Old 08-22-2015, 08:41 AM   #85
Ravenna , Ohio
To be called and advertised as a "snow tire" there are some minimum performance standards that must be met. Hence the snowflake symbol.
"All-Season" term was introduced 35 - 40 years ago as at that time the bias tires were either summer tires or real snow tires but the then new radial construction and tread designs allowed much better performance in all but deep snow so people no longer needed to change to snow tires in the winter.
Tireman9 is offline   Reply With Quote
Old 08-22-2015, 08:57 AM   #86
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Put on the spare.
Here's a picture of the Swollen-up-athon of Puff-up-athon:
Name:	ImageUploadedByAirstream Forums1440255148.567482.jpg
Name:	ImageUploadedByAirstream Forums1440255167.018392.jpg
Marathon is a good name- good for 26 miles-
I've had Carlisles do the same thing.
No more ST tires for me.
We have a fleet of 14,000# GVW trailers at work- with 16" LT tires-
Oh yeah, I'm getting new lug nuts, too. These cheesy chrome covered ones are terrible- the cover moves around loosely on the nut even when the nut is tight-
It is hard to get a lug wrench on them if they're already distorted/bent out of shape.
Shame on you, Airstream, for putting such garbage on a $94,000 MSRP "top of the line" travel trailer-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 08-23-2015, 06:25 AM   #87
CapriRacer
CapriRacer's Avatar
I'm in the , US
m.hony,
What you have in the photos is called an indentation. It is the place where the body ply fabric is overlapped. EVERY tire has at least one for every body ply (the number listed under "sidewall plies") - sometimes more. They range from barely perceivable to much, much worse than in your photos.
It is NOT a safety issue so long as they are indentations, and even if they are bulges, it is a matter of degree.
As a check, go to any of your other vehicles and look for them.
CapriRacer is offline   Reply With Quote
Old 08-23-2015, 07:04 AM   #88
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
You guys are scaring me, my marathons have 17000 mile on them now, and they still feel good running my hand over them, maybe 1/4 worn....knock on wood they are going on a 3500 mile trip in Sept......
Old 08-23-2015, 09:16 AM   #89
Ravenna , Ohio
Originally Posted by CapriRacer View Post
m.hony,
As a tire design & quality engineer I will attest that this a correct, fact based, description of the cosmetic condition seen in the 2nd picture.
Old 08-23-2015, 02:49 PM   #90
m.hony's Avatar
2013 30' Classic
m.hony,
Look again closely. That is not what I'm talking about. I am talking about hoe across the tread, which should normally be relatively flat, it is all pooched out, distended, rounded, bloated, swollen.
I know those indentations on the sidewalls are normal and all tires have them.
I can find no LT tires in that size.
I guess it's 16" wheels and tires.
TAC #MS-10
Airforums #70955
Old 08-23-2015, 02:50 PM   #91
m.hony's Avatar
2013 30' Classic
Again, I am not talking about the indentations.
TAC #MS-10
Airforums #70955
Old 08-23-2015, 02:55 PM   #92
m.hony's Avatar
2013 30' Classic
How the tire tread should look:
Name:	ImageUploadedByAirstream Forums1440363256.780930.jpg
How the jacked up tire looks:
Name:	ImageUploadedByAirstream Forums1440363318.062874.jpg
Name:	ImageUploadedByAirstream Forums1440363338.635522.jpg
TAC #MS-10
Airforums #70955
Old 08-23-2015, 02:57 PM   #93
m.hony's Avatar
2013 30' Classic
Looks like my quest is for Sendel wheels.
What is the model of Sendel wheel that comes on new Eddie Bauers and Classics? T03? T06?
TAC #MS-10
Airforums #70955
Old 08-24-2015, 05:21 AM   #94
CapriRacer
CapriRacer's Avatar
I'm in the , US
Sorry. It wasn't clear from the first 2 photos, but your followup photos and further descriptions helped clear that up.
What the second set of photos show is very likely a belt leaving belt separation - commonly called a tread separation. In this case, it looks like there is a cap ply in the tire, which is why it is bulged out and distorted, rather than havinf the belt (and the tread on top of the belt) detached.
Old 08-24-2015, 05:56 AM   #95
m.hony's Avatar
2013 30' Classic
16" Sendel T03 and LT tires will happen soon-
TAC #MS-10
Airforums #70955
Old 08-24-2015, 05:59 AM   #96
m.hony's Avatar
2013 30' Classic
All I could envision was damage to my wheel well and trailer skin.
No more ST tires for me. I've had Carlisles do the same thing. Apparently, the tires can't hold to the weight, heat, speed, etc., even though I tow at 60-65 mph with 50-60 psi. I think I've done my part/done the best I could. These tires are just inferior junk.
TAC #MS-10
Airforums #70955
Old 08-24-2015, 06:06 AM   #97
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Tire seperation.
Hi, while on my Alaska trip, I had two seven year old Canadian Marathons separate exactly like your's did. I never had any problems with my Chinese Marathons. These tires are not enough to carry a 30'er. You will be happy with your new tires and wheels.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 08-24-2015, 07:13 AM   #98
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
! TIRED OF TIRE SEARCH- recalls/complaints
I had two E rated Maxxis ST's on the front axle of my Classic do the same thing. I just returned from a 200 mile drive, cold pressure on the tires were 80 psi checked 3 days earlier. I backed into the driveway when I got home and noticed that my wheel locks wouldn't open between the tires. I was really lucky I caught them here at home.Click image for larger version
ID:	246215. Here is a picture of one of the bad tires next to one that hadn't failed. Tires were on the first trip of season 4 of use.
Jack
Jack Canavera
STL Mo.
AIR #56
Tire complaints LFC Tires 2 10-08-2013 04:42 AM
recalls and only recalls.... 2airishuman Electronics & Connectivity 7 04-29-2008 07:28 PM
