Old 11-16-2005, 11:46 AM   #1
jglase's Avatar
2005 28' International CCD
Newfield , New York
Unhappy Tire valve problems
The tire valves on my 2005 25' Safari are oriented radially, towards the wheel hub. Consequently, there is insufficient room for most of tire inflator couplers found on 12-volt portable units. The space between the valve end and the aluminum wheel structure is too small. Is this a new "feature" of my wheels or have people dealt with it in other ways?
jglase is offline   Reply With Quote
Old 11-16-2005, 10:16 PM   #2
cammur's Avatar
Roseville , California
Ain't that annoying? We drove our new Safari California to Colorado and back, and were never able to add air, and the air was low (23 lbs in one tire).
The answer: Camping World or perhaps Pep Boys sell right-angle valve extenders. Add these and the valves will point to where you can reach them.
cammur is offline   Reply With Quote
Old 11-16-2005, 10:39 PM   #3
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
How about.....
can you have new stems mounted sticking straight out? I'm not sure why AS would mount them that way.
Marc
Old 11-17-2005, 08:47 AM   #4
jglase's Avatar
Newfield , New York
Tire valve problems solved!
Thanks Cammur. I checked Camping World and found some 45° extenders that should do the job. Ordered two pair.
Cheers!
http://www.campingworld.com/ts-cwi/i...i=223&cvt=jpeg
Fixed that dump valve !!! 77caravaner Waste Systems, Tanks & Totes 1 05-21-2010 05:55 PM
Thetford valve rebuild mkeith54 Waste Systems, Tanks & Totes 17 10-15-2007 02:37 PM
tire pressure wb13798 General Motorhome Topics 16 01-27-2007 12:31 PM
Black & Grey valve trouble camphost Waste Systems, Tanks & Totes 51 08-18-2006 08:45 AM
rear air suspensiom problems wb13798 Airstream Motorhome Forums 19 03-03-2003 07:12 AM
