in the tires (due to things I have read). Any suggestions?
Also, I have a few small scratches (light) on the exterior of my A/S. Any suggestions to remove them without hurting the finish? Thank you.
lisa.bivens is offline   Reply With Quote
Old 03-21-2008, 09:36 AM   #2
2airishuman
2airishuman's Avatar
Profile:
hi lisa and welcome to the forums!
just inflate the tires to 65psi and keep them at that pressure (check each morning when cold)
IF you plan ever to drive 65mph or faster that's the ideal pressure.
IF you weigh the trailer and KNOW how much weight is on each tire,
they might safely be inflated to 50 or 55 or 60 psi BUT that's only if you know the weight figures and never exceed 65mph...
most rv tires FAIL from under-inflation.
also be sure to check/inflate the spare tire before the trip!
for scratches here are a few suggestions...
http://www.airforums.com/forums/473677-post5.html
http://www.airforums.com/forums/504360-post11.html
have fun and enjoy the drive!
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 03-21-2008, 09:41 AM   #3
Rebee
Profile:  2007 30' Classic
Leonardtown , Maryland
tires
I run 65 to 70 lbs in mine. I am not too worried about the ride as much as heat build up and the flexing of the side walls. With long runs the more air pressure the firmer the side walls will be and the cooler they will run.
_________________
Rebee - WBCCI #1325
2002 Classic Ltd 30'
2007 Dodge 2500, 6.7 Cummins
Rebee is offline   Reply With Quote
Old 03-21-2008, 11:32 AM   #4
lisa.bivens
Memphis , Tennessee
Thank you 2air' for your suggestions. I was told to use McGuire's car wax to remove scratches. Have you ever tried this or heard of any results with the wax? Lisa
Old 03-21-2008, 01:10 PM   #5
Roadtoaster
Roadtoaster's Avatar
Profile:  2006 28' Classic
Byhalia , Mississippi
Welcome to the Forums Lisa. Lots of good info here. I work in Memphis live just south of Collierville. Glad to help when I can.
Greg
(formerly known as ptrvr)
Roadtoaster is online now   Reply With Quote
Old 03-21-2008, 02:06 PM   #6
henw
Cyclist
henw's Avatar
Profile:  2007 28' International CCD
Windermere , Florida
I run 55 lbs. I'm worried about too stiff a ride for the trailer. Beating things apart. I check my tire temperature. The sidewalls never exceed 110 degrees in the Fla summer.
Tom
2007 28' Int CCD.
2008 F 250 6.4L Diesel.
DTV 5lnb on a tripod.
Wilson wired repeater with YAG.
henw is offline   Reply With Quote
Old 03-21-2008, 02:24 PM   #7
jcanavera
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Lisa, I would take the advice that 2air gave you. You lose 1,560 lbs. of weight capacity by lowering your cold air pressure from 65 to 55 psi. Unless you are going to weigh your trailer with its normal camping load and consider the liquid weights in the holding tanks, you are spinning the wheel of chance. Under inflation is a major concern and the speed you tow at is a contributing factor. Your trailer should be able to keep its rivets intact and you should be a lot more at ease by maintaining the 65 psi cold pressure.
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.
'03 GMC Savana 2500
'08 Vespa GTS 250
jcanavera is online now   Reply With Quote
TIRES - Which, What and How tetstream Tires 8 09-08-2007 04:39 PM
TV tires Over59 Tires 1 09-06-2006 01:13 PM
Tires, anybody ever heard of Specialty Tires of America? lebolewis Tires 3 06-08-2006 04:11 PM
tires 78 Overlande Tires 13 01-10-2006 03:34 PM
Tires? markdoane Tires 6 10-22-2003 11:30 PM
