Old 04-12-2016, 10:03 PM   #1
2008 25' Safari FB SE
El Cajon , California
Tire wear
I have a 2008 25' Safari. I've had it for a year and believe it doesn't have many road miles. It still had the original tires on it when took it on a 10,000 trip last summer.
We had a blow out on the right rear which was replaced. The tire shop put the new tire on the front and the front tire (an original) on the rear axle. After the trip I and a few couple hundred mile excursions I was surprised to see the original tire that was installed on the axle which had the blow out was terribly worn on the outside edge (photos). I've called Dexter Axle to see if bent axles were an issue and got the impression this was rare. With such an old tire I'm wondering if this is the way they wear out (the other two originals on the drivers side both have a lot of tread).
Has anyone else experienced tire wear like this? How about bent axle experience.
ID:	260591   Click image for larger version
Pullingtin is offline   Reply With Quote
Old 04-12-2016, 11:06 PM   #2
TahoeStream'n
subfan1's Avatar
2012 20' Flying Cloud
La Habra , California
Yes on our 2012 FC 20ft
Axel had to be aligned. If I bought a 2008 trailer and had the original tires on it I would have replaced them right away. That's just me though.
subfan1 is offline   Reply With Quote
Old 04-12-2016, 11:42 PM   #3
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
Tires look under inflated. ST tires that are more than 3 years old should be monitored very closely for abnormal wear, an out of round condition, or lateral shoulder variation.
You can quickly validate axle alignment by placing a straight edge against the sides of the tires on each side at the center of the wheels. The front shoulder of both tires should not touch the straight edge, because the wheels should have slight toe-in for directional stability. An eight foot long floursent light tube can be used as a straight edge.
Travel safe. Pat
PKI is online now   Reply With Quote
Old 04-13-2016, 05:08 AM   #4
Andrew T's Avatar
2008 34' Classic
1960 17' Pacer
London , Ontario
You can see in the picture that the tire has a shifted belt which is not uncommon with ST tires. It could also be out of alignment, the most common position for alignment problems is the right front tire due to being scrubbed around a curb on a right turn but any tire can be knocked out of alignment just like a car.
I would suggest and alignment, Michelin P235/75R x 15" XL tires will solve your shifted belt problems.
Andrew T
Andrew Thomson
London, Ontario
"One test is worth a thousand expert opinions."
Tex Johnston, Boeing 707 test pilot
Andrew T is offline   Reply With Quote
Old 04-13-2016, 06:43 AM   #5
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I think you should follow Andrew T's advice.
We did and I am well into the 2nd set of Michelin XL's on our 25' trailer and have never seen any wear at all. I replaced the first set at 5 years because it was time. I am going into the 4th year on the second set and they still look new. We run about 5000 to 10000 miles most years.
Old 04-18-2016, 07:07 AM   #6
Ravenna , Ohio
What is the measure load on each tire and what inflation do you set the tires to in the AM when they are not warmed up?
Tire size & Load Range info would help.
Tireman9 is offline   Reply With Quote
Old 04-18-2016, 10:41 AM   #7
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
After 3 1/2 years you better keep an eye on them or just put new on ,,,check your axle weight and maybe put Michelin tires on and be rid or the St tires....
Uneven tire wear..Yikes!! daydreamer36535 Tires 18 07-09-2007 10:17 AM
Tire Wear on Tow Vehicle grannyred Tow Vehicles 5 02-08-2006 02:34 PM
Outrigger wear to tire contact Johndigbydog Tires 10 01-20-2006 10:03 PM
Dramatically different tire wear Nicksut Tires 5 10-21-2005 12:41 PM
Un-even tire wear Deputych Tires 5 05-15-2003 12:23 PM
