Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Tires
Old 06-29-2007, 02:55 PM   #1
Goin camping
Profile:  2007 25' Safari FB SE
valencia , California
Pepsi challenge
When I pull my trailer, Pillows come off the couch, drawers open and everything looks like its been rattled around.
I believe that our wheels etc should be balanced for safty.
I had planned on having Andy balance me up but then decided to put on Disc brakes and get tire upgrades. However I'm going on a 2000 trip before I could put the new discs and tires on.
So I ordered my dyna beads and installed them today.
Here's the challenge part. Will my coushins be on the floor or my drawers self opened and will everything else have that mix master look?
I'll let you know in a week.
NULLUS ANXIETAS
WBCCI 6731 FCU
AIR# 13896
Goin camping is offline   Reply With Quote
Old 06-29-2007, 04:31 PM   #2
flyfisher
flyfisher's Avatar
Profile:  2004 30' Classic
Lancaster County , PA & MT
Airstream uses such cheap door slides and closures that you may never be able to keep things closed. We now use velcro straps to keep several of our drawers closed.
One of our big wall mirrors also fell off the wall because Airstream only used adhesive tape to secure it -- it was bound to fall off, and it did.
As far as your running gear -- personally, I would have had Andy do his balancing act on them -- but good luck with your dyna beads.
Oh, and why not just put everything on the floor in the first place?
John
Flyfisher
flyfisher is offline   Reply With Quote
Old 06-29-2007, 04:39 PM   #3
Ganglin
Ganglin's Avatar
Profile:  1971 27' Overlander
Gahanna , Ohio
How difficult was it to install the Dyna Beads. I have new tires and wheels that were lug centric balanced, new shocks also, none of which has been installed yet. Really thinking about the beads but hate to take the tires back and have them broken down again.
Did you install the beads through the valve with the tool they also sell...?
Thanks....
OHIO - WE ARE THE MOTHER SHIP
Gary
Old 06-29-2007, 05:13 PM   #4
Gunnyusmc
gunnyusmc
Gunnyusmc's Avatar
Livingston , Texas
Images: 69
Tire balance
I have Centramatic's on my truck and both Airstreams and they are great.
Don
Gunnyusmc is offline   Reply With Quote
Old 06-29-2007, 09:55 PM   #5
safari57
safari57's Avatar
Profile:  1951 21' Flying Cloud
West Coast , BC
I had wheels balanced (I have aftermarket mags) using tape weights on the inside only (it doesn't look cool if the mag has weights visible does it?). I do not have the problem you are experiencing. The balance job works well and I'd never put a wheel on anything going down the highway without a proper balance. But that's just me - it took me a lot of years to learn that lesson.
It will be interesting to hear how your solution works.
Barry
safari57 is offline   Reply With Quote
Old 06-29-2007, 11:36 PM   #6
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
Thanks....
Gary,
I just put the dyna beads in my Goodyear Marathon tires. I tried the plastic bottle/clear tubing on the valve stem with the tire still on the trailer at the 6 o'clock position. It took a long time even placing a vibrating sander against the tubing. One tip, the bare pad actually started melting the tubing from friction. I took the next 3 tires off the trailer one by one, placed a chunk of 4"X4" wood under the 12 o'clock position and screwed the tubing onto the valve stem. I found that one of the small funnels from my gardening ph test kit actually imparted a spin on the beads and helped force them down the tubing faster than placing the plastic bottle nipple into the tubing. If I timed it right, the beads did not get clogged in the valve stem, otherwise I had to just thump the stem repeatedly with one of my fingers. Tires filled right back up without a problem and are not losing air. I should get a chance to check out how well the dyna beads do next weekend. This weekend I am installing my third solar panel if I can get some help from one of my kids.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 06-30-2007, 12:20 AM   #7
ROBERTSUNRUS
ROBERTSUNRUS's Avatar
Profile:  2005 25' Safari
Lakewood , California
Images: 18
Hi, the only thing that moves inside of my trailer is the mattress; Everything else stays in place. This only happens when we hit rough roads. You may have a real balance problem.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
2000 Navigator / Equal-i-zer / P-3
YAMAHA 2400 / AIR #12144
ROBERTSUNRUS is online now   Reply With Quote
Old 07-02-2007, 11:29 AM   #8
Action
Moderator dude
Action's Avatar
Profile:  1966 26' Overlander
Phoenix , Arizona
Images: 13
Hmmmmmmm
>>>>>>>>>>>>>>>Action
1966 Mercury Park Lane 4 DR Breezeway 410 4V, C-6, 2.80 - towing a - 1966 Overlander International Twin Bed
1996 Lincoln Mark VIII Diamond Anniversary 4.6L (275hp), 4R70W - 1990 Ford E 150 5.7L, AOD, 3.73 ____________________________________
Phoenix ~ Yeah it's hot however it's a dry heat!
Wheel balancing beads nickcrowhurst Tires 19 05-17-2005 11:53 PM
Need a new tire/wheel for spare. tenrsingr Wheels 10 02-06-2005 08:58 AM
How To Balance Running Gear Inland RV Center, In Axles 26 07-08-2004 03:14 PM
Tire balancing - one more time !!! femuse Tires 25 02-26-2003 06:04 PM
Wheel assembly balancing - which method?? 83Excella Wheels 0 03-23-2002 07:53 PM
