Old 12-31-2013, 10:23 AM   #1
LeeJ's Avatar
1985 25' Sovereign
Okc , Oklahoma
Tire Temp Monitoring with infrared thermo gun
I do not have a TPTM system, but do have a infrared temperature monitoring "gun."
What temps should be considered "normal" and which ones "abynormal" in an 85 25' Sovereign?
Those of you that have the TPTM systems feel free to comment about the temps you start with and what you consider normal operating temps + and -.
Thank you for your learned experiences.
Lee
Lee Johnson
Corriente de Aire
85 Soverign
LeeJ is offline   Reply With Quote
Old 01-01-2014, 09:09 AM   #2
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Using tire temps look for a tire that is hotter than others. Take a base temp before towing and the take temps at all stops. Again you are looking for consistancy.
This would be to determine future tire failure, not to determine proper tire inflation.
>>>>>>>>>Action
Old 01-01-2014, 09:37 AM   #3
SteveH's Avatar
Common Sense , Texas
Depending on speed and load vs inflation, I think you can expect 20 degree or so above ambient temps.
Regards,
Steve
Old 01-01-2014, 09:52 AM   #4
dznf0g's Avatar
Oswego , Illinois
It also depends where on the tire you check. I check at the shoulder, between the outer tread blocks. This is the hottest part of the tire, due to the most flexing of the carcass. I find that temps are normally 125 - 145*F when outside temps are 80 - 90*F. Steve is right. Get a baseline norm and look for inconsistencies between tires and from the norm.
-Rich-
Old 01-01-2014, 10:48 AM   #5
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Agreeing with recording readings and then watching for higher than your norms. Also consider shooting the drums if possible. Low drum temp can indicate under performing brake and high temps can indicate brake drag.
It's a very useful tool.
The only documented number I can offer comes from the Dill owners manual. It alarms at internal temp over 176 deg F.
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
