After an 8 day involuntary stay with the generator issue, it was down the Natchez Trace. Interesting History.
No hurry to get anywhere the vehicle was looked over daily whereby I noticed a 2" dia bump in one of the rear tires. Not good. Had to drive to a bigger city to find a Michelin dealer, since that's what these are, Michelin Defender LTX, just put on new and barely 5000 miles on them.
Found me a reputable dealer in Baton Rouge LA. The owner of the place did not think it was warranty. He insisted that it must be an installer mistake, a damage bead. I didn't think so because this would have shown up earlier.
We agreed he'd order one new tire to be here the next day. I would pay for it in full if he is right and otherwise ....., he wanted nothing to do with a warranty claim and gave me a number to call Michelin, so I did.
Can't say enough about Michelin's customer service. They answered the call in no time and within minutes I had a case number, no receipt necessary nothing, just name and address and have dealer call us with his findings.
I did not have the best feeling about this shop, though being modern and part of a chain and I was sort of committed to go with the program. No way would I feel comfortable driving with a tire like this. 24 hours later a new tire was there and a service team member was starting the job.
Fortunately, they had to do this outside because there bays were not tall enough. First thing he used a bottle jack to go under the rear of the leaf spring. Huh? "Noooooo, needs to go under the front of the spring or if you have a 3.5 ton long floor jack to go under the axle" Well, he did not have a 3.5t jack, so it was a bottle jack at the front of the spring pack. Next came a pair of pliers to remove the chrome caps from the nuts. "Oh no!" I had requested that they use a socket do remove those. Then he proceed to put an impact wrench to work before removing the chrome hub cap. Oh well ............
He certainly applied his expertise to remove the tire from the rim and after brief inspection no damage could be found on the bead or the inside of the tire.
So it just happened to be a faulty tire, a new one was put on under warranty (immediate response from Michelin) though I had to settle the 49.99(!) bill for the labor, I was on my way once again.
Oh yes, the Defender LTX from Michelin does take 80 psi of air pressure, that is the best way to go at least on the rear tires. One will not notice a difference in ride performance, however mileage is improved as opposed to running in the 55 plus psi range.
